23mm vs 25mm tires
23mm vs 25mm tires
I just read an article that says 25mm tires are faster? Is this true? What are the other advantages of 25mm tires?
Thanks,
Thanks,
Bikes: '11 Fuji SL1 Pro
i have 25s
smoother ride. dunno about faster
also using 23 rims though.
Bikes: 02 Cervelo P2K, 07 Cervelo P2SL, 07 Cervelo Soloist, 09 Cervelo RS, 96 Quintana Roo Kilo, 80 Chicago Schwinn Letour, 12 Motobecane Nemesis, 97 Kona AA, 97 Cannondale f700
Quoted: 11 Post(s)
Liked 35 Times
I was always under the impression that, generally speaking, larger tires are more comfortable but slower. Under certain conditions, this may not be the case, but there's generally a tradeoff to everything.
In my own experience, as a relative newbie, the speed I give up is negligible, but the comfort is quite apparent.
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
25c with about 10 psi lower pressure than 23c is still fast (maybe even faster) and is more comfortable on rough roads.
It's been discussed many times.
Google: site:bikeforums.net 23 25 tires rolling resistance
For example, I linked to this chart in this thread. Rolling resistance is vertical, air pressure is horizontal.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Quoted: 973 Post(s)
Liked 511 Times
The "same old" questions can be tedious for long term members. It's hard for new members to do effective searches of old threads, so the same topics keep recurring. A tricky problem.
xkcd:
xkcd:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
eg. https://www.google.com/webhp?sourcei...bikeforums.net
Quoted: 41 Post(s)
Liked 9 Times
"I just read an article that says 25mm tires are faster? Is this true? What are the other advantages of 25mm tires?" ==
25 vs. 23 | Is Wider Really Faster? | Competitive Cyclist
Quoted: 539 Post(s)
Liked 44 Times
23mm vs 25mm - which is faster? is not a question that can be answered with just that info. Your weight is a big factor - a 25mm tire is faster than a 23mm tire for someone who's heavier without a doubt. The line between when 23mm would be faster based on weight - is debatable and is one I don't know about. But if you had a 240lb rider, they would be faster on a 25mm tire, all other things being properly adjusted.
18mm tires exist, but they're not used much, because they're to skinny and slower. Tires that are to fat are also slower. The fastest tire for you is one that's neither to wide nor to skinny.
Quoted: 2432 Post(s)
Liked 638 Times
"Faster" because you run them with lower pressure which allows the tire to conform to road irregularities more and bounce less. No you won't see a change in your average mph but they will make the ride a little more smooth. More or less depending on what kind of roads you ride. Us chipseal riders can tell a nice difference.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
There are only 4-5 guys in the entire world that ride the Tour De France to win de Maillot Jean. Of those 4-5 guys, you are probably right, they don't ride 25mm tires, but the rest of the Tour Riders seem to ride 25mm (from everything I have read that seems to be the case).
I myself won't try 25mm tires as long as all of these 23mm tires on clearance are around Very hard to find 25mm race tires marked down as low as 23mm.
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
The tires I have made for my son to race on are 25s. The tires he trains on are 23s thicker rubber tougher. I bought some 27s this year but they barely clear the Tarmac. They are heavier. He is using 25mm HED rims for racing so even 24s look too narrow. I think he will do some riding on 24s and also the 25s this year.
Bikes: Fuji roubaix 1.1
Quoted: 20 Post(s)
Definitely faster less rolling resistance lower tire pressure equals to a more supple ride, bouncy in a good way,, supposedly more aero.. i ve tried 23mm tire once and i hated it. i have a pair of boyd altamontes which are 24mm wide so 25 mm tires are a good match for them.
Liked 371 Times
These are 27.5 300g - really light for the size
Going with these - sometimes. Measure 24.5 (they are size 25). They should be very low RR...but not tested.
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
It the most recent issue of Cyclist magazine, they did a comprehensive test of tire width and psi. 25mm tires at 85psi roll faster than 23 at 110psi. I am greatly simplifying their results, but if you want to get all of the information, read their article.
Liked 638 Times
Pretty much every single tire I see on sale is the same price for every size it comes in. I don't recall ever seeing a tire that has the 23 size on sale but not the 25.
