Centurion Pro Tour 15 FD Problem
Old 10-14-19, 08:24 PM
Sophylong
Hello all,
Getting back into cycling after many years away and I have forgotten almost everything I used to know! 10 years ago I had all the basic bicycle tools and basic know how, but at that time due to various life events I sold all the bikes and have seem to have forgotten how to trouble shoot.
Recently got back into riding for exercise and picked up a Centurion Pro Tour 15 for $40. It had a mix matched group set on it and so I went about mix matching it even more!
The biggest problem is the crank and FD. I had a compact FSA BB30 sitting around collecting dust which obviously wouldn't mount and also had a single speed I put together about 5 years ago that I held on to. The Centurion came with a square taper triple. I removed the triple and mounted the Sugino AT cranks on to the bike and the FSA had the same BCD so the rings went on too. The original FD is a clamp on and the only FD I had laying around was a 105 braze on so i left the original FD on.
The L limit screw adjusted outboard enough to engage the smaller ring but im having difficulty getting into the big ring. It went in 1 in 20 times or so during my test ride. H limit is maxed out. Im thinking the FD is a little high, but im not sure because I believe the original triple was also a 50 tooth. It looks like if the crank arm was about 2mm closer to the frame of the bike that would work too, but I feel like I shouldnt tighten it any further. Could it be a spindle length issue?
Everything else is working well. I had a full 105 10spd set, minus chain, sitting in a box in the garage so that all bolted on and has been adjusted. Funds are still tight so I'm hesitant to bring it into the LBS. Is there any hope for me!? Ive lost 17 pounds these past few months so I thought I deserved the $40 upgrade bike, but its turning into a bit of a nightmare.
I'd love to post a picture but apparently my post count is too low. I can email it to someone if they'd be able to post it for me.
V/R
Sophy
Sophylong is offline
Old 10-14-19, 08:53 PM
Sir_Name
Sir_Name's Avatar
Bikes: are fun!
Quoted: 392 Post(s)
Liked 192 Times in 91 Posts
Well, a Pro Tour 15 for $40 is quite the steal...that’s a great bike.
Just to be clear, what parts were taken off and what parts replaced them? Sounds as though the Sugino AT stayed in place with new rings and same spindle? What were the tooth counts before and after, 50t for old and new? The front derailleur cage outer plate should float a couple mm above the big chainring. Front derailleur low limit keeps the chain from dropping from the small chainring towards the frame, high front derailleur limit keeps the chain from dropping from the big chainring towards the pedals. Need to take chainline to the freewheel at both extremes into account.
Was the bike stock when you got it? Check the chain length per Sheldon Brown. Pics would really help. Keep posting!
Sir_Name is offline
Old 10-14-19, 09:06 PM
Sophylong
Just to be clear, what parts were taken off and what parts replaced them? Sounds as though the Sugino AT stayed in place with new rings and same spindle? The front derailleur cage should float a couple mm above the big chainring. Was the bike stock when you got it? Check the chain length per Sheldon Brown. Pics would really help. Keep posting!
I thought $40 was a good deal too, which is why i jumped on it The Sugino cranks actually came off the single speed I referenced earlier. I do not believe the Centurion was stock. The parts replaced/removed we're:
-brake levers (replaced with 105 10spd Brifters)
-triple crank, replaced with Sugino ATs and FSA compact rings
-DT shifters removed and replaced with stops
-DP25 wheels(29ers?) replaced with Shimano RS
-quil stem replaced with 1 1/8 adapter and stem
-new handle bar
- toe clips/pedals with old DA clipless
- suntour? RD replaced with 105
Chain length seems good. I set the chain big to big and added two lengths. Has enough length and the space between the RD pulley chain section and chain stay chain section seem to have enough gap.
Thanks for looking!
Edit: regarding low limit, I understanda i adjusted the limit so it wouldn't fall towards the frame. The high I maxed out hoping to get a couple more millimeters towards the big chain side. Spindle and BB were left original.
Old 10-14-19, 09:10 PM
CO_Hoya
Señor Member
Bikes: Yes
Quoted: 190 Post(s)
Liked 109 Times in 61 Posts
Pic assist
CO_Hoya is offline
Old 10-14-19, 09:17 PM
nlerner
Quoted: 1939 Post(s)
Liked 1,273 Times in 693 Posts
Sounds like your BB spindle is too long on the drive side as you suspect. One cheap fix is to reverse that spindle, i.e., try what’s now on the non-drive side on the drive side.
nlerner is offline
Old 10-14-19, 09:20 PM
Sophylong
I didn't even think of that! I guess I'll be watching YouTube videos tonight lol. May have to get some more tools, all I was able to find in my old boxes were a pedal wrench and crank puller
Old 10-14-19, 10:05 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 632 Post(s)
Liked 261 Times in 169 Posts
I'd like to see a picture of the crank looking down from the top. I bet there's lots of clearance between the inner chainring and the chainstay, which would mean your bottom bracket spindle is too long. IMO it's easiest to experiment with different length spindles by trying different cartridge bottom brackets. Cup & cone BB's are OK, but they're a hassle to experiment with.
Jeff Wills
Jeff Wills is offline
Old 10-15-19, 07:22 AM
due ruote
due ruote's Avatar
Quoted: 728 Post(s)
Liked 224 Times in 157 Posts
Agree with others about the spindle length.
