What is this Bianchi?
Old 02-16-20, 03:32 PM
Jicafold
Quoted: 195 Post(s)
Liked 41 Times in 34 Posts
So I picked up this frame last week. I know its a low end model looking at the stamped rear dropouts. But any idea what model this is or what it is made of? Has some nice lug work and looks like it sported centerpull brakes.Nice chrome fork crown. Serial number is on the head tube and says 1L21372. Thank you.
Jicafold is offline
Likes For Jicafold:
Old 02-16-20, 04:24 PM
T-Mar
Quoted: 3112 Post(s)
Liked 536 Times in 432 Posts
Based of the serial number format and location, it was manufactured in Italy during 1971. The model appears to be a Strada.
T-Mar is offline
Old 02-16-20, 06:37 PM
stardognine
stardognine's Avatar
Quoted: 647 Post(s)
Liked 210 Times in 157 Posts
I had a feeling this was a “good one”, but didn’t want to jinx it for ya. 😉 Now that T-Mar has IDed it, you’re golden. Congrats. 👍
stardognine is online now
Likes For stardognine:
Old 02-16-20, 06:56 PM
merziac
merziac's Avatar
Quoted: 1667 Post(s)
Liked 566 Times in 415 Posts
Nice score!
Cottered, rusty and crusty, that crank is a big deal to a point, hope it's all good.
BB width?
merziac is offline
Old 02-16-20, 08:36 PM
John E
feros ferio
John E's Avatar
Quoted: 794 Post(s)
Liked 129 Times in 104 Posts
Nice score!
BB width?
BB shell width is presumably 70mm.
Chainrings are the same proprietary 128mm BCD units the very desirable cotterless aluminum Nervar Star crank takes. If you scrap the cranks, the rings are probably worth something on eBay. I am guessing 52-47, which was a very common Bianchi spec. through the 1960s.
T-Mar is correct (as always) regarding year of manufacture, with the leading 1 denoting 19x1. Based on components and frame design, x in this case is clearly 7.
John E is offline
Old 02-16-20, 08:41 PM
juvela
juvela's Avatar
Quoted: 1995 Post(s)
Liked 235 Times in 207 Posts
Frame constructed of Agrati "AM" pattern lugset Nr. 000.8040/U
head is bulge-formed (one-piece) Nr. 000.8046
seat lug is item Nr. 022.8049
bottom bracket shell is item Nr. 000.8507
dropouts Agrati item Nr. 000.8002
fork ends Agrati item Nr. 000.8010
This is the first Strada model have seen to be fitted with the cottered NERVAR Sport chainset. At this time it was standard on the next model Bianchi up the range, called the Record/Rekord.
Brakes mentioned in text are Balilla Corsa 61 as produced by Giovanni Galli S.p.A.
The bicycle's Agrati bottom bracket shell is 70mm in width and Italian threaded.
juvela is offline
Old 02-16-20, 08:45 PM
merziac
merziac's Avatar
Yep, would expect it to be 70mm and if original, which I assume it is then definitely should be kept for posterity at least, regardless of condition.
Can always be used for reference, placeholder or show, no way I would ever scrap any part of that crank.
merziac is offline
Old 02-16-20, 08:50 PM
Jicafold
Quoted: 195 Post(s)
Great. Thank you for the information. I smell a repaint in Celeste with red decals.
Jicafold is offline
Old 02-17-20, 11:55 AM
stardognine
Quoted: 647 Post(s)
What? And destroy that beautiful “patina”? 🤔😉
Old 02-17-20, 12:52 PM
Jicafold
Quoted: 195 Post(s)
So how can you tell the difference between a Strada and a Rekord as in this current thread:
https://www.bikeforums.net/classic-v...ification.html
Jicafold is offline
Old 02-17-20, 02:54 PM
Jicafold
Quoted: 195 Post(s)
Took the bottom bracket out, since it's a slow work day. Looks like it may have been a repaint. It's Celeste underneath.
Jicafold is offline
Old 02-17-20, 05:30 PM
stardognine
Quoted: 647 Post(s)
Now THAT was a pretty good trick. You wanted it to be Celeste, and it was, even though it isn’t. 🤔😁😉
Old 02-17-20, 07:10 PM
Jicafold
Quoted: 195 Post(s)
I took the power sander to it. It's all Celeste underneath. Yea!
Jicafold is offline
