Can hub bearings tighten themselves?
Old 12-18-19, 05:15 PM
jreeves
jreeves's Avatar
Bikes: 1984~85 Raleigh Competition, 1985 Raleigh Super Course, 2013 Raleigh Revenio 2.0
Quoted: 43 Post(s)
Liked 35 Times in 23 Posts
When I purchased my latest bike at the LBS, a lightly used 2013 Raleigh with Weinman rims and Raleigh hubs, the owner bounced the front wheel and felt enough vibration that he removed it and adjusted the hub. Once I put some miles on the bike I noticed a unusual noise from the wheel, so I removed it and could tell the bearing was tightened too much. It was binding and felt sorta 'crunchy' when I spun it. I backed off the nuts until it felt free and smooth, but should I expect this to happen? Seems odd that it would be a problem in the first 20 miles or so?
jreeves is offline
Old 12-18-19, 05:23 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1793 Post(s)
Liked 1,267 Times in 874 Posts
Over tightening a QR skewer will cause this.
Depending on "how crunchy" the bearings felt, I'd be inclined to service/replace the balls.
It might save a hub/wheel.
Bill Kapaun is offline
Old 12-18-19, 07:16 PM
jreeves
jreeves's Avatar
Quoted: 43 Post(s)
Thanks for the tip Bill, I hadn't considered the skewer pressure. How tight is too tight anyway?
jreeves is offline
Old 12-18-19, 07:36 PM
TiHabanero
Quoted: 1744 Post(s)
Liked 1,370 Times in 719 Posts
The skewer would need to be seriously tight to affect it to the point of being crunchy. My guess is that there is something going on with the hub. Disassemble and inspect. Upon reassembly, be certain the cones are backed into the over-locknuts nice and tight. If not, they will do exactly what you have already experienced.
TiHabanero is offline
Old 12-18-19, 08:20 PM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 835 Post(s)
Liked 1,252 Times in 661 Posts
No, wait, clamping the skewer can "bow" the axle and cause bearings to be too tite.
with conventional cone and cup hubs - you want a tiny bit of play - and then the slack is taken up when you tighten the skewer.
Feel for lateral play at the rim and look for a smooth back and forth oscillation when you let the wheel turn slowly.
Mark Petry
Bainbridge Island, WA USA
mpetry912 is offline
Old 12-18-19, 08:40 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
From the OP's description I gather the hub was OK after the LBS readjusted it but tightened as it was ridden. That sounds like: 1) the locknut and cone weren't tightened together sufficiently or 2) the axle or cone or locknut threads are bad and won't hold their adjustment.
HillRider is offline
Old 12-18-19, 08:58 PM
79pmooney
79pmooney's Avatar
Quoted: 4802 Post(s)
Liked 3,923 Times in 2,552 Posts
My first thought also. One of the two cones will tighten under load from the ball bearings if the locknut is not tight. I'm not going to do the mental gymnastics to tell you which one, at least not tonight.
Ben
79pmooney is offline
Likes For 79pmooney:
Old 12-18-19, 09:44 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
In the same way that tightening the quick release stretches the skewer slightly, the same force also compresses the axle, which tightens the bearings slightly. The axle's compression will be less because the axle has a larger cross section; the amount also depends upon the elastic modulus (stiffness) of the two materials. If both are steel it will be roughly in proportion to the ratio of the cross-sections. https://en.wikipedia.org/wiki/Young%27s_modulus
dsbrantjr is offline
Likes For dsbrantjr:
Old 12-18-19, 10:23 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4199 Post(s)
Liked 3,851 Times in 2,301 Posts
I am under the impression that tensile strength is less then compressive strength for steel. So th axle will under go less dimensional change then that of the QR. How one balances this is the art of adjustment.
To the Op's initial question- Bearing "adjustment" can change for a few reasons. The above additional pre load from the QR, improper lock nut/cone counter tightening that can rotationally migrate, Out of alignment drop outs producing off axial bearing loads, contact surface wear and pitting as well as one's ability to sense bearing "feel". Andy
AndrewRStewart
Andrew R Stewart is offline
Old 12-19-19, 05:53 AM
dsbrantjr
dsbrantjr's Avatar
[QUOTE=Andrew R Stewart;21250684]I am under the impression that tensile strength is less then compressive strength for steel. So th axle will under go less dimensional change then that of the QR. How one balances this is the art of adjustment.[QUOTE]
Tensile strength and modulus of elasticity are not the same thing; the modulus is the same for tension and compression in the linear stress-strain region. The axle will undergo less deformation due to its larger cross-sectional area. https://en.wikipedia.org/wiki/Young%...lus#Definition
Old 12-19-19, 06:11 AM
jreeves
jreeves's Avatar
Quoted: 43 Post(s)
Thanks for the analysis! From what I can tell this is a joytech/novatech front hub. At this point I get the best free spin with the cups nearly loose and the minimum safe QR tension without any noticeable side play. Need to get it out on the road to see how it feels, then to a reputable shop for service!
jreeves is offline
Old 12-19-19, 11:54 AM
tomtomtom123
Quoted: 350 Post(s)
Liked 122 Times in 90 Posts
If you're already adjusting the cone and lock nut yourself, I don't see what other services you need from a bike shop. All you need to do for servicing is to remove the axle, clean the cups and cones, clean or replace the balls, add grease, put everything back together. If you notice pitting on the cup or cones, then you'll need to replace either the whole hub or just the cones.
tomtomtom123 is offline
Likes For tomtomtom123:
Old 12-19-19, 10:16 PM
stardognine
Partially Sane.
stardognine's Avatar
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times in 468 Posts
Definitely agree. ^ The good part about doing it yourself is, you'll know it was done right, and you'll know for sure the condition of all those parts, rather than "trusting" the mechanic. Plus you'll develop a feel, for how to tighten those quick releases properly. It's not rocket science, but there's definitely a happy place, where your wheels roll very nicely, not just functionally. 👍
And don't worry, if an idjit like me can do it, anyone can. 😁
stardognine is offline
Likes For stardognine:
Old 12-20-19, 01:12 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
If the right side cones were adjusted and not tightened properly then the cone can tighten and ruin the bearing. I always remove the left side cones when overhauling my hubs for that reason. If the right side cone need replacing I really tighten the lock nut as much as my puny muscles can.
davidad is offline
Likes For davidad:
Old 12-21-19, 11:03 AM
Chuckles1
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times in 94 Posts
Crunchy
When i tighten the locknut on cone type hubs, after tightening the inner nut just right, it often comes out crunchy, ie too tight. Not sure if there's a trick to it, but i usually loosen the inner nut a little more than ideal before tightening the lock nuts. If I'm lucky it comes out just right. If not, repeat until perfect. Also, it seems that putting the riders' weight on the bike makes the bearings effectively slightly looser, so a tiny bit of resistance in a non- weighted hub may be just right under load. Not sure why, but it seems so.
Chuckles1 is offline
Likes For Chuckles1:
Old 12-21-19, 11:19 AM
jreeves
jreeves's Avatar
Quoted: 43 Post(s)
All great tips, thanks!
Disassembled the hub, wiped everything down and degreased, regreased with lithium grease and adjusted just shy of crunchy and it feels MUCH better and rolls smoothly now!
jreeves is offline
Old 12-23-19, 10:16 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
If it feels like it tightens up again, check to see that the freehub body is tight. I know on Shimano hubs that a loosening freehub body can cause the bearings to tighten up mysteriously.
Wilfred Laurier is offline
