SunTour Barcons Questions
Can the standard SunTour Power Ratchet Barcons handle a triple crank? Or were they produced in 2 different versions, depending on if you were running a double or triple crank?
Thanks in advance
Thanks in advance
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,287 Times
Just one version, with the derailer limit screws limiting the lever's travel.
Quoted: 5888 Post(s)
Liked 3,471 Times
Yes.
Likes For bikemig:
Likes For Chris_in_Miami:
ambulatory senior
Quoted: 1954 Post(s)
Liked 3,658 Times
I concur.
Likes For 52telecaster:
Likes For Goofball:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I've used them on doubles and triples.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Bikes: 1984 Miyata 1000, 1984 Univega Specialissima (frame), 1993 Miyata 1000LT, 1987 Raleigh Ventura, 1935 Golden Sunbeam, Early '50s Columbia Bomber
Quoted: 19 Post(s)
I use them on my triples. If there are different versions out there for double/triple cranksets, I was never aware of them.
Bianchi Goddess
Quoted: 2926 Post(s)
Liked 2,921 Times
Yes. And since we are showing off our triples
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 796 Post(s)
Liked 522 Times
Ok I will ask what seems to me like a dumb question ... how can you tell which shifter is left and which is right, i.e FD control or RD control.... does it matter if they are friction? I have a set but see no obvious way to tell (he said shamefaced)
Slotted side of the bolt
nut side of the bolt
Bianchi Goddess
Liked 2,921 Times
The left one says JAPAN and the right one says Japan
They handle triples just fine, as others have mentioned above. No difference front- or rear. They're both the same. I've had mine on this bike since November of '76! I changed from double- to triple crankset ~30 years ago, using the original Compe-V front derailleur.
Likes For Cougrrcj:
Quoted: 796 Post(s)
Liked 522 Times
I feel my leg being tugged a bit as they both have JAPAN spelled in CAPS and Velobase seems to indicate the friction barcons are the same right and left
Likes For ryansu:
Bianchi Goddess
Liked 2,921 Times
Did you actually go look at them? If so my job is done here! LOL
Quoted: 823 Post(s)
Liked 1,395 Times
I ran mine with both double and triple chainrings with no problem - the challenge was getting a Campagnolo Olympus mtb rear derailleur to play nice with the barcons over an 8-speed Campagnolo cluster. I had to have it dialed in just exactly right to get all 8 cogs.
Likes For rustystrings61:
Quoted: 1627 Post(s)
Liked 630 Times
I have yet to meet a friction barcon, friction downtube or friction stem shifter that couldn't handle three rings. When you think about it; it makes sense. Those three rings up front on any given crank are spaced closer together than the most narrow 5-speed cluster on back, so why wouldn't it?
Another gratuitous pic of the setup in practical use:
Likes For Lascauxcaveman:
