Is this the right BB replacement?
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
A local shop installed this BB back in 2013 before I started doing a lot of stuff myself so I never really looked into it until now because I think I need to replace it because I keep getting a clunking/knocking sound and I don't think it's the freewheel though maybe it's the pedal spindle I dunno.
Anyway, going to try to replace this and see what happens.
is this: https://planetcyclery.com/shimano-bb...xoCxKsQAvD_BwE
(btw this appears to be a pretty hard to find size)
the correct replacement for my current:
Yes I measured the spindle length with calipers, it's 107mm. English threading, right?
Weird how it has a piece that snugs against the outside of the BB shell on the drive side, but sits inside the shell on the non-drive side. Is that normal for these vintage bikes?
Thanks for any help.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Looks like a normal cartridge square taper bottom bracket. Most likely English threading - does DS have left threads and NDS right threads?
There is also JIS vs ISO difference - most likely it is JIS.
The one you linked looks good.
Likes For etherhuffer:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
For just $9 more you can get a higher quality, made in Japan one: Tange LN-3922 Square Taper Bottom Bracket – The Bikesmiths
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Liked 1,471 Times
Likes For SoSmellyAir:
