New alloy wheels
New alloy wheels
Old 10-24-20, 12:25 AM
btppberk
Quoted: 77 Post(s)
Liked 26 Times in 23 Posts
New alloy wheels
Following advice from an earlier forum, I've decided to get some new wheels for my 2012 Focus Izalco Pro 10-speed SRAM. I current have the narrow DT RR 1850s. I'd like something that can comfortably fit a wider tire, especially since the roads here can be pretty bad. Aero is not important to me; I'm more interested in climbing. Since this is a relatively old bike, I'd like to keep it on the cheaper side, ideally under $500.
Someone suggested the Hunt Race Aero Wides. Any other opinions out there or tips for figuring out which wheels to buy?
btppberk is offline
Old 10-24-20, 12:54 PM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
I'm pretty happy with a pair of Campag Zonda clinchers I bought in May. ~$360 with free shipping from (IIRC) Chain Reaction Cycles. 18 radial spokes front, 21 G3-pattern in the rear, 17mm internal width, 24mm deep front, 30mm (IIRC) deep rear, so not massively aero. Actual weight (w/o skewers) 672F/887R. Solid rim bed, so no tape needed. I use 25mm Rubino Pros, which are an actual 26mm diam with the Zondas. They'll accommodate wider, but I'm at the limit of my frameset, tire-wise. They're pretty stiff, IMO. I started running them at 100 psi F/R, which was what I used to use with the Rolfs that preceded them, but that setup was boneshakingly harsh, so I've dropped to 85 psi front, 90 psi rear, which works out well for me. I got mine with a Campag free hub, but they're also available for Shimano. I'm ~185lb, and I've used these for solo rides (18 mph average) for ~2200 miles so far. They remain perfectly true. My only reservation is that, if I break a spoke, I'll have to go proprietary, which will be expensive, but I ran the same risk with the Rolfs and it never happened in ~16 years
Litespud is offline
Likes For Litespud:
Old 10-24-20, 01:19 PM
Bob the Mech
Bob the Mech's Avatar
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times in 55 Posts
Hunt Race Aero Wides pretty damn good set of wheels....
https://www.cyclingweekly.com/editor...-wheels-358775
Bob the Mech is offline
Likes For Bob the Mech:
Old 10-24-20, 01:49 PM
crn3371
Quoted: 43 Post(s)
Liked 30 Times in 16 Posts
At Bicycle Wheel Warehouse you can get their house brand rims laced to Dura-Ace 7900 hubs for $450.
crn3371 is offline
Likes For crn3371:
Old 10-24-20, 03:11 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Yeah, I have no complaints re: their sister model to these, the Sprint Aero Wides (same rim but polished silver, upgraded hubs).
That said, to get the same rims and some manner of customization, the "Ventus" version linked below is another option
PWB SIGNATURE - VENTUS
Sy Reene is offline
Likes For Sy Reene:
Old 10-24-20, 05:34 PM
btppberk
Quoted: 77 Post(s)
These have gotten lots of reviews, but from what I read, they are too narrow for 28s and not idea for 25s either.
btppberk is offline
Old 10-24-20, 05:36 PM
btppberk
Quoted: 77 Post(s)
Thanks for the tip. It seems like there are hardly any reviews though.
btppberk is offline
Old 10-24-20, 05:55 PM
Litespud
Quoted: 645 Post(s)
Pretty much perfect for 25s. The rims are 23mm external width. My nominal 25s are 26mm actual width on these rims No idea about 28s, but they’re certainly spec’d as 28-compatible
Litespud is offline
Old 10-24-20, 06:08 PM
btppberk
Quoted: 77 Post(s)
I have no idea myself, but here's one guys opinion (he seems knowledgeable, but who knows):
A 25C tire on a 17C wheel – better comfort but no better speed or handling than a 23C tire on a 15C wheel. 23C tire on 17C wheel at right pressure will get you somewhat improved comfort with improved aero if the rim has at least a rounded nose rather than box or V profile, is >35-40mm, and you are riding at 18mph/29kph or faster.
btppberk is offline
Old 10-24-20, 06:25 PM
mercator
In the wind
mercator's Avatar
Bikes: Giant TCR Advanced Team, Lemond Buenos Aires, Giant TCX, Miyata 1000LT
Quoted: 172 Post(s)
Liked 120 Times in 54 Posts
I'll second the recommendation for the Zondas - excellent wheel at a good price. I'm running them with 25mm GP4K and they are very nice.
On an older bike, all those wide rims are a pretty tight fit.
mercator is offline
Old 10-24-20, 06:30 PM
Litespud
Quoted: 645 Post(s)
well, there you go...🤔
Litespud is offline
Old 10-25-20, 11:37 AM
dan911
dan911's Avatar
Bikes: Marinoni Piuma Custom
Quoted: 31 Post(s)
Liked 16 Times in 10 Posts
A little over your budjet but the Hed Ardennes / Belgium + ares awesomes wheels. They are well build and wide.
HED
dan911 is offline
Likes For dan911:
Old 10-25-20, 07:07 PM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1097 Post(s)
Liked 559 Times in 446 Posts
Zondas work great with 25mm tires and reduced pressure. The ride is greatly improved over 23mm tires with 10-15 psi more pressure. I have them on two bikes. They will also accommodate 28mm tires with no problem. Campy/ Fulcrum recommends their 17mm rims for 25 to 50mm tires.
DaveSSS is offline
Likes For DaveSSS:
