Thru axle question
Thru axle question
Old 10-23-20, 03:57 AM
Tpcorr
Bikes: 2016 Specialized Roubaix SL4 Expert, 1987 Cannondale SR500 105, Univega Nuovo Sport
Quoted: 14 Post(s)
Liked 5 Times in 2 Posts
Thru axle question
I just bought a road bike for my wife with disc brakes and thru axles. https://www.liv-cycling.com/us/avail-advanced-1 2 or 3 times a week I'll be removing the front wheel to transport the bike. Do I need to worry about damaging the threads in the fork or on the thru bolt by removing it this frequently? It's my first time with thru axles so I have no experience with them.
Thanks
Tom
Tpcorr is offline
Old 10-23-20, 05:56 AM
Gary in NJ
Bikes: 2020 Fuji Gran Fondo 1.3, 2015 Trek FrankenMarlin Gravel Thing
Quoted: 29 Post(s)
Liked 60 Times in 31 Posts
Given the length of the axle and it’s inherent alignment, it’s almost impossible to cross-thread the axle. There are people who transport their bike for every ride.
be sure to keep it greased for ease of removal and reinsertion.
Gary in NJ is offline
Likes For Gary in NJ:
Old 10-23-20, 06:01 AM
hsuBM
jj
Quoted: 140 Post(s)
Liked 110 Times in 78 Posts
Bike shop mechanics and manufacturer sales reps will say no.
Invest in brushes to clean out the thru holes and the axle’s threads and some shop rags to wipe off the rest of the axle and keep them cleaned and greased to extend their useable life as much as possible.
Next question to pose to your dealer’s mechanic- how often to clean & regrease? Every time? When it looks dirty to me? When it looks dirty to my grandfather (every time, pretty much)?
hsuBM is offline
Likes For hsuBM:
Old 10-23-20, 06:43 AM
Tpcorr
Quoted: 14 Post(s)
Thanks for the good advice and easing my mind.
Tom
Tpcorr is offline
Old 10-23-20, 06:45 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
You should be more concerned with the front brake. Be sure to put a brake shim in the caliper each time you remove the wheel in case you accidentally grab the brake lever while the wheel is not installed. I've also noticed that when a bike is forward facing on a roof rack, sometimes the wind resistance can be enough to push the brake lever in some.
topflightpro is offline
Likes For topflightpro:
Old 10-23-20, 06:55 AM
Tpcorr
Quoted: 14 Post(s)
Thanks , the bike shop gave me a shim for the front brake and I've practiced with it a bit. I actually mount the bikes in the back of the van. I have fork mounts attached to a 1X4.
Tom
Tpcorr is offline
Old 10-23-20, 08:27 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
Just make sure you torque it back to spec when reinstalling and you will be fine.
jadocs is offline
Likes For jadocs:
Old 10-23-20, 09:14 AM
WhyFi
WhyFi's Avatar
Quoted: 20808 Post(s)
Liked 9,450 Times in 4,668 Posts
Tom
Shimano also has little lever blocks that slide in and prevent gear changes in addition to braking. Not sure if they actually sell them separately, but your LBS might have a bucket of them sitting in the back room.
WhyFi is offline
Likes For WhyFi:
Old 10-23-20, 10:21 AM
Tpcorr
Quoted: 14 Post(s)
Thanks WhyFi. I'll check, nice tip.
Tom
Tpcorr is offline
