General purpose gearing
Old 08-26-07, 09:46 AM
soloflyfisher
I'm thinking about building a general-purpose/commuting cycle starting with a gunnar crosshairs or lemond poprad frame. I'm now looking at gearing options. Ideally, I'd like something like a 46-36-24 crankset with an 11-27 cassette, preferably in 10 speed to get relatively close gear spacing over this wide range (24 to 113 gear inches). Does anyone know if any manufacturer makes a drivetrain like this? If not, can anyone suggest something with a similar gear range?
(PS: The closest I've found is the campy 53-42-30 triple with a 13 to 29 cassette--this gives a gear range of 28 to 110)
soloflyfisher is offline
Old 08-26-07, 10:25 AM
CHenry
Bikes: A bunch
You can get that front ring set with a Sugino XD touring crankset, the Shimano LX touring crankset or with a TA Specialties crank. RaceFace Turbine and Deus cranks also have that range.
The Shimano is dirt cheap at Nashbar right now. $39.
CHenry is offline
Old 08-26-07, 10:30 AM
CHenry
Bikes: A bunch
[QUOTE=CHenry;5147455]You can get that front ring set with a Sugino XD touring crankset, the Shimano LX touring crankset or with a TA Specialties crank. RaceFace Turbine and Deus cranks also have that range.
You will get the same range in nine speed as with ten, and have the advantage of using MTB cassettes if you decide to go for a lower low range. Nine speed road parts are cheaper and the nine speed chains are stronger.
CHenry is offline
Old 08-26-07, 10:47 AM
soloflyfisher
Thanks
Thanks for the tip. That Shimano is a great deal. I like 46/11 better than 48/12 or 48/11 for a top gear, but I think I can live with 48/12 and I like the option to get even lower gears on the bottom end.
Old 08-26-07, 03:11 PM
Steve B.
Quoted: 3221 Post(s)
Liked 2,043 Times in 1,169 Posts
Make sure the Sugino is 9/10 spd. compatable, as some are 8 only and can cause shifting issues if used with a 9/10 speed chain.
SB
Steve B. is offline
Old 08-26-07, 03:59 PM
ehsiung
Bikes: Jamis Aurora 2006
My Jamis Aurora came with a 52/42/30 crankset and 11-32 cassette, which gives me 25 - 126 gear inches. Pretty close to what you're looking for, though with a 9 spd.
ehsiung is offline
