Shifting Into the Small Ring
Bikes: Trek Domane SL 5
Quoted: 201 Post(s)
Liked 98 Times
So when I shift into the small ring in a climb, it's such a drastic change that I spin my legs like an idiot while I shift the RD back into a harder gear.
Is there a better technique to this? When I shift into the big ring, I simultaneously shift the RD 3 times and by the time it takes for the FD to get the chain on the big ring, I'm comfortably in a gear on the RD that makes it all a smooth transition.... Shifting in to the small ring... not so much; the change from the big ring to the small ring happens so fast that I don't have time to make the change on the RD (without stressing the gears by shifting under power).
To make matters worse, it's usually when climbing up a hill and I lose some amount of momentum doing it.
Any tips on shifting to the small ring efficiently for a climb?
Likes For trailangel:
Quoted: 15271 Post(s)
Liked 4,143 Times
Shift to the little ring before you need it. Remember that there's a lot of overlap between the two chainrings and that you should be able to comfortably cruise in the granny ring at 18-20mph without cross-chaining.
*don't know if this is possible with Shimano cable-actuated drivetrains. I run Campagnolo 10sp, which allows me to dump up to 5 gears, or to upshift 3, at one time. I also have a relatively narrow chainring difference (39/51) which helps
Likes For Litespud:
+1. About half the time, you can shift the front once or twice and stay on the same gear in back till the climb is over. Then go right back to where you were.
Bikes: SuperSix Evo | Revolt
Quoted: 648 Post(s)
Liked 652 Times
Are you shifting them simultaneously? Because that's what I usually do and I've never had problems with spinning. I can dump three gears on the back with three quick clicks of the shifter, though I do ease up on the pedal for a fraction of a second to allow for this to happen smoothly. During this split second my legs are spinning at the rate that I think I ought to be in once the gears engage, and once they do engage you are right there. Sounds like a lot, but it's really only a fraction of a second for it to happen. It does take some practice. It doesn't matter if it's 53/39, 52/36, 50/34, 46/36, 50/39/28...I have all of these.
Likes For mcours2006:
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 2455 Post(s)
Liked 1,450 Times
Di2
Quoted: 201 Post(s)
Liked 98 Times
... maybe I'll spin up while in the big ring, shift two clicks harder on the RD and then dump into the small ring while I click another couple in the RD. Either way, I'm sure there is a more efficient way of doing it than what I'm currently doing.
It's different from shifting to the big ring, because the shift to the big ring takes longer vs. the small ring just drops in.
I think with my 105 setup, I can do multiple changes with one sweep of the big handle, but for the clicks, they are individual.
Does Di2 help with this? (I only ask because I'm considering getting a Di2 upgrade for my 40th birthday).
Likes For Metallifan33:
Di2 has a couple of options that take care of this issue:
You can choose to automatically shift the back up or down when you switch the front up or down.
Or, my favorite mode is to let the front shift automatically when the back gets to close to either side AND then adjust the back at the same time.
With this last mode it is possible to go through all gears with just one shifter, you only have to say if you want it lighter or heavier. It can be fully programmed at which point the front shifts. The other shifter can then be programmed to command the garmin device.
Likes For mr_pedro:
Klaatu..Verata..Necktie?
Bikes: Canyon Endurace, 105; Battaglin MAX, Chorus; Bianchi 928 Veloce; Ritchey Road Logic, Dura Ace
Quoted: 1623 Post(s)
Liked 1,494 Times
1) shift before the climb, when you're going faster and you can allow some slack
2) Determine how big the gap is. For example, on my 53/39 bikes the gap between big and small rings equals 2 cogs. On the 52/36 and 50/34 it's 3.
3) slacken up slightly on the pedals and shift the right number of cogs, THEN shift the front. Should take about 1 second all told.
I have tried shifting simultaneously and it works 95% of the time. The other 5% the chain drops. So I try not to shift simultaneously anymore. This can be exacerbated by the chain being in need of cleaning and relubing. I don't mean really dirty, just about the time you'd normally clean it.
The key is not having to shift under pressure on the pedals.
Likes For genejockey:
I feel like this issue is the area where Campagnolo has the advantage over Shimano. with Shimano, you need to press and release the small lever 3 times to go 3 gears harder on the RD. this makes for at best, a clunky transition from big to small chain ring. Campagnolo allows a single sweep of one lever to change 3-5 gears in one press, making the simultaneous shift work very well. it was so easy to do naturally, I even taught my wife the fine art and she mastered it quickly!(I also don't like that fact that the shift lever is the brake lever for Shimano, but that is another issue.) I recently left Campagnolo for Shimano, but only for DI2, since EPS is WAY more $$ than I cold spare.
Likes For mgopack42:
Liked 1,450 Times
Personally, I didn't see much point to DI2 until I got a bike with it. It rocks for lots of reasons, and this is one of them. More generally switching chain rings is much easier and I do it much more often with DI2. On my old bikes, I'd always wear out my big chain ring several times and basically never need to replace the small chain ring. On the new bike, the wear is going to be more even (though of course, I still use the big chain ring more - I live in the midwest, not in the mountains).
Likes For MinnMan:
Hits [ENTER] b4 thinking
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 2145 Post(s)
Liked 885 Times
I was shifting my 105 5800 both front and back at virtually the same time when dropping to the small front. It handled it beautifully, IMO. Frequently it took two sometimes three smaller cogs in the back to achieve the correct ratio for my cadence.
Since in both cases front and back you are going to a smaller cog, you don't have to let up on the power quite as much as when shiftting to bigger cogs. At least I didn't think I did.
That bike has an 11-32 with 52/36.
Quoted: 201 Post(s)
Liked 98 Times
Bikes: Trek Domane SLR 7, Trek ALR 6, Trek CrossRip, Trek X-Caliber 8
Quoted: 89 Post(s)
Liked 181 Times
Yep, it shift both mechs and it eliminates the cross chaining....it's really nice. It is also very quick. You can also set where you want it to shift....pretty sweet setup.
Likes For jaxgtr:
If you need a bigger shift you can also keep the button depressed and let it shift all the way up or down.
I used semi-synchro with Di2. Original was 2 cogs in back in opposite direction from front chain ring shift. After some experience I changed it to 1 cog in back along with front shift. It works for me.
Liked 1,450 Times
Likes For MinnMan:
Likes For spelger:
Quoted: 122 Post(s)
Liked 296 Times
You said the word, TRANSITION.
I read an article years ago that mentioned TRANSITION cogs. If in the big ring switching to the small ring, the transition cogs would be 2 or 3 before you get to the inside of the cogs.
If going small to big, the transitions cogs would be 2 or 3 before getting to the outside of the cogs.
In short, about 3 cogs in the direction you are planning to shift.
I use this every freaking time I ride and it makes my shifts smooth. Also helps from dropping the chain as well. Though if adjusted properly, the chain should not drop but this helps make it smoother and even if my limit screws were not adjusted properly, it would still keep it from dropping with the drastic change. But in the end, smoother shifting, just plan a head a few seconds. After some practice, it's a natural feeling and shift of gears.
