Added weight of rear rack and panniers
Quoted: 11 Post(s)
Liked 6 Times
I have recently added a rear rack and panniers on my hybrid commuting bike for groceries and stuff. Just 1 ride, I do not like the heavy feel at the back. They added about 2kg, with groceries perhaps 10kg. My main concern is the rear wheel as Its only 24 spokes. I'm worried the weight will be too much that the spokes and also tire will fail and wear at a faster rate. I don't use it everyday, perhaps twice a week and the distance from market to home is roughly 4km. Or is that all fine and I'm thinking too much?
Galveston County Texas
Bikes: 2010 Catrike Expedition, 02 GTO, 2011 Magnum
Quoted: 856 Post(s)
Liked 272 Times
Do you have some pics or a LINK to the bike?
Fred "The Real Fred"
Quoted: 11 Post(s)
Liked 6 Times
I can't right now. But I can give some details. It's a Giant CRX, as below. The the wheels have been changed to HED ardennes LT 18/24h. The rack and panniers are from decathlon.
https://www.productreview.com.au/listings/giant-crx1
I tend to think the added weight is just a small fraction of what you and the rest of the bike weigh already. In other words, it'll be fine.
Quoted: 856 Post(s)
Liked 272 Times
You Have A.
"A light weight bike that is best used for around the city and leisurely rides."
Likes For 10 Wheels:
Bikes: Schwinn Varsity
Quoted: 1713 Post(s)
Liked 433 Times
Those HED wheels have a weight limit of 225 lbs. 22 for the bike. 23 for your rack and groceries. That leaves 185 lbs for you. Cutting it close?
Likes For mr_pedro:
Quoted: 2184 Post(s)
Liked 545 Times
Having only 24 spokes might be of some concern. However cross country cyclist put very heavy loads on their rear wheels, and have no problem.
Quoted: 378 Post(s)
Liked 221 Times
The HED Ardennes is a great wheelset that can withstand a lot of abuse, but 18/24 spoke count is aimed at saving weight, which reduces the wheel's strength. If you'r total load is under 225lbs, it's probably fine, but you're definitely at a higher risk for breaking spokes.
YMMV
YMMV
Likes For msu2001la:
Sunshine
Quoted: 4856 Post(s)
Liked 2,081 Times
You could look into moving the weight up front with a front rack(and use the same bags). That may help- you have to balance the weight, but when done properly, it can reduce the heavy feeling. It also slows down your steering.
Your wheels arent intended for heavy weight use, but if you are light enough, its fine.
I personally wouldnt get low spoke wheels for a commuter, but im not a featherweight.
Likes For mstateglfr:
Quoted: 2162 Post(s)
Liked 2,723 Times
You cant really get rid of the heavy feel when you are carrying 20-25# of groceries in 2 bags. Thats a lot of weight, so its normal for the bike to feel heavy.
Another idea: add a front rack (or even a basket) and move some (not all) of the cargo up there. That will not only spread out the load and perhaps help with the bike handling, but it will take some of the strain off your rear wheel.
But, as others have suggested, you don't have the right wheelset for this kind of use. When fully loaded, ride gently.
Quoted: 338 Post(s)
Liked 649 Times
Pop any spokes? Raise yourself off the saddle when going over rough spots.
Quoted: 12494 Post(s)
Liked 4,599 Times
Get a beater/second bike with stronger wheels for shopping/errands.
Quoted: 11 Post(s)
Liked 6 Times
Yeah. I'm very close to the weight limit with all that. I have thought of getting front rack too and ride slower with load. I wonder if having larger tires could help to relief the stress. The bike allows for 38mm tires and I'm running on 25
Sunshine
Liked 2,081 Times
yeah...there is really just no benefit to running 25s for commuting/errands if quality 35/37/38mm tires can fit.
Quoted: 296 Post(s)
Liked 140 Times
My fat bike wheels are stronger than the wheels of many other bikes. It's probably because the tires absorb bumps better, and spread the forces out. Some may want to get a fat bike for carrying heavy loads.
aka Phil Jungels
Clark W. Griswold
Quoted: 2001 Post(s)
Liked 906 Times
I would run wider tires regardless of anything at least up to a point. In terms of your loads it seems like you are running some lightweight wheels not designed for load hauling. You might want some stouter wheels. At least 28 spokes handbuilt (because really all wheels should be handbuilt and tensioned) with quality components. You could add other racks but it doesn't seem like the bike is designed well for racks it looks like a flat bar road bike which is great for riding but hauling groceries and errands not so much. You don't need a super heavy duty bike to do it but something a little better for carrying front and rear loads could be handy. Typically front load carrying bikes will have what is called a "low trail fork" which is common on randoneurring bikes and might be just the ticket for you. You can build up a nice fairly light rando bike that can still handle some loads.
For probably the nicest rando bike out there:https://theradavist.com/2018/02/2018...es-randonneur/
If I am not mistaken, HED wheels are generally intended for racing. It is possible or likely that an extra 10kg of dead weight over the rear wheel will significantly reduce its life. Bikes designed for carrying cargo or touring generally have aluminum rims with higher spoke counts.
Liked 433 Times
I believe the weight limit is for the wheelset.
Larger tires would be good... and "ride light"... some riders know how to do this.
