Where can I get a Hayes HFX9 bleed fitting
I my front brake needed bleeding after I came off my bike I have managed to pressure bleed it with castrol response dot 4 and my gunson easibleed I usually use on my car, is it possible to get the bleed fitting that plugs into the master cylinder separately so next time fluid doesn't go everywhere
is slower than you
Bikes: Gunnar Sport, Marin Pine Mountain, Gunnar Ruffian, Gunnar Roadie, BMC Fourstroke, Salsa Vaya
You could try your local bike shop. Otherwise, JensonUSA.com and CambriaBike.com both carry a variety of disc brake parts.
Proud supporter of the Chippewa Off-Road Bike Association (CORBA)
www.chippewaoffroad.org
The bike shops I've tried round here (Teesside, England) are useless, if it ain't Raleigh or Shimano they cant do it that's why I used my pressure bleeder, its improved it but there's still air in there think it will work better with a pipe on the outlet.
