Determining spoke length?
Quoted: 1332 Post(s)
Liked 398 Times
If it's a difference of 1mm in spoke length left/right on the rear, you probably don't have to worry about it at all. Most places that sell spokes don't even offer them in 1mm increments in my experience.
^that guy^
Fresh Garbage
BTW, if you need a wheel building reference book, here is a PDF of The Art of Wheelbuilding https://tri.by/content/files/artofwheelbuilding.pdf
Easy to follow lacing method at page 67 which can be adapted for 2x lacing.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
H+Son website says 610 as well
TB14 | H PLUS SON
TB14 | H PLUS SON
Two cross front (20h) and rear (24h)
Likes For phtomita:
Liked 2,563 Times
Yep, although it's the most you'd want to do.
^that guy^
Alrighty... Got the front wheel laced up but based on the existing spoke divots I can't place the valve where I'd like.
Everywhere I read online stated the TB14 to be center drilled, which mine are not 😕... So it's not allowing me to place the spoke in the hole I want to... Ugh
then flip 180 degrees the rim, or the hub?
^that guy^
yup.....
I remember when I laced the Archetype, I had the same issue because it is not center drilled.
But I got right after re-doing it.
https://www.bikeforums.net/bicycle-m...nsiometer.html
I followed the tips from Sheldon Brown to start from the hole next to the valve hole.
^that guy^
Wheels have been built already, thanks for your input tho
