Calculate FTP on a Max effort over an hour.
I have never done an official 20-minute FTP test, I've only had it calculated form 20-minute efforts while climbing Alpe du Zwift.
I have however done the Mt. Washington Auto Road Bicycle Hillclimb Race, and been completely wiped out at the finish.
This took aver an hour, and because the route is 7.4 miles at an average 12%, with no flat or recovery areas (it's pretty steady, some sections hit 18%, the lowest grade is 6-8%), it requires a steady effort.
I have my average & normalized power numbers (both very close) for the race, (263w/268w) & 20-min max (284w), my time was 1:12:22. My FTP at the time was 277w (from 20 minutes of a hard Zwift rode, 95% of 292w).
Is there a way to calculate my FTP on my Mt. Washington ride?
Thanks
Thanks
Quoted: 20808 Post(s)
Liked 9,450 Times
What are you going to do with it?
Base my training zones on the number.
I used my FTP to train for Mt. Washington, and took almost 5 minutes off my previous time.
On that previous time, I had used my previous FTP for training.
Also, very few people actually have their FTP based on a 60-minute effort.
I had one of 72 minutes.
See where I'm going with this?
Thanks
Thanks
Quoted: 3943 Post(s)
Liked 7,284 Times
Why don't you just use your 1 hr power from Mt. Washington?
Likes For tomato coupe:
My maximum one hour during the race wasn't the max that I could put out in just an hour, if it had been I wouldn't have finished.
But I was completely spent at the end of the race, I had absolutely nothing left.
So my one-hour max power has to be more than my race average power.
Thanks
Thanks
Liked 7,284 Times
I'd say you're splitting hairs. Pick a number between 263 W and 277 W -- it's not going to make much difference.
Quoted: 347 Post(s)
Liked 418 Times
72:22 is likely very close to one hour, you could just take 268W as your FTP since the personal power curve usually degrades slowly in the 1-3h range.
You could try interpolation since you have two data points: (292-263)/(20-72.37) = -0.554 and then (292+(slope*40)) = 270W. Not 100% exact since the total power curve it not linear and the ‘real’ FTP might be 1-2 watts lower than this as the real curve drops away in some power function.
I kind of expect the true FTP (power you can make in one hour) to be slightly less than the 20min*95% RoT number because the 20min effort include too much anaerobic effort as a percentage of the test IMO.
Quoted: 18883 Post(s)
Liked 10,646 Times
Anything short of a perfectly paced 60 minute effort is going to be an estimate, and the numbers you have are very close. If the intervals are too hard or easy, adjust.
Likes For Seattle Forrest:
Quoted: 942 Post(s)
Liked 526 Times
Re: indoor FTP test: unless you are using your power meter (not trainer power), I would not put a lot of stock in your indoor FTP as far as accuracy.
That’s how I do it, outside as well. I have found that 20 min tests tend to overestimate FTP for people who do not have the gas tank to go all out for an hour. It sounds like you have that conditioning, so 95% of your 20 min power is going to be fairly accurate.
Thanks
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
Just take an actual 60 minute FTP test. They’re much easier than 20 minute or 8 minute or ramp tests. Plus it’s your actual number.
Or just do a bunch of VO2 Max workouts and game the system via a Ramp Test. That way your fragile ego can remain solidly delusional.
See here;
https://www.trainingpeaks.com/blog/t...ing-protocols/
I made a couple of Kolies tests in Training Peaks. Best test of fitness by far.
Get your number the right way. Set your zones correctly.
Good luck.
See here;
Good luck.
Quoted: 1814 Post(s)
Liked 923 Times
See here;
Good luck.
See here;
Good luck.
Likes For woodcraft:
Liked 7,284 Times
I use my Favero Assima pedals for all of my power measurements, and use them to control my Kickr. This way I have apples to apples power comparisons from my trainer to my outdoor rides. I had figured that my 60-minute would be a little higher than my 112 minute, since after 60 minutes I still had something left, enough to finish the race strong. I'll take a 20-minute test sometime soon.
The 95% of 20-min rule is only an approximation to begin with, as it assumes everyone's power curve flattens in the same way. As per Training Peaks, it is a good estimate of FTP for about 50-60% of riders. It doesn't work for many riders, myself included. (My curve flattens quickly, and my 60-min power is 98% of my 20-min power.)
pan y agua
Quoted: 1442 Post(s)
Liked 711 Times
Your average power on Mt Washington is likely very close. You could argue its low, given the effort was a bit over an hour. On the other hand ftp climbing is typically a bit higher than calculated on a flat
effort.
I’d say those two effects pretty much offset.
On a practical note, set your zones off 263. If that proves too easy, up it.
effort.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Your FTP is 267W.
I’m guessing you were climbing out of the saddle for at least a little bit on Mt. Washington, and in a normal FTP test being out of the saddle is shunned.
Additionally, the wattage difference in workouts between FTP’s at 263W and 270W is negligible, and you probably won’t be to hold a steady-enough power to know the difference anyways.
Likes For Cypress:
Quoted: 741 Post(s)
Liked 412 Times
I agree with the set and adjust as needed approach. You will know if it feels too low. It isn’t an exact science as a person’s numbers can vary due to the long list of variables that effect performance.
Quoted: 1975 Post(s)
Liked 232 Times
FTP is not exactly an hour, coggan has always maintained it is about an hour. Time to exhaustion is 30-70 mins depending on your training level https://www.trainingpeaks.com/blog/t...ing-protocols/
