OK, back to this Speedplay thing again
I just can't decide between the Zero and Light Action pedals
I do like the idea of adjustable float... I don't know if I need a full 15 degrees. Maybe I don't need any.
So the adjustibility almost sways me to the Zero
Except I heard that the Zero is harder to click in and click out of (hence the Light Action pedal)
What is "harder", exactly. I mean, how hard is hard.
I'm used to SPDs, which aren't tightened down very much -just enough- and they still take a pretty good "kick out" with the heel to get out of.
So is this a concern? What would I be more used to?
The key for Speedplays is to follow the writtn directions when mounting the cleats. If you tighten the screws that hold the cleats too tight, they can be stiff on the release. As with many cleats, the specific motion that best releases the cleat will vary slightly. However, I've never had any problem releasing my feet from the pedals with Speedplays.
Version 7.0
Bikes: Too Many
Quoted: 1341 Post(s)
Liked 2,483 Times
I will give you the race weenie answer...Light Action is for wussy.
I ride SPD SL but many of my buddies ride Speedplays. Do not over analyze this. I think the light action is marketing designed to get reluctant recreational cyclists to try clipless. I would ask your LBS, who buys Light Action pedals or who is the target market?
Climbing Above It All
When I first went to clipless, Look style, many years ago, I wanted the release on the pedals set as light as possible. However, I quickly wished for the security of a tighter tension. Now I pretty much ride them as tight as they can go (Look Keos). I'm more wary of pulling out of a pedal on a sprint than not clipping out and falling over. Clipping out is second nature.
I switched to X2 from eggbeaters. I went to the LBS to look at the Light Action and they talked me out of it. They are definitely intended for newbies curious about clipless. My LBS guy said that they steer newbies toward adjustable tension SPD type, so they really don't sell many Light Actions - unless they come in specifically looking for them.
Since I had been riding clipless for 3 years, the LBS guy talked me out of it. He said that my best choices would be the X series or the Zero's. I don't race but I put in 5000 to 7000 miles a year and I sometimes push hard.
I haven't found the X2 to be hard to enter and exit. In fact, I find them easier than the eggbeaters. As someone else said follow the installation instructions: get the 4 screws snug, then turn a quarter of a turn. Dip in blue locktite, to make sure they don't come loose. (They come pre-dipped for first time installation.)
I absolutely love the float! The non centering, free float sensation is liberating. The zero's are basically the same except that you can control the float. I didn't go with that because I didn't want to go anal about the adjustment - something I would definitely have done.
Bikes: Cannondale T800
Speedplay vs Look Keo vs SPD
Hi all:
I am going thru the exact same things that you are all speaking about ... I originally have used the SPD clips for 5+ years and last year went to the Keo's. I really dont like the Keo and was looking to go to the Speedplay Zero or X/1. I do like the play and float of the Keo but have a hard time in getting clipped back into the cleat ... the angle at rest faces back at me and requires thought and careful movement to get in on the correct side of the pedal and I often end up trying to clip into the wrong side. That part makes me crazy when trying to take off from a stop light and I have "almost" fallen over multiple times. I am looking to go to the Speedplay as there is no Top or Bottom and can be clipped into either side. I think that I will go for the zero due to the adjustability and limiting of the float if I want it. Please note that I am also a Clydesdale ... 6'4" and 270 lb. My local bike shop owner just attended a conference where she learned to do the speedplay adjusments and says that it takes about an hour plus to get them set up properly. Looking forward to doing it very soon.
Michael
Michael
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,846 Times
An hour for the bikeshop to set up a pedal / cleat system? If this is true, I'd avoid Speedplays.
Speedplay adjustments
I understand what you are saying ... but I dream about a more efficient stroke and transfer of maximum power to the pedals and also to accomodate my bad knees for the most efficient riding positions ... maybe I am dreaming ... but hopeful that this will add to my efficiency, ride comfort, and power transfer?!
