Looking For A More Compliant Fork.
Cyclocross and Gravelbiking (Recreational) This has to be the most physically intense sport ever invented. It's high speed bicycle racing on a short off road course or riding the off pavement rides on gravel like : "Unbround Gravel". We also have a dedicated Racing forum for the Cyclocross Hard Core Racers.
Old 12-07-19, 02:10 PM
Krenovian
Krenovian's Avatar
Bikes: Hers: Volagi Liscio, Kestrel 200 SCI, Niner Jet9 RDO, Ellsworth Truth. His: Kestrel 200 EMS, Niner Jet9, Psyclewerks Wild Hare. Ours: Paketa V2
Quoted: 5 Post(s)
I'm riding a 2019 Niner RLT RDO. I find that the rear of the bike and front of the bike are out of balance. By that I mean the back of the bike feels much more compliant than the front. I guess that is to be expected when the fork has no rider wt. limit and I weigh 155 lbs. I've replaced the stem with a Redshift Shock Stop stem and that has helped. I'm wondering if there is a more compliant fork out there? I'm also looking for a fork with more rake/offset. I have some minor toe overlap with a 38 mm tire on the front which will be more marked with a bigger tire. Forks under consideration include ENVE's G series gravel fork, Parlee's gravel fork and the 3T Luteus II Team Stealth fork. Do any of you have experience with these forks in comparison to the Niner fork? Any other forks you might recommend for my consideration?
Krenovian is offline
Old 12-07-19, 04:25 PM
Krenovian
Krenovian's Avatar
Quoted: 5 Post(s)
Originally Posted by Spoonrobot View Post
#1 thing you could do is run a fork with 1 1/8” straight steerer with a headset reducer. The lack of compliance is almost entirely from the OS headtube and steerer.
I hadn't thought about it from that standpoint. It makes sense.
Old 12-07-19, 05:08 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 4736 Post(s)
Liked 1,911 Times in 1,151 Posts
What spoon said.
your bike with a different steerer width or perhaps better yet- a frame that doesnt have a massively oversized head tube and tapered steerer combo would change the stiffness/harshness.
https://whiskyparts.co/forks/no.9-cx-disc-12-straight
This has a 1 1/8 steerer, is full carbon, and clears 42mm tires. Not sure how the rake and axle to crown measurements compare to your current setup.
mstateglfr is offline
Old 12-07-19, 06:37 PM
shoota
shoota's Avatar
Quoted: 1367 Post(s)
Liked 222 Times in 167 Posts
Oversized head tubes are a plague on modern gravel bikes. There's no reason for them. Change my mind.
2019 Salsa Warbird
shoota is offline
Old 12-07-19, 06:41 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2791 Post(s)
Liked 728 Times in 511 Posts
Isn't there some thinking that having a steerer that is more flexible than the fork blades contributes to brake shudder, though?
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 12-07-19, 07:19 PM
Elvo
Quoted: 502 Post(s)
Liked 193 Times in 110 Posts
Fox Ax, Lauf Grit
Elvo is offline
Old 12-07-19, 07:59 PM
dsaul
Quoted: 538 Post(s)
Liked 326 Times in 232 Posts
Carbon forks and compliance don't go together. Let some air out of your front tire.
dsaul is offline
Old 12-08-19, 04:10 AM
sweetspot
Quoted: 82 Post(s)
Liked 8 Times in 8 Posts
this is a very interesting topic for me. I feel that today's gravel bikes are not balanced in terms of front and rear comfort. It is much easier to engineer compliance at the rear. Front of the bike is much harder but you still have at least 3 things to do. First, like it was already said, it is the headtube and the width of the steerer. Your bike, like many of current gravel bikes, has an oversized headtube so even if the steerer itself is narrow, the headset will keep it from flexing too much. The second thing is the fork length. Generally the longer the fork the more flexing it can exhibit. But too much flex is no good, especially if you have disc brakes (like every gravel bike has now) so don't expect much but for sure longer forks can be more comfortable. And finally, there is something that I discovered recently while testing a GT Grade Carbon bike with its Flip Chip fork. I mean if you move the axle of the fork axis and closer to the rider it will promote more flex and generally more comfortable ride (this is the same patent that my Jamis Renegade bike uses with its ECO compliance fork). Yet again, we are talking about a few percent more compliance. So in the end, if you want a really comfortable front end of the bike, go for something like Specialized Diverge with its Future Shock. From my experience, you will have a hard time finding something more comfortable...
sweetspot is offline
Old 12-14-19, 12:00 AM
dwmckee
dwmckee's Avatar
Quoted: 240 Post(s)
Liked 117 Times in 78 Posts
I suspect your more sensitive hands at the handlebars vs. your comparitively less sensitive and well padded arse at the rear is why you feel the front is less compliant. Actually a curved, raked and cantilevered front fork at the front end is likely more compliant than the dual triangulated rear on most biikes though if you could measure it. Also the fact that you instinctively take weight off of the seat by standing a bit when you see bumps also makes the rear seem more compliant. You cannot easily de-weight your front end like you can your rear end.
I have been riding a Lauf Grit fork for about two months now for gravel riding and I have to say it is freakin' amazing. Not only is it a great way to gain compliance with no loss of precision steering, but it has INSTANTLY cured my chronic hand numbness problem! I highly recommend it as a great comfort enhancer with very modest weight penalty. No moving parts either!
dwmckee is offline
