Drops or hoods? Can't have both, it seems
I can't seem to get comfortable in both the drops and the hoods using a given bar angle. The drops are too much of a stretch but the hoods feel great when the angle is horizontal like this:
When I rotate the bars down the drops feel perfect, but the hoods feel like too much of a stretch:
I can't find a happy medium where it feels good both in the drops and on the hoods. Does anyone else have this problem? I don't race, and I'm on the hoods/tops about 90% of the time on my rides, but I'd like to increase my time in the drops.
Is this a fit issue? I've always been very unflexible my whole life, and am currently about 30 pounds overweight. Would my reach improve by losing more weight?
Just out of curiousity, which of the bar angles in the following photos would you find more suitable if you were setting this bike up for yourself? (I know, I know, we're all different, etc...I'm just curious).
A.
B.
A.
B.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
get new bars?
deda anatomic is designed for campy style to give a flat top without compromising the drops.
https://www.bikeforums.net/showthread.php?t=412472
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
A Little Bent
Location: Struggling up a hillside in Vermont, USA... ..........................................
Compact bars for you sir...
Bikes: KHS steel SS
A shorter stem might bring the drops closer to you, eliminating the need to rotate the bars down. When you rotate the bars down, it moves the drops closer, but it moves the hoods away, and increasesthe angle of your wrists needed to use the hoods.
Bikes: KHS steel SS
175mm crank of love
Windsor, Ontario is a great place... drinking age is 18 years, smoke is "legal", gambling is legal, short term compensated love affairs are legal. Makes for a festive environment with an interesting crowd. They have great ethnic restaurants too and a good public support system...no homeless people. I studied alot at the U of W library.
100% USDA certified
Liked 6 Times
Frame geometry is the problem, not just the bars.. given your situation a compact frame design w/ more upright geometry, a taller headtube and less saddle-to-bar drop may be a good idea. Think along the lines of Specialized Sequoia/Roubaix, Trek Pilot, etc.. there's many out there.
Bikes: Colnago Dream, Kestrel Evoke, Giant XTC Hardtail
Yep, New bars and relocate the shifters. I use hoods and drops about 50%-50% and the drops are actually less of a reach then the hoods.
Frame geometry? Shorter stem? Here's what I would try, since it costs you nothing: loosen stem bolt. Raise handlebars ~1 inch. Enjoy! I would put money on your problem being too much saddle to bar drop, possibly with a stem that is too long. Raising bars will bring them closer. If that's not enough, very yes on the shorter stem, PLUS raising the bars to about the height of the saddle. You don't need the amount of drop you have going on, there.
Thanks for all the replies. That's a 90 mm stem I've got on there, which is an improvement over the 120 mm stem that came on the bike when I bought it. I will certainly raise the bars a bit, that should help.
When suggesting new bars, what kind of bars do you mean precisely, and how would that help? Traditional round bars would be even more of a reach in the drops, wouldn't they?
not revenge...punishment
Jet Jockey
I have FSA Omega compact bars. Best money I've spent next to a Brooks saddle. Those bars have changed my ride, and eliminated every bit of hand position discomfort I've ever had.
Love them.
Love them.
Good night...and good luck
