Looooong grips for butterfly bars? Or padded tape?
I used Fizik Microtek tape on the butterfly bars I put on my Trek 620. The tape looks pretty nice, but after a longish ride today I realized that I missed the padding that I have on my other bike. My commuter bike has foam grips rather than handlebar tape.
Does anyone know of really long (31cm) foam grips?
Or can you recommend a padded bar tape?
Thanks!
Thanks!
- Jeneralist
- Jeneralist
Bikes: Nature Boy 853 Disc, Pugsley SS
Quoted: 251 Post(s)
Liked 8 Times
Your hand has two muscular spots at the base of your palm, with a ridge n between. Foam padding will initially feel more comfortable than tape and gloves, but if you use foam padding, it redistributes pressure to the ridge between the muscles, causing hand pain over the long-term and potentially causing carpal tunnel.
It's safer and probably more effective to use not-so-padded tape and gloves with gel pads on those muscles, rather than swath your hands in foam.
Same concept in seats!
- Jeneralist
- Jeneralist
I have 2 layers of gel/cork-foam tape on mine..
ups the diameter for more surface under my hand.
Most of the long sleeves I've seen,
like Pyramid (most common),
are too soft..
are too soft..
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I use regular cloth tape and cycling gloves, been doing it for over 35 years. If you are putting that much pressure on your hands you may need an adjustment, FWIW I set most of my bikes up a bit more upright than is considered normal.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Bikes: Custom 531ST touring, Bilenky Viewpoint, Bianchi Milano, vintage Condor racer
I like the larger grip diameter of mountain bike grips, but don't particularly want padding. I slit a length of heavy-walled garden hose and put that over the bars before taping them. With a single layer of tape over the hose, the diameter is the same as a mountain bike grip, but I can make it as long and curved as necessary. You can see it larger at https://www.flickr.com/photos/jputnam/7370808234
Here is a setup with unpadded rubber handgrips and Bontrager cork tape.
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 48 Post(s)
Liked 42 Times
Under my bars I have long gel pads I found on the Nashbar site. They have adhesive strips, but I left them on and scotch taped in place so when I change the tape, I can salvage the pads
This kind of stuff is common on butterfly-type handlebars:
https://www.componentforce.co.uk/cate...3/foam-sleeves
I don't put credence in horror stories of carpal tunnel syndrome caused by using such material, because so many people use it for touring. For example, my wife used short foam grips on a three-month tour and had no trouble. Butterfly handlebars are usually sold with foam on complete bikes in my country.
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
Stuart Black
Stuart Black
Found Grab on grips shred as the sun dries them and your hands do the rest,
so they get thinner and thinner .
I wrapped Cotton bar tape over them, and they last for decades.
just the 4 Pieces are more like pushing together twin beds as compared with a Queen sized,
because of the way they are rounded end finished for packaging ..
If you can get long single pieces , great..
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12782 Post(s)
Liked 7,696 Times
I'm not a fan of foam either. Suelo Tubo grips would be my choice for trekking bar use.
Liked 4,221 Times
Stuart Black
Stuart Black
Bikes: Cannondale M300 mountain, '72 German Kurfalz touring
I use the mountain bike type grips near the front where my breaks and shiftes are, then gel bar tape on the rest. No problems, and so glad I switched to the trekking/butterfly bar. Very comfortable.
Quoted: 5 Post(s)
Liked 5 Times
I have a set of rubber grips and then bar wrap on mine. It is time to re-wrap, and I plan to keep the rubber grips and do a double layer of wrap (one package on each side) this time around.
jeneralist, Sampson gel tape, while too soft for me maybe good for you. I had Grap On bar wrap on an old Raleigh that lasted quite awhile, but hard to clean.
Brad
Brad
I used that as well, along with some foam tape that added a little more cushion.
My current bars are Albatross bars, and I put some Ergon grips at the end and slid a pair of short, rubber grips up to the bend. The rest of the bar is naked.
I really prefer grips to tape. The only problem I have is that you can't run cables under your grips, which can interfere with some set ups, particularly any bar-end brakes or shifters.
Bikes: 80's Marin, 90's Dawes, ALAN & various unicycles.
I use this & have no problems- https://www.bikesomewhere.com/BBB-Mul...ps-BHG-27.html
Fit it on the bar with hairspray, helps you slide it on then won't move at all when it drys.
But I don't like SPAM...
Bikes: 1994 Univega Alpina 5.2 MTB
Works for me.
When I cover my bars with a slit length of rubber hose before taping, I slit the hose just wide enough to leave room for the cable, so I get the grip diameter of grips, with the cable even more concealed than with standard bar tape.
