Best Chain Lube
Best Chain Lube
Old 03-02-05, 02:07 PM
xccelr8
xccelr8's Avatar
Bikes: 2002 Lemond Zurich, 2004 Gary Fisher Tassajara
Best Chain Lube
Hi,
I'm looking for some advice as to the best chain lubes for a road bike. I have been using Boshield T-9. Most of my riding is done in the dry. I have found that my chain seems to pick up a lot of grit and grime which affects my shifting. I apply the lube every 200-300 miles. Am I doing something wrong?
Any suggestions for a good all around lube that won't pick up a lot of road debris. I am thinking about trying Prolink Gold.
Also this might sound like a dumb idea but has anyone every tried a synthetic motor oil such as AMSOIL as a chain lube? I use AMSOIL in my vehicles and think it's outstanding.
Any thoughts?
Thanks,
xccelr8
xccelr8 is offline
Old 03-02-05, 02:09 PM
DogBoy
No one carries the DogBoy
Bikes: Roubaix Expert Di2, Jamis Renegade, Surly Disc Trucker, Cervelo P2, CoMotion Tandem
Quoted: 5 Post(s)
I thought the best chain-lube was WD-40..... j/k
DogBoy is offline
Old 03-02-05, 02:15 PM
OneTinSloth
(Grouchy)
i had been using prolink for a while, but have recently become a believer in tri-flow. just the little black bottle that's usually about $4.95. you have to apply it a little more often, as it doesn't really harden like some other chainlubes do, but it's amazing, and it smells nice, too.
OneTinSloth is offline
Old 03-02-05, 02:18 PM
ManBearPig
1/2 man,1/2 bear,1/2 pig
ManBearPig's Avatar
Bikes: .
I've settled on Prolink. There is no perfect lube -- i.e. one that lasts forever, never attracts crud, and that eliminates chain maintenance. Chains must be maintained, period. Sad, but true. I wonder why folks stopped working on a sealed transmission?
ManBearPig is offline
Old 03-02-05, 02:22 PM
Chops83
Another fan of the Tri-Flow here
Chops83 is offline
Old 03-02-05, 02:24 PM
Matt Gaunt
Matt Gaunt's Avatar
Quoted: 18 Post(s)
Weight!
I use a wax based lube for my road bike and a more runny, highly effectlive but mega-crud-attracting one for my MTB.
Matt Gaunt is offline
Old 03-02-05, 02:30 PM
jlin453
Bikes: Jamis Satellite
I've never used a wax based lube, but the chain that my new bike came with had this wax based lube. I was wondering why my fingers were sticky after I touched the chain.
jlin453 is offline
Old 03-02-05, 02:32 PM
ManBearPig
ManBearPig's Avatar
Bikes: .
Originally Posted by Matt Gaunt
Weight!
That's a good reason to keep working on it. Who woulda thunk 15 years ago that a cell phone would fit in a shirt pocket?
Old 03-02-05, 02:33 PM
OneTinSloth
(Grouchy)
that's not lube...it's a protectant that keeps the chain from getting rusty while the bike sits in the box or at the shop for months and months and months...same deal with the gunky crap on new chains straight from the box. simple green takes care of that, then triflow.
Old 03-02-05, 02:35 PM
OneTinSloth
(Grouchy)
maintenance. taking care of a chain isn't that difficult. overhauling any kind of sealed drivetrain is a pain in the ass...internal gear hubs, shaft drive, even fully enclosed chainguards *shudder*...plus internal gears aren't as efficient as external gears.
Old 03-02-05, 02:36 PM
Matt Gaunt
Matt Gaunt's Avatar
Quoted: 18 Post(s)
Good point. I suppose if the boffins at Trek make the bike 'too light' for any of the regulations then a housed transmission would be viable.
Might be a pain in the a$$ to maintain, though - still gotta lube the chain and cogs.
Old 03-02-05, 02:37 PM
Matt Gaunt
Matt Gaunt's Avatar
Quoted: 18 Post(s)
HA!! Posted my reply at the exact same time as OneTinSloth and put the same sentiment in it too - it's like one mind!
Old 03-02-05, 02:45 PM
joeprim
joeprim's Avatar
WD-40 is called WD because it is Water Displacer great stuff, but not lube.
