Lugged MTB - headtube replacement
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
So unfortunately I have cracked the headtube on my beloved 1984 Trek 850. I'm of the understanding that this is something that can be repaired/replaced.
I'd like to know if anyone may be able to share what a frame repair like this might cost? (excluding paint).
Also, I'd like to know if anyone has any insight on what might have led to this failure, and if it would be something inevitable to happen again? Or as a friend suggested, is it just possible there was too much heat in the original brazing of the frame?
Quoted: 103 Post(s)
Liked 144 Times
I'd guess $50-100 would be typical. It's one of the easier repairs. Cut as much away as you can and then grind the existing tube out of the lugs so that a new HT will slide in and then use silver to braze it in. They should then ream it to spec. It's probably an hour worth of work.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Likes For duanedr:
I'm curious now if any of the Trek mountain bikes had the one piece headtube/lug construction like some of the road frames. That does look like it started right at that joint, in the one piece headtubes that would not be a joint at all.
Edit: Seems maybe this is a cast one piece unit and the fake lug edge can cause a stress riser?
Quoted: 1248 Post(s)
Liked 1,323 Times
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
Also I'm assuming that may make this way less feasible to repair?
Quoted: 1400 Post(s)
Liked 1,883 Times
not what you want to hear - but consider a search for a replacement frame
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
Oh no!
Have you been riding off road? I've been wondering if 531 is not the best choice for MTB. Love that bike and hope you can get it fixed reasonably.
Good luck.
Good luck.
Last new bike 1991
Last new bike 1991
framebuilder
Likes For Doug Fattic:
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
I had already started seeking another as I wanted something built up close to original, and one built as pictured below with 700c!
Unfortunately, with this being such a short lived style of mountain bike in a very odd size, I'm not ruling out repair as a feasible option.
Absolutely have been riding this bike everywhere, and I have no regrets! Technically it's 531 all terrain so the tubing is pretty oversized, and the 531 isn't what failed! It's honestly one of the best steel frames that I've ever ridden. Way more responsive that it looks, but you wouldn't mistake it for stiff either.
Thank you Doug, I really appreciate the visual, that is exactly what I have.
it is easy to tell if it is a one piece head tube/lugs. If you look into (inside) the head tube and see big holes into the top and down tube then you know it is a one piece unit. If there are no holes, then it is a a standard head tube joined to a couple of lugs. These all-in-one units were made by Nikko in Japan. They are bulged formed. I used them when we made the 1st 50 sets of transportation frames in Bucha, Ukraine. Here is a picture of the lug unit and another picture of one of our transportation frames using one of those units.
Likes For theblackbullet:
framebuilder
framebuilder
Oops, the one piece head tube/lugs that I have were for Miele road frames and as a result have 1" top lug sockets and 1 1/8" down tube sockets. I just measured one of those and it is around 212mm long. I'm assuming your Trek has standard oversize tubes? is you steerer 1" or is it larger?
It isn't impossible to repair your frame by removing the lug unit (after cutting it into 2 pieces) and replacing them with real lugs. Of course this depends on the geometry of your frame. I also have a large assortment of odd lugs that might or might not work. Also it might be possible to braze an internal sleeve inside your broken head tube. That would probably require turning some stock thick tubing down on a lathe to fit the ID of the head tube and still leave room for the steerer. Of course all this work comes at a cost even before it is repainted. Yours is a pretty big MTB so there might not be many of those still around but if there is, the price is likely to be much less than a repair by a competent builder. Whether you want to explore getting yours repaired is going to be primarily based on its sentimental value to you. If you loved the frame/bike and want to make it like new again then whatever it costs is wroth it.
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
I think a repair is still my most favorable option. There aren't many of these out there. I was looking for a second to leave built up closer to original already before I broke this one! Also, if I were to find another Trek the same as this one, it would have the same headtube that is prone to failure. If I were to replace this headtube with something stronger rather it be lugged or fillet brazed, I would have an improvement over the original design! I understand the repair will cost more than the value of the frame, but I have no plans to sell this frame down the road. It's been my most ridden frame since I picked it up this summer.
I have already reached out to a couple of framebuilders here in Georgia. One is no longer taking on repair work, and the other seems to discourage trying to repair the frame, so I'm not sure they really want to take on the work. They did say it would be in the range of $3-500. If I could stay closer to or under the $300 price point, I think it's a no brainer to try and get this back together.
Randomhead
Liked 3,699 Times
Did they even bother to miter those tubes though? It would be a different bike after repair if they didn't. But the way that the lugs are so long onto the top and down tubes makes me believe they just cut them square.
I built a 531 frame back in the '70s and I like it more than I think I should. There is a lot better tubing available nowadays, but if some 531 fell into my hands for a decent price I would probably build another one. I don't see anything wrong with a 531 mountain bike. And of course, the 531 didn't break on the OP's bike anyway
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
Top tube is 28.6mm down tube 31.8mm. The frame takes a 1" steerer.
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
https://www.bikeforums.net/classic-v...k-600-a-3.html This thread goes into some detail about the headtube replacement on a Trek road frame.
Here's how mine look.
I've had a few 853 road frames and love them, but this bike with 531 is just perfect. Of course, the 485mm chainstays may be deserving of the credit for the smooth ride.
doh! good call!
framebuilder
I see this as a challenging repair. The easiest thing to do would be to fillet braze it. The problem is that the miters are going to be off so without redoing the miters, that will weaken the joint. Because the tubes are already in the frame, that makes it difficult to hand miter each end somehow so a head tube will fit flush against both tubes and at the right angle. Of course just a little length will be lost but that won't matter. I'm doubtful there are some old lugs available somewhere that are close to the right angle. Very few lugs were ever used on mountain bikes. If you could discover the angle of the down tube to head tube, I could check my stash of old lugs. Every frame builder has his own methods of doing something and working to different standards. The way I would repair this Trek would not resemble the method used on the thread you posted about a head tube repair of a one piece head tube/lugs. Of course I am not in the running to repair yours because I don't have time with my teaching schedule.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
Old fart
Liked 3,401 Times
Old fart
Liked 3,401 Times
Old fart
Liked 3,401 Times
Quoted: 714 Post(s)
Liked 800 Times
If this were mine, there are two possible repairs I would make. The ugly option would be to fixture the head tube back into place, clean it up and TIG weld the head tube back together. The less ugly option would be to leave the lug portions that are on the top and down tubes and grind/file away everything else. Then clean up the miters and fillet braze to a new head tube.
Quoted: 103 Post(s)
Liked 144 Times
Quoted: 103 Post(s)
Liked 144 Times
