Sourcing Vintage Dropout Screws
I have a Miyata 914 (early 90’s I believe) and I’m missing the dropout screws. I would imagine it’s pretty tough to find originals. So what do you guys do in this situation? Hardware store, bike shop, any good resources? I have access to one from another 914 that I can take measurements from. It looks tiny like a 2mm screw or something.
Thoughts?
Thoughts?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 984 Post(s)
Liked 634 Times
Velo Orange: Dropout Screws
And I did not read carefully, bought six to do three bikes, ended up with six PAIRS!
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Virtually all dropout adjuster bolts from the 1960s on are 3mm x 0.5mm thread.
Thank you for all the links and info. I think I found what I need. Much appreciated.
Likes For Mrstott:
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Lots of options as long as complete originality isn't important. I have a stash, but should I ever need to buy some replacements, I'd give retired framebuilder and blogger Dave Moulton my business:
https://www.ebay.com/itm/283715059565
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 134 Times
I bought some from Dave Moulton a while back. As far as originality is concerned, he built the frame.
Likes For uncleivan:
Quoted: 1949 Post(s)
Liked 2,010 Times
Less critical than proper brake lever hoods but these thumb screw things are nice to have.
Disraeli Gears
While I second that emotion to buy from Dave Moulton, I've sourced these from Framebuildersupply.com in Portland, who has quite reasonable prices and shipping (I'm on the other coast). Be aware that they sell two types: the typical machine screw/spring/knurled cap at 2.9 mm OD and 40 mm length (good for long 1010A-style dropouts, but may need to be trimmed for more modern shorter dropouts) and also a plain black stud with 2 mm allen key end that is ~4 mm OD -- not sure what those would work with (aluminum frames?). They can be made even cheaper if you just buy the parts from McMaster-Carr, (3 mm x 0.5 mm pitch screw) though you should be buying enough screws, springs and knurled or acorn nuts (plus other hardware) to justify the shipping cost.
I find that the black plastic ends on the Campagnolo adjusters tend to come off too easily, compared to the steel (or brass?) knurled caps -- I suppose that could be ameliorated with a dab of loctite or epoxy.
But I like the look of the knurled better. Some people seem to reverse the adjuster, so that the knurled cap is inside the dropout, and the slotted (or hex key) head is outside.
I have a pair of dropouts that have a chromed screw threaded through a black nylon crescent that fits in the rear of the dropout slot -- I'm not sure where they came from, but I also have a frame (sourced as a complete bike awhile back, early 70s Raleigh, working on it now) that has 3 mm smooth bore (unthreaded) holes through theCampagnolo Huret dropouts, so maybe that's where they belong. More than one way to skin a cat!
”keep in mind that the dropouts have an adjuster screw thread of 3.0 mm X 0.6mm rather than the 3.0mm X 0.5mm employed by the balance of the known universe.”
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
(...) I have a pair of dropouts that have a chromed screw threaded through a black nylon crescent that fits in the rear of the dropout slot -- I'm not sure where they came from, but I also have a frame (sourced as a complete bike awhile back, early 70s Raleigh, working on it now) that has 3 mm smooth bore (unthreaded) holes through the Campagnolo dropouts, so maybe that's where they belong. More than one way to skin a cat!
I am glad those dropouts are unthreaded. I was already thinking about what drill size to use, when this one just fell out after a liberal application of WD40:
Shifting is fun!
Bikes: Yes, please.
Liked 4,601 Times
I did too, until I found out that new Campagnolo screws were €25 a pair ...
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
For the shorty DOs with threading (ie not the Simplex) I usually replace them with hardware-sourced Stainless steel machine screws and if I can find metric stainless nylock nuts I use them on the outside. Those may look "industrial" to some but function over form in this case. For the inboard heads I go with either Allen heads (if have the space) or slotted pan heads if space is limited. Stainless threads still get greased, that makes it "extra rust-proof" (if there is such a thing)
Quoted: 1562 Post(s)
Liked 1,734 Times
Because I’ve never had a frame where these adjuster screws were needed. In all the frames I have had, the alignment is perfect when I put the wheel in sans adjuster screws.
Also, when you push the wheel all the way back into the dropout, you have more clamping surface for the QR nut. These horizontal dropouts have a tendency to slip as it is.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
Surly makes replacement dropout screws for one of their frames and while shifting through my LBS online supplies, comes across some. Went down there and bought local.
Ive also used hardware store stainless M3 bolts but my last build, a single speed, one of them bent, so went with those Surlys.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
I use SS button heads and acorn nuts from the hardware store
Bikes: many
Liked 1,392 Times
Doesn't being able to move the axle back and forth help when getting a derailleur to work at or beyond its design limits? Like getting a Nuovo Record derailleur to work with a 28T rear cog?
Disraeli Gears
car dodger
I think on the CR list there was some discussion about removing or leaving the dropout screws, it was thought the dropouts are less prone to damage from dropping the frame if the screws were left in.
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
+1, I got a few different lengths from McMaster-Carr, usually use the shortest practical size. I use a nut on the outside, a kinda takewaway from all the Fujis I assembled, which came with outer knurled threaded rings to hold/set the length. No springs. The button-heads take a 2.5mm allen wrench, and make it much easier to install them, no tiny screwdriver tip slipping off all the time.
This is from now-Merziac's Bruce Gordon:
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Quoted: 4512 Post(s)
Liked 6,382 Times
Quoted: 984 Post(s)
Liked 634 Times
Pretty sure this is true, excepting the modern carbon-fibre bikes with electrically powered screws, adjustable by buttons on the brifter; those have a larger diameter.
