Rear derailleur shifting issue.
Old 07-15-19, 10:16 AM
hrdknox1
hrdknox1's Avatar
Quoted: 85 Post(s)
Liked 53 Times in 40 Posts
Shimano Dura Ace 10 spd drivechain 11-23 cassette and 53/39 chainring. I can adjust the rear derailleur to shift properly when in the large ring, but then it does not shift properly when in the small chainring. If I adjust it to shift properly when in the small chainring, then it won't shift to the smallest cog when in the large chainring. I mostly am in the large chainring, but it bugs me why the adjustment doesn't work for both chainrings.
hrdknox1 is offline
Old 07-15-19, 11:00 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Derailleur hanger out of alignment
Front DR needs adjusting
Bad chainline
trailangel is offline
Old 07-15-19, 12:06 PM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
Most likely a problem of derailleur hanger alignment.
Wilfred Laurier is offline
Old 07-15-19, 04:27 PM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
Internal cable routing? If the rear cable and front cable cross each other inside the frame, the front cable puts additional tension on the rear cable when the front is in the big ring. You can adjust it to work on either chainring, but it will never work correctly in both rings.
dsaul is online now
Old 07-15-19, 05:28 PM
hrdknox1
hrdknox1's Avatar
Quoted: 85 Post(s)
Yeah, that's gotta be it. I recently changed the front shifter cable and it may have crossed over the rear cable inside the frame. Thanks. I'll report back if that's not it.
hrdknox1 is offline
Old 07-16-19, 05:55 AM
ja6610
...any possibility of the b screw needing adjustment or a chain of incorrect length?
ja6610 is offline
bleumeon
Bicycle Mechanics
23
08-19-16 02:29 AM
cmcanulty
Bicycle Mechanics
8
05-14-16 03:40 AM
mzr
Bicycle Mechanics
7
09-24-15 10:46 AM
vatdim
Bicycle Mechanics
16
01-03-14 07:59 PM
Marto32
Road Cycling
5
04-16-12 11:32 PM
