Rocky Mountain Summit RL
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
I bought this old mtb. It has been in storage for 10 years. The previous owner toured around Japan on it. It's really rough. Rust. Bearings all bad. I like it a lot though.
Quoted: 813 Post(s)
Liked 1,029 Times
Here is what I like to do in this situation. Let me say that not everyone on BF agrees with this technique, but it has worked for me and so far I have done no harm to the good race inside the hub.
Clean out the grease in the hub. Often I use the old bearing if they look good. You said that the bearing are pitted, so start with new bearings. Get automotive valve lapping compound. It is gritty. Place the lapping compound into the bearing race the same as you would for grease. Adjust the cones as normal. It will feel different because of the valve lapping compound, but you are looking for a just right adjustment.
Place the axle in a drill and hold the hub with your other hand. Turn on the drill. Let it run on and off for about 5 minutes. Disassemble the hub and look at the bearing surfaces. If there are improving, then reassemble and keep going. If they are good, then stop.
Once the surfaces are reasonably smooth, clean the lapping compound out of the hub. Use solvent of your choice to get all of it out. Throw away the ball bearings that you used with the lapping compound. Then reassemble the hub with new bearings the same as normal.
Looking the picture of your cone, this may or may not work since it is deeply pitted. You don't have much to loose either. Keep an eye on your hub race to be sure that doesn't degrade.
Let us know if you try this and how it worked out if you try it.
Quoted: 2365 Post(s)
Liked 1,754 Times
Since the OP mentioned that the cups appear good, I would do the above ONLY using a junk hub as a place-holder. There's a LOT to clean up on that cone, which means a lot of "run time" on that procedure. I wouldn't subject a good hub to that.
Quoted: 275 Post(s)
Liked 417 Times
Quoted: 5890 Post(s)
Liked 3,475 Times
I love picking up old MTBs like this and keep two around the house as loaner bikes. That's too bad about the cones but replacements should not be that hard to find. Shimano made like a zillion of these hubs and I doubt it matters whether the donor hub is an xt, dx, lx, or just plain deore. There is pretty decent interchangeability.
I'd look around in the usual places like a bike co op for older shimano mtb hubs. Also put up a wtb in the local online classifieds. You should be able to find old beat up wheels with usable cones. A wtb in the C&V for sale forum might also work but you are in NZ and a long ways from most forum members.
Quoted: 275 Post(s)
Liked 417 Times
Yeah so I took the wheel to a local community used bike shop
looked through parts bins for ages, could find 1 good cone that fits
they ended up ordering me some new from shimano which apparently should work, so that's great
the rims have life in em too and they're straight
Quoted: 275 Post(s)
Liked 417 Times
Is the middle ring supposed to be like this for shifting or is it dead?
Quoted: 1627 Post(s)
Liked 630 Times
It should work OK. Depends a bit on the chain and whether it's in decent shape and lubed. Ride it to find out.
Quoted: 275 Post(s)
Liked 417 Times
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
Wheels Manufacturing sells new cones and axles in case the shop version doesn't work out. Here: https://wheelsmfg.com/products/hub-parts/all-cones.html
Quoted: 275 Post(s)
Liked 417 Times
I had only taken in the cones, and they said none were the same.
I took the axle and the cones and the whole shebang to the second shop, a lower rent community type place. They set me to looking through boxes and boxes of old cones, and said that any which fitted on the axle should work.
None did so they ordered some, I think actually from shimano.
I'm a bit confused about how exact cones do have to be and I think if for some reason the cones the second shop has ordered for me don't work, i'll take the axle into the first shop and see if any of the wheels mfg cones fit on it and if those might work.
Very confusing lol and I know i'm doing this baby mode with modern-ish shimano parts and compatibility. Huge huge respect for people keeping much older bikes in good service.
Quoted: 275 Post(s)
Liked 417 Times
I'm thinking about getting it blasted and powdercoated
Prices 120-180 NZD
Thoughts?
Prices 120-180 NZD
Thoughts?
Likes For Soody:
Quoted: 275 Post(s)
Liked 417 Times
I cut out and drilled this pulley out a bit because it was missing from the stem.
It's a 1-1/8" stem so hard to just replace
hopefully this should work ok
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,057 Times
Quoted: 275 Post(s)
Liked 417 Times
aaagggghhhhhhhhhh
Quoted: 275 Post(s)
Liked 417 Times
yeah...
this frame is trash now right?
I'd personally part it out as I'd be concerned of unseen damage. Others may repair it, but not worth it to me.
Liked 1,754 Times
Yuh, "that'll buff out", right?
Quoted: 275 Post(s)
Liked 417 Times
local shop is going to weld it
Quoted: 275 Post(s)
Liked 417 Times
Welding is done.
There's a local place that does '100% inhibited phosphoric acid base' dipping
The powdercoater could also blast it
Not sure. Thoughts?
Not sure. Thoughts?