Was there something wrong with the triple? Why not just use that?
due ruote is offline
Old 10-15-19, 07:40 AM
Mr. 66
Mr. 66's Avatar
Quoted: 446 Post(s)
Liked 285 Times in 213 Posts
That's a real beaut you have, great changes. I do agree with the others about the spindle check that over, it does look that the FD may be a tad high.
Mr. 66 is offline
Old 10-15-19, 07:45 AM
ollo_ollo
ollo_ollo's Avatar
Bikes: Still have a few left!
Quoted: 345 Post(s)
Liked 79 Times in 50 Posts
Does your triple takeoff say "Aerox" on the arm? That's what was on my old Pro Tour. A top end SR crankset. Don
ollo_ollo is offline
Old 10-15-19, 08:13 AM
Sophylong
NBothing wrong with the triple that I know of. It was one of those cases where I got "itchy hands" and couldn't leave well enough alone. Had spares parts sitting around and thought I'd make use of them.
Thanks, I think it's coming along fairly well too. I will have to try adjusting the FD first when I get home.
Currently at work, but I agree. From what I recall the spindle does seem to have quite a bit of space between the frame and crank arms. I'm hoping that the spindle is asymmetric and want to try flipping it first. Just need a little bit of time and see if I can get my hands on some additional tools.
Oh that's good to know! I do believe it is marked AEROX, but won't be sure until I get home later this evening. To be honest, I just like the look of the compact more which is why I attempted the swap in the first place.
Old 10-15-19, 08:29 AM
seypat
Quoted: 1666 Post(s)
Liked 525 Times in 380 Posts
You could get compact rings for the triple crank and run it as a compact double.
seypat is offline
Old 10-15-19, 08:51 AM
ollo_ollo
ollo_ollo's Avatar
Quoted: 345 Post(s)
Can't say for sure, because my Pro Tour was high mileage when I got it, but said to have all original equipment. It had SunTour VGT (Luxe?) derailleurs. With a new wheel set, it gave good service as my main Winter rain bike for about 10 years. Sold it to someone in Bellingham, WA. Don
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 10-15-19, 11:06 AM
davester
davester's Avatar
Quoted: 574 Post(s)
Liked 223 Times in 130 Posts
Sounds like a good buy! Do be aware that jamming a 10-speed rear wheel in there requires that the frame be cold set to the correct width and, more importantly, the dropouts need to be realigned. Otherwise, the stress placed on the rear dropout by clamping down on the quick release can eventually crack either the braze between the dropout and chainstay, or the dropout itself. This has happened to me and a number of folks on the forum.
davester is offline
Old 10-15-19, 12:14 PM
squirtdad
squirtdad's Avatar
Quoted: 1255 Post(s)
Liked 487 Times in 358 Posts
Best solution is to get cartridge bottom bracket to match the crankset you are using, I don't recall many japanese BB be asymetrical.....that was more of a campy thing....but that is memory
other observations
makes sure you can run Big Big combo. if you can't you need to lengthen the chain safety issue if you do not (fwiw I have moved to big big chain sizing method)
if that is a 120 spacing you really should coldset to 130mm, less an issue if it is 126mm spaceing
seat should be close to level.....lower seat post if needed
squirtdad is offline
Old 10-16-19, 08:49 AM
Sophylong
Sorry for the late replies, I am limited to 5 responses in 24 hours currently.
other observations
Thank you for the warnings. I'll make sure to check the dropouts and stays for stress or cracks. When I purchased the bike it actually came with an 8spd rear wheel, which I believe is spaced at 130. I haven't checked alignment yet, but I'll do some rudimentary work with some string and see how that goes. The 10spd rear actually dropped right in without having to part the drops so I want to assume the previous owner cold set it. The brakes were also set up already for 700c. Looking at some pictures online the previous owner definitely made some changes to the bike's stock form and from the saddle and other changes I assume it was used primarily for long distance riding or touring. I'll have to measure the drop outs and confirm spacing. To be clear, the chain length WAS set big-big through the FD.
Regarding the original problem, I am happy to announce that the issue no longer exists! After cleaning the roof yesterday evening I got around to mucking around with the bike and made a few changes. The FD was actually around 3mm too high so that was lowered to the appropriate height. I was not able to find torque settings online for the crank to BB but decided to give the crank arm bolt 2/3 a turn more tightening. It does not appear or feel over tightened but managed to bring the arm inboard enough that the shifting now works beautifully with no chain rub except in extreme cross chain events.
Regarding saddle height and angle. That picture was from my first test ride and in my haste to get going I just eyeballed the saddle height and angle. It has now been adjusted. It actually needed to be about 4mm higher and pushed back slightly. No knee pains, and the angle of my knee at full extension seem about right. Unfortunately I haven't been able to go for an extended ride so that may change a little in the future.
Thank you to everyone who took the time to reply to my post! I truly appreciate it. All that's left is to clean up cabling and shorten the housing in a few places and go for some more rides! I'll take a few more pictures and throw it into that long running "vintage with ergo bar" thread too.
On a side note, if anyone here bought an Eddy Merckx Tianium AX with full DA and carbon wheels 14 years ago on EBAY I hope you are still riding it and would love some pictures of my old bike.
