Ask the Community
#153
Bikes: CENTURION / LOOK / Bianchi
Quoted: 214 Post(s)
Liked 10 Times
What always worked for me was to just use electrical tape. Good for a solid night session -- Easy to remove and doesnt leave residue behind. So.. Just tape the light to your bar in other words
What light we talkin about here?
#154
Quoted: 1332 Post(s)
Liked 398 Times
Axiom Lazer 500. The mount broke while I was riding last night. Ideally I want to figure out something I can easily remove and put back on for commuting type stuff. I have a smaller spare light to use in the meantime, but it's **** at actually lighting the road on dark routes.
#155
Bikes: 2015 Aventon Diamond
Quoted: 151 Post(s)
I am currently riding 48x17, which is 74 gear inches. Is there any advantage to having smaller sprockets, other than the reduced weight?
Example does 43x15 (75 gear inches) differ much from 49x17 (also 75 gear inches)?
#156
Calamari Marionette Ph.D
#157
Dave
#158
Liked 398 Times
Good idea, I fixed my dresser with gorilla glue a few years ago. I'll see if I have any still lying around.
#159
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Smaller sprockets will wear proportionally faster.
#160
tumbleweed
I'm having trouble finding tube for some deep v rims. I can't locate long presa valve tubes in a large diameter.
Question is;
Can I install a 35 mm tube in a 40mm tire? I know I can but will it cause any issues?
Question is;
#161
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
It will probably be ok. The tube is quite flexible and will simply expand to fit inside the tire.
#162
tumbleweed
Cool, That was my train of thought but I wasn't really sure if stress would over take the tube or not.
Thank you T.T.
Thank you T.T.
#163
Veteran Racer
Liked 764 Times
A tube is like a balloon, which can expand a lot before it bursts. Once the tube is constrained by the tire, the only stress it sees is from direct pressure, and as long as the tire casing is not damaged it will not fail. Tubes are often rated for a range of tire sizes anyway, such as 35-43mm, so going from 35mm to 40mm as in your situation is certainly not a problem, IMO.
#164
Quoted: 151 Post(s)
Creaking sound - need help
So, I am having a creaking sound that is coming from either the cranks or BB, and I am not sure which is the culprit or what I should be looking for to fix.
I get a slight creaking sound on the left side crank when applying a lot of torque, either with forward pedaling or backwards. If I mash the pedals to go forward I will get a slight creaking that does not continue as I keep pedaling. That is until I apply enough back pedal torque, in which case it slightly creaks again. Then again, if I apply forward motion torque it slightly creaks again. So it only happens when significant torque is applied in either direction. Does that make sense???
To me it seems like something is slightly loose, but the crank arm is tightened to spec, and the BB is tightened to spec.
Any clues as to what I should start with? Go easy on me, I am newish to the world of cycling.
Thanks!
Thanks!
#166
Might be pedal bearings. I had a similar situation recently, and was convinced it was the crank, but not so much. If you have an extra set of pedals, try swapping them out.
Dave
Dave
#167
Quoted: 151 Post(s)
Also, should I grease the pedal threads prior to install? Or loctite? I never know what should be used where. lol
#168
Quoted: 151 Post(s)
Ok, so it's not the pedals. They are plenty tight, and I still get the creaking when pushing on the crank arm itself.
I gotta ride it home from work, and then I'll take the cranks off and inspect.
#169
I've read that teflon tape on the bottom bracket threads will help fight creaks if that is the culprit.
#170
Bikes: steel track
Quoted: 235 Post(s)
I'll add one to the already large bucket of standard things to check for squeaks/creaks in that area:
If your tires just barely clear the chain stays, pedaling hard can deform the stays (or possibly the wheel; I'm not exactly sure about the mechanics of this) enough to rub one side against the tire. Solutions are to 1) true your wheel perfectly to ensure optimal clearance all around, 2) move the wheel back in the tracks ends to get more chain stay clearance (they get wider as you go back), and 3) check your frame alignment and adjust (if it's steel).
#173
If the creak only occurs when changing the direction of the applied pedaling force, I'd be checking chain-ring bolts or cog tightness.
#174
Quoted: 151 Post(s)
This morning before leaving for my commute, I attempted to find the answer. I took out the crank bolt on the left side and it was pretty dirty and gunky. I went to remove the crank arm, and could not get that damn thing off for the life of me. Feels like it might've wedged itself onto the spindle, but I'm not sure. Maybe I am missing something in my haste.
So all I could do was clean and grease the crank arm bolt and reinstall. That seams to have fixed 99% of the creak. I faintly heard it again at the end of my commute this morning, but it could just need to be tightened a little more after riding it.
Attempted to inspect this morning, but could not get the crank arms off.
Wheel is steady in the dropouts with plenty of tire clearance. The creaking is definitely coming from the left side crank arm somehow.
Cog and chainring bolts are tight. The sound is very distinctly coming from the left side crank arm.
I will try to remove them again when I am not so pressed for time. I would think the crank arm should easily slide of the spindle, unless it has been wedged somehow.
I should mention I have the SRAM S300 Courier Crankset like here
https://www.retro-gression.com/colle...-s300-crankset
#175
Veteran Racer
Liked 764 Times
I'm confused by your statements. If you have a square tapered spindle, the crank will require a puller to get it off. It will not just "slide off" and will indeed be too tight to remove w/o a puller.
