Specialized Hardrock 26x2 rims?
Ok, so
I got a bike from a friend after he took a pretty decent crash on it, everything is fine except the rims are pretty much garbage.
I beleive the hubs are fine on both, could anyone point me to replacement rims for a decent price for this bike? if they are cheap enough complete rims would be nice, otherwise i can pull the hubs out of these and have someone lace them, or do it myself if it isnt too hard.
Thanks!!
Thanks!!
Quoted: 4222 Post(s)
Liked 3,910 Times
There are a lot of rims that would be the right size to install on the bike. Don't assume that the spokes will be able to reuse, condition and length... But also know that the parts to rebuild on the old hubs will likely cost more then basic prebuilt wheels. This is the time to establish a relationship with a shop to either get the replacement wheels from or the rims and spokes (and fall back on the shop to complete the wheel builds). Andy.
Quoted: 5849 Post(s)
Liked 2,683 Times
Unless the hubs are top quality and worth salvaging you'll be able to buy decent quality wheels for about the same price as rims and spokes. If you can or and plan to build the wheels yourself, it's close to break even, but if you have to pay a builder, then rims + spokes + labor almost always costs more than a comparable wheel.
BTW- To clarify, the rim is the hoop between the spokes and tire. When it's laced onto a hub with the spokes, the assembly is a wheel.
So search bicycle wheels to get a sense of what's out there at what price.
FB
Chain-L site
FB
Chain-L site
Insane Bicycle Mechanic
Quoted: 810 Post(s)
Liked 723 Times
This is about as good a deal as you can find for complete wheels: https://www.nashbar.com/bikes/Product...62_-1___202477
Given the cost of decent rims and spokes and the labor of having them built (not that I'm discouraging you from learning how), this is a killer deal.
Jeff Wills
Jeff Wills
Alright, used to ride bmx, but this setup seems to be much different with disc brakes and such.
Jeff, will that specific setup fit on my bike? at that price i could order tonight!
Keep in mind, I am a bit overweight and using this bike as a weight loss tool (it was free from my friend) thanks for all the quick replys!
Quoted: 810 Post(s)
Liked 723 Times
FWIW: I bought a set of those wheels a few years back and they're still working fine. I'm not small, either: 6-foot-4, 220 pounds.
Jeff Wills
Jeff Wills
before i order in the morning, does it matter if my stock rims are 2 inchs wide and the ones you suggest are 1.75?
Quoted: 810 Post(s)
Liked 723 Times
No... not much at least. If your tires were very wide it might make a difference, but if they are the stock tires you will have no issues.
Jeff Wills
Jeff Wills
S'Cruzer
2" rims? are you sure that's not the tire size? the rims on a mountain bike like a Hardrock are rarely much over 25-30mm wide. you can put a 2.25" tire on that easy.
on the path
Bicycle Mechanics
32
08-30-15 01:25 PM
lopek77
19
10-12-12 09:07 AM
