Alfine 11 SG-700 Best practises?
Quoted: 8 Post(s)
Quoted: 8 Post(s)
Thank you I have no idea how the country got selected - maybe I didn't pay attention while signing up.
Aaron's website has a lot of information, yes - but my mechanical ineptitude keeps me from working on anything more complex and expensive to replace than a derailleur I'd assumed IGHs would be trouble-free, at least not this one.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I've used Royal Purple 75w-140 in my Alfine 11 for around 10,000 miles with no problems. I used the Shimano oil for the first change; a kit with the necessary syringe and tube came with enough for the flush and fill. As far as I could tell, the only real differences were color and price. I also use this oil for dipping my Nexus gears once a year.
My friend rides geared hubs a lot, and in his Rohloff that oil seems to work with no problems (he also runs that oil + grease for the Shimano Nexus hubs, but he has no Alfine hubs for us to test with them).
Quoted: 8 Post(s)
You just perfectly stated my oft-expressed reason for not going IGH on my folder and instead going with a 2X crank and derailleur system. (Such as avoiding Bike Fridays and Dahon TR with SRAM 3x7/8 IGH.) I pulled apart a 3-speed Steyr hub when I was about 12 and it took me all winter to get it back together. Plus I don't have a workbench and vise for that sort of thing these days. IGHs are generally reliable, but they do require expensive maintenance that I can't do these days, whereas I not only can do work on derailleur systems but very competently, and in the field if necessary, the latter completely impossible with even a simple IGH, let alone something like a Rohloff.
I might still consider getting a more reliable IGH (maybe a 3-speed SA or an 8-speed Alfine) that don't need an oil bath and have a simple maintenance routine...IF I get a good deal on it and only for commuting - so I'm not too stressed about ditching it when need be.
what setups do you have then on your folders? 2/3*8/9?
Agreed. Very messy.
I think many lubes will work fine on a traditional IGH with ratchet pawls on all gears (other than direct drive). But an Alfine 11 does not use ratchet pawls into teeth, but rather, roller clutches in all gears except direct drive; smooth and hard steel cylinders (like roller bearings) that engage with other smooth and hard steel cylinders or shafts, in one direction pressing hard to form a friction lock (hopefully), while in the other direction freewheeling, depending on the gear selected. And thus, the choice of lube may become more critical than if the lube was purely... well... lube, on a ratchet system, because too slippery a lube, and the rollers will slip under higher torque like climbing out of the saddle. I had dreamed of a Brompton with an Alfine 11, a shop in Scotland makes new rear triangles in correct O.L.D. (stock Brompton O.L.D. is too narrow) for conversions, until I found out about the roller clutches, and that made me avoid it like the plague, for the same reasons I avoid CVTs in cars; I don't like relying on two hard, smooth steel surfaces lubed by oil, to generate sufficient friction to not slip, plus durability issues with wear on those surfaces. Pawls rely on durability of tiny springs and pivot pins, but for the most part have been reliable and durable.
Quoted: 981 Post(s)
Liked 584 Times
Hmmm... Apart from my Alfine 11, which has worked perfectly for around 10,000 miles and whose roller clutch surfaces looked unworn when I took it apart for inspection, I have a Prius with over 90,000 miles on it with no mechanical issues. Of course, I haven't taken the transmission apart, but the car still gets 45-50 MPG. Also, a good percentage of the taxi cabs in Chicago are Priuses, so I don't think reliability is as big a problem as you may think.
It maybe possible to special order from Shimano.
Try Shimano's distributor in Thailand.
https://bike.shimano.com/en-SG/infor...S/HAHHONG.html
If above doesn't work, try Shimano - Singapore
https://bike.shimano.com/en-SG/infor...Singapore.html
One of your friends from US or Europe maybe able to carry the oil in checked-in baggage. Can't be more flammable than brandy or vodka.
But getting back to roller clutches and CVTs, durability is all about how much friction load they are carring relative to contact pressure, and that might be good. Priuses are not known to be hot rods, same with Corollas, both offered with CVTs, though notably (last I looked years ago), the sportier version Corolla had a conventional automatic design. When I was excited about perhaps a Brompton with Alfine 11, I researched the hub and found a lot of examples of slipping under high pedaling loads like climbing out of the saddle, some saying it just wasn't designed for high torque, it was designed for casual riders using spinning gears while seated. I'm not a racer, but do often climb out of the saddle.
At the same time I was researching the Alfine 11, I saw mention of some newer IGHs with excellent reputation but significantly lower pricing than Rohloff. Someone on the bike trail also mentioned Pinion, and that does look impressive, but requires a bike built around it and all were $5000+ at the time. Hopefully that comes down.
Likes For Duragrouch:
