Help with Shimano 105 5600 to 5700 upgrade
Quoted: 63 Post(s)
Liked 10 Times
Hi, I usually post in the vintage forum, since my knowledge base is mostly friction shifting....
Anyway, I just bought an 2011 Specialized bike for my wife, which is original Shimano 105, 5600 series.... It is a triple in front with 10 speed maxing out at the top rated 27T in back.
I want to change the rear derailleur to a 5700 (since it is rated to 30T) and of course, then change the cassette to a same era cluster that tops out at 30T, but keeping the same hub/wheelset.
I know the 5700 RDR can handle the 30 and the total capacity, but will it work with the 5600 brifters?
I've read through old threads, and there's conflicting information.
Any experience or wisdom appreciated!!
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Yes, they will work together just fine.
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Agreed^ Also, it's possible the 30 tooth will work with your 5600 RD, might want to try it.
Quoted: 2026 Post(s)
Liked 1,096 Times
+1 Shimano is very conservative in their capacity ratings and most often their rear derailleurs will handle a cassette somewhat larger than the published limit. Try the 30T with your 5600 before buying a replacement. You will probably be pleasantly surprised.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
You should be able to run a 30 or even a 32 cog with your 50, 39 & 30 triple if you use this derailleur;
https://bike.shimano.com/en-EU/produ...D-4601-GS.html
the 4601-GS is backwards compatible with 105 and Ultegra. It has a generous practical cog size and chain wrap capacity.
Quoted: 63 Post(s)
Liked 10 Times
and no issues w trying the 5600 rdr w a cs-6700 cassette?
Quoted: 212 Post(s)
Liked 83 Times
Liked 1,096 Times
I expect tightening the B-screw a bit would have solved that problem. I have a Shimano RD-6503 (9-speed) rear derailleur also rated for a 27T maximum on one bike and it appears that snugging up the B-screw would easily allow a 28 or 30T large cog.
