1995 Marin Eldridge Grade
Quoted: 630 Post(s)
Liked 1,262 Times
1995 Marin Eldridge Grade - New pics added.
I picked up a 1995 Marin Eldridge Grade MTB a little bit ago, it's in pretty decent shape and mostly original except for the saddle and unfortunately the front wheel but there is no evidence of fork or frame damage. It's the 20.5" frame, the first Marin of any kind I've seen for sale locally with that large a frame. It should clean up nicely, I'm going to try to find the correct front wheel but failing that I'll look for a set of period correct wheels that would be an upgrade. I plan to keep it as original and period correct as possible. Please excuse the pics, they're from the CL, when I get better ones I'll post them but these will have to do for now, they'll at least give you an idea of it's general condition. It's been well used but not abuse, the fork feels good and it looks like it was well maintained most of it's life. The paint and most of the decals are in very decent shape, the grips are shot but the shifters, bars etc. are in very good condition. I have NOS and like new duplicates of the Deore LX shifters and derailleurs but I don't think I'll have to swap any of them out and it even has good tires on it. It wasn't a "steal" but I think I'm still in it right. Now I have to pick which one has to go to make room for it.......
Quoted: 630 Post(s)
Liked 1,262 Times
Found one more non original item, the seat post is a cheap chrome steel one that probably came with the cheap vinyl saddle. Not a big problem, I have several that will do for now.
Quoted: 1136 Post(s)
Liked 650 Times
Hard to tell just from the NDS photos but the cranks look like early White Industries cranks, made under contract by Sugino. Check the backside of the cranks arms to confirm.
At the time, White Industries had two levels of cranks. The top of the line set were made in California by WI, fully CNC machined from billet and then mirror polished. These had the WI logos engraved into the crank arms. The spiders were profiled and back of the arms machined out to shave weight. The second tier cranks were forged by Sugino and then finished with some machining, but not as much as the made-in-the-US version. The WI logo was silk-screened on, which often rubs off. Not quite as fancy but still a high-end cranks that was used OEM on a surprising number of Marin and some other brands' nicer models for a couple years.
Liked 650 Times
Another cool part you have on that bike is the brakes - they look like Dia Compe VC-900 cantis. These brakes use the same spring adjustment mechanism as the Paul Component brakes of the same era, and had a really cool height/angle adjustment for the pad holders, like Paul's Motolite v-brakes. Hard to say who came up with these features first.
Some better pics should show if these are actually VC-900s.
Bikes: Masi Gran Crit, Bianchi Campione D' Italia 84, Eddy Merckx Corsa Extra, Ibis Ripley, Co Motion Tandem, Merlin Agilis, Ritchey Breakaway, Bianchi Infinito CV, Colnago Master
Quoted: 68 Post(s)
Liked 129 Times
I had a number of Marin's from that era. The Eldridge Grade is an upper tier steel bike. I had an Indian Fire Trail from that same year. White industry cranks, I think the brakes were from WTB, but not sure.
Onething I noticed from your pic is the front wheel is on backwards. Those tires are WTB velociraptors, and the tread is facing the wrong direction.
Marin is still in business and in the same town. I would be willing to bet if you called them, they would be a wealth of knowledge on your Eldridge Grade.
Quoted: 630 Post(s)
Liked 1,262 Times
Quoted: 68 Post(s)
Liked 129 Times
The front wheel is a replacement and I'd flip the skewer but since the tube is blown the tire has to come off anyway. The whole bike is getting a tear down, deep cleaned and detailed. I'm keeping this one as original and period correct as possible. I have an aftermarket seat post that is nearly identical to the original but I'm hoping to locate an original eventually. I also hope to find the correct front wheel. I've wanted a "good" original vintage MTB for a long time but they seem to be rather hard to find on my size. My birthday and Christmas just came a little early this year. 😎
Likes For Thalia949:
Quoted: 630 Post(s)
Liked 1,262 Times
New pics.
Got the front tire to hold air long enough to ride a couple hundred feet. Both shifters turned out to be FUBAR but no problem as I have a pair of the exact same NOS shifters. It turns out only the front rim was replaced, they kept the original Deore LX hub so I'll probably have some better rims laced onto the original hubs. It still has both MARIN bottle cages too. What little I got to ride it felt REALLY good though, I'm looking forward to getting this back into A-1 shape.
Liked 650 Times
Nevermind about the Dia Compe brake reference. Those are Marin Lite brakes, made by Tektro.
Can you take some close-ups of the cranks, including the back of the arms? Trying to figure out of there were multiple versions of these.
Likes For TenGrainBread:
Quoted: 630 Post(s)
Liked 1,262 Times
Thanks for the brake ID, I couldn't see any markings on them. I'll get some crank pics tomorrow, rain's moving in right now.
Bikes: 1980 Raleigh Competition G.S., 1987 Schwinn Tempo, 1987 Schwinn Voyageur, 1982 Raleigh Superbe, 1983 Specialized Sequoia, 2002 Lemond Buenos Aires, 1998 Marin Eldridge Grade
Quoted: 15 Post(s)
Liked 27 Times
Before you swap those shifters out, flush out the insides with some wd40 and go in after it with some tri flow. Might bring them back to life
I've rebuilt a number of those types of shifters. Most of them you can just work the paw back and forth to get the spring moving. There are 2 on the front shifter, don't remember how many on that back.
A video that explains it a bit (different shifter, same idea)
Quoted: 630 Post(s)
Liked 1,262 Times
https://www.youtube.com/watch?v=vcwhADt7ANs
I may have a bigger problem, I haven't tried to air up the forks yet, I don't have a needle, but if the air seals don't hold I'm SOL, replacement seals are "unobtanium" for the Mag 21's. If they won't hold air I'm going to try to find a rebuildable Rockshox Judy from that era with a 8.375" long 1-1/8" threaded steerer. I wish the Judy uppers would fit in the Mag 21 crown, I'd just swap them out.
UPDATE: Found articles online on how to make my own seals or to replace them with a Schrader valve so I should be good.
Quoted: 1627 Post(s)
Liked 630 Times
I've owned a modern MTB with a beefy squish fork, and bashing that thing down through the bumps at full speed was a ton of fun; but I can do the same thing on my rigid bikes. Just a little slower.
Quoted: 630 Post(s)
Liked 1,262 Times
Well, it looks like I was meant to have this MARIN, turns out I may have the replacement rims I need already, my '89 GT Karakoram came with a like new set of wheels but they were MTB rims laced to DuraAce road hubs. ???? A rather odd combo but the rims are a like new set of Araya RM-395 Team XC 32 hole eyeleted rims and my LX hubs are 32 hole, the rims are also period correct as they were first introduce in '92 or '93 depending on who you ask. Of course I can put the equally nice Dura Ace hubs to good use too. Not sure how well the rims show up but........
Liked 650 Times
Interesting. They are definitely the Sugino version but the two Sugino pairs I have had were screened not stamped. Perhaps they changed this process at some point.
From the internet:
From the internet:
Quoted: 796 Post(s)
Liked 522 Times
Likes For headtubes:
Quoted: 630 Post(s)
Liked 1,262 Times
My guess is the stamped Suginos were the transition between the other two.
I picked up this Eldridge Grade a few months ago. Mine is a few years older than yours. Pretty decent mountain bike for the time. I have swapped out the pedals for SPD clipless pedals. The frame of my bike is 20.5" ctc and 22" ctt.
Likes For rjhammett:
Quoted: 630 Post(s)
Liked 1,262 Times
Very clean! 1989?