Joe
joeprim is offline
Old 03-02-05, 02:46 PM
howling.fantods
I like triflow too. Picks up grit if you don't wipe it off enough, but if you wipe down the chain pretty thoroughly after applying it, it stays pretty clean, and still has all the lube it needs in the actual contact points. Every 200-300 miles doesn't sound often enough. I usually re-lube after every long ride, or every couple of days if I've just taken it out for short errands. I've tried wax lubes, but it starts sounding craptastic after 50 miles or so.
howling.fantods is offline
Old 03-02-05, 02:54 PM
Matt Gaunt
Matt Gaunt's Avatar
Quoted: 18 Post(s)
LOL!!! yeah i suppose - my MTB is silky smooth on runny oil but I just haven't got the heart to do that to my roadie! Looks foul most of the time but it's so effective if you keep it under control.
Old 03-02-05, 03:22 PM
DogBoy
Quoted: 5 Post(s)
Hence the j/k
DogBoy is offline
Old 03-02-05, 03:43 PM
skydive69
skydive69's Avatar
Bikes: Guru Geneo, Specialized Roubaix Pro, Guru chron 'alu, Specialized Sequoia
Originally Posted by xccelr8
Hi,
Any thoughts?
Thanks,
xccelr8
I use Pedro's spray on dry lube. I used to use Pro lube, but unlike Pedro's which seems to pick up little dirt, Pro lube picks up everything on the road requiring frequent chain cleaning. I can now run my chain quickly through a towel, spray on a coat, wipe off excess on sides, and chain sparkles without running it through a chain cleaner.
skydive69 is offline
Old 03-02-05, 03:45 PM
Voodoo76
Blast from the Past
Voodoo76's Avatar
Bikes: Felt FR1, Ridley Excal, CAAD10, Trek 5500, Cannondale Slice
Quoted: 222 Post(s)
Liked 66 Times in 43 Posts
Tri-Flow is very effective. Most people over use it, apply one drop per roller and wipe excess off. Much less dust collection & should last a week or two unless you run into a bit of rain.
Voodoo76 is offline
Old 03-02-05, 03:47 PM
climbo
climbo's Avatar
Bikes: a few
Homebrew - it's been discussed all over the place on forums. 3 parts OMS to 1 part motor oil, shake, spray, wipe down, ride. I've been using it for years, cheap and it works.
climbo is offline
Avalanche325
Avalanche325's Avatar
Bikes: Litespeed Firenze / GT Avalanche
I found that White Lightning runs way cleaner than Pro Link.
Avalanche325 is offline
Old 03-02-05, 04:01 PM
'nother
semifreddo amartuerer
'nother's Avatar
Bikes: several
I just recently "switched" from Tri-Flow to White Lightning ("Epic"), so far so good. Definitely does not seem to attract as much crap as TF or other lubes. Guess we'll have to see about the longer term; I've only been running it for about 100 miles so far.
'nother is offline
Old 03-02-05, 04:04 PM
Dr Mono
Another vote for Tri-Flow
Dr Mono is offline
Old 03-02-05, 04:37 PM
JBar
JBar's Avatar
Bikes: Cannondale R1000, Marin Pine Mountain
I use Tri-Flow, usually clean my bike once a week or so and thoroughly wipe off any excess lubricant. My bike is cleaner than most but I think my drive train will last longer and work better as a result. If I'm going to spend 8-10 hours a week on my bike, it's no big deal to spend 15-20 minutes to keep it clean. Of course, if I followed that rational, I'd have to wash my truck.
JBar is offline
Old 03-02-05, 05:18 PM
jsigone
got the climbing bug
jsigone's Avatar
Bikes: one for everything
Quoted: 632 Post(s)
Liked 908 Times in 273 Posts
I use White Lighting on both the MTB and Roadie.
jsigone is offline
Old 03-02-05, 05:39 PM
DXchulo
Upgrading my engine
DXchulo's Avatar
Quoted: 125 Post(s)
Nice to see lots of Tri-Flow believers like myself.
If you want something that doesn't attract much dirt and you live in a dry area, you should try some wax-based lube and see how you like it.
I used some wax stuff a while back and didn't really like it because I had to apply it more often, but that's just me. Plus, I missed the beauty of the black stuff on my chain.
DXchulo is offline
