Need help identifying an older Trek
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
Hoping Trek experts respond to the bat light: a fairly unhelpful (and sole) photo of a bike ad up on the local CL here -- I'm looking to experiment with touring frames to see how they feel, and this one looks my size and carries clues (eg. rack bosses on chainstays) that it might be a match.
Looks lowish-end otherwise (DC brakes, cheaper seatpost etc) - any Trek gurus here who can zero in on further clues? (pretty sure i see unoccupied bottle bosses on down tube, etc) maybe also confirm it's 24" and not 25"?
incazzare.
With that paint scheme, probably 1980-82, if I recall correctly.
If that's a Reynolds 531 sticker on the seat tube, probably a 6XX or 7XX frame.
Best guess, a 1982 610? Whatever it is, it seems to be a pretty decent one.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
incazzare.
I see it on the Brooklyn craigslist. Go get it now. At that price, you'll be lucky if it's not gone already.
Quoted: 2363 Post(s)
Liked 1,749 Times
It's an '81 or '82, by the livery and the above-the-stay rear mech cabling. Color and seat stay rack braze-ons suggests it's an '82 613, but it should have a Laprade seat post and nicer DiaCompe brake levers with hoods. Rims appear to be replacements.
Quoted: 796 Post(s)
Liked 522 Times
Looks like a good bike but to be clear the touring line for Trek at that time was 420 (sport touring) 520, 620 and 720 the later 3 would have come with Cantilever brakes and triple chain rings, a serial number ought to answer the questions. Vintage Trek is also a great resource. Good luck
Likes For ryansu:
Quoted: 217 Post(s)
Liked 198 Times
thanks folks - appreciate the collective brain dump. can make it out there tomorrow pm at best, so fingers crossed.
incazzare.
OK, guess I'll go get it now, then.
KIDDING.
KIDDING.
Quoted: 217 Post(s)
Liked 198 Times
Quoted: 786 Post(s)
Liked 520 Times
Looks like an Ishiwata 22 tubing decal on the seat tube. That says 400 series to me. Maybe upgraded rims too. Nice bike.
Somethings up with that front wheel/brake situation. The "upgraded" wheels might be 700c's, and it looks like the front caliper has insufficient reach to drop the pads far enough. Unless you like braking against the tire. Then it looks terrific.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Quoted: 217 Post(s)
Liked 198 Times
it'd be a bonus if it's already wearing 700s, and the existing Dia Compes would be coming off for sure.
Quoted: 217 Post(s)
Liked 198 Times
...but I've seen a lot of Weinmann LP18 rims used around these parts for newer 27" wheelsets, so I fear it's just wearing newer 27s
Liked 1,749 Times
Am I the only one itching to know the serial number?
Space between the tire and fork crown does kinda suggest it's on a 700 up front; IIRC, the 27s stuffed into the original fork pretty snug.
Quoted: 5888 Post(s)
Liked 3,471 Times
I wish I were selling my old bikes in NYC, . This looks like a 25 inch frame and looks to be, as others suggested, an early 80s 600 or even 400 series. Both are fine bikes and other than snob appeal 3 main tubes Ishiwata is as good as 3 main tubes Reynolds 531. One thing to keep in mind is that some of these bikes came with a suspect fork which you may need to change out.
I have a pristine (and I do mean pristine) 24 inch 1983 Trek 620 that I need to get rid of one of these days.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
Do the chain stays look a little short to the rest of you to be a touring frame? They're certainly not as long as a 520/620/720. The seatstay braze ons indicate rack, but I just don't see touring geometry.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Commence to jigglin’ huh?!?!
Quoted: 217 Post(s)
Liked 198 Times
ok - scuffed and chipped, but straight and true (photos not yet), here's what I can add so far...
- s/n appears to be 016262 - seems this indicates a 1982 610?
- measures ~24" ctc
- tubing is 531, though decal is largely gone
- rear dropouts with adjuster screws
- has a full set of Blue Line mech
- newer 27" rims
- rack mounts on seat stays, a chain hook also, and one set of bottle mounts on downtube
- measures ~24" ctc
- newer 27" rims
Liked 3,471 Times
Good deal. The tubing is 531 main tubes if an '82 600 series; Ishiwata magny fork and stays.
You are going to want to take a look at this thread:
https://www.bikeforums.net/classic-v...ata-forks.html
I have a 400 series Trek with that potential fork problem and I think I may just replace the fork.
Quoted: 1856 Post(s)
Liked 664 Times
- measures ~24" ctc
- newer 27" rims
- measures ~24" ctc
- newer 27" rims
Liked 1,749 Times
^^^^ +1; the "610" in the serial number tables is just a place-holder of sorts. At that point in the process, it's unknown whether the bike would be a 613 or 614. Being a double, with gunmetal paint and BlueLines, that def. makes it a 613. Nice find. Wonder why the front brake appears to be hitting too high; trick of the photo angle?
Quoted: 217 Post(s)
Liked 198 Times
Quoted: 217 Post(s)
Liked 198 Times
Quoted: 217 Post(s)
Liked 198 Times
Liked 1,749 Times
^^^^^ They used DuPont Imron automotive-style paint BITD, so either they just used the DuPont color names, or came up with the names under the influence of the fumes...
Does it seem that more than one-half of photos of bikes being sold on line show the left side and not the right? Wouldn't you expect it'd be 50-50? Does some corollary of the Peter Principle account for that?