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Michael
Michael
Gravity holds the unladen pedal in the correct position for clipping in easily. The front loop will always point up. Simply slide your foot forward so the front of the cleat catches that loop and rotates the pedal to horizontal. Then add weight to the pedal and the rear will click right in.
I'm not arguing the Look vs. Speedplay point. Both are good pedals. But if you already have Looks, I would suggest just learning the right way to step into the pedal.
Thanks for the reply ... but I know how to do it properly and it works 7 to 8 times out of 10 but sometimes it just dosent as the angle of the resting position is not vertical by back by about 20 degrees off of vertical towards the rear ... if they would stay vertical then it would be easier for me. I guess that I am just a bit of a "****"?!? I have been using them for 8 months now and have gotten better of course but still not perfect.
Rides again
Bikes: Giant OCR T, Trek SC
I switched from SPD to X speedplays. Much easier on the legs. It doesn't take long to set up. Just takes time to read the directions. All you need to do is make sure the cleat platform doesn't flex, and they include a ton of shims to solve the problem for you. Then just screw in 7 screws/shoe. The only catch is to make sure you put a good glob of blue locktight on the 4 bottom screws, so they don't come off when riding. Speedplay support is great. If you do lose screws, they will
send you new ones.
As far as unclipping, there's just a tad more twist needed, because of that flow. But if you adjusted to SPD's from non clipless, you can easily make this adjustment. It may take about 3 times, and you've got it.
I don't know what the advantage would be to dial in float. With the speedplays, it just feels natural instead of being locked into a track position.
send you new ones.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Version 7.0
Bikes: Too Many
Liked 2,483 Times
Whichever pedal and cleat system you get, get a Kool Cover for walking around. This is especially true for Speedplay where the mechanism is in the cleat. https://www.koolkovers.us/
The guy in the 50+ jersey
Bikes: Specialized S-Works Roubaix, Litespeed Tuscany Road, Specialized Allez Epic lugged carbon frame Road,Giant Anthem 29'r, Klein Hardtail
+1 on Speedplays. Have used Zeros for 5yrs. , Frogs on my mountain bike as long. Efficient, EASY to learn (just practice), "no-look" clip in, pedal always in the right position to clip in. Agree with Hermes on the cleat cover, eliminate the chance you damage the cleat and / or slip.
Rides again
I don't know about kool cover, I just went to LBS and got some X cleat covers. About the same price, so I'd rather support LBS
Doc
Bikes: Trek Madone, Rans Velocity Squared
I have had the speed play Xs for about six weeks and really like them. they have helped my knees a lot. I really like the float. I bought from bike shop and they placed on the shoe in no time flat. I did have to make a slight lateral adjustment on one shoe to a different position because of some knee discomfort.
Getting out takes a bit of getting used to but it is more mental than physical, but in no time I feel comfortable with this.
The covers for the speedplays here are called "coffee cans", and they are great for walking on dirt roads and slide on and off nicely. No problem walking with the coffee cans on.
Billy
Billy
Bikes: Schwinn, Kestrel, Guerciotti, Ross ,50th anniv. Paramount ( 2 )
Ive been on speedplay pedals for more than 12 years, first pair was second hand, chrome plated spindles, solid alum. pedal pad, cleats were huge , they were great ! in compairson to everything else, made my knees very happy, and the newer ones just keep getting better !
Jim's bikes here..Thanks...Jim
Bikes: Giant OCR2, Motobecane Fantom Trail, Specialized Hard Rock, Giant Nutra
Update: OK, it was a real bear but I pulled off the M520s I had on the Giant and put my trusty ol' A520s on. I have ordered a pair of Speedplay Zeros. We'll see where this all ends up
dEaDtOtHeCoRe=o)
Location: ...where the sky is yellow and the sun is blue...
Bikes: debernardi road / specialized epic mtn
my bad
i took the intrusion out please continue on.
peace b.
peace b.
