Poor cantilever braking
I have a tour bike with tektro oryx cantilever brakes and brifter levers. The braking is very weak. There is some initial 'bite' which slows the bike but then when I increase pull on the levers the braking force effect doesn't increase as I would expect and it needs a lot of force to do so. The bike is second hand. The brake blocks are worn but still plenty of life left in them and they are adjusted to hit the rims nicely. Block are Jagwire.
I have replaced the cables but little improvement. From looking at Sheldon's site I think that the link cables are too long and this means that the mechanical advantage is low. At rest the link cable angle is less than 90 degrees and obviously under braking this reduces even further. see pic
Hence I am thinking of getting shorter link wires and seeing if that improves the braking. Is this the right thing to try or does anyone havee any other suggestions? I have also seen these tektro 'power hanger' gizmos that replace the link wire. They claim to increase power and don't need frame cable stops which would sort out a n awkward cable routing I have round the seatpost. However, I can't find any other mention of them on the net and I am thinking there must be some reason they didn't become commonplace. I also need to look and see if they could fit around my mudguards.
thanks
thanks
i agree with the regular straddle wire and the yoke,the unit not make to use the shimano unit.
I may have a yoke from an old centrepull brake so I will try that and lower the yoke and get the pads adjusted as close to the rims as possible and see if it helps.
thanks
thanks
