What are all the needed bits and tools?
What are all the needed torque wrench bits and other tools so I can tighten/open everything on my bike? I'm planning to build a new bike from a scratch (buying frame, components etc separately).
Quoted: 2026 Post(s)
Liked 1,096 Times
Required allen keys for a bike are typically 3,4,5,6 and 8 mm but vary with the make and model of components you choose. Also there are a number of bike specific tools for working on bottom brackets, headsets, hubs , etc.
Be specific as to what you are getting and we can be more specific as to what you will need.
Actually the first "tool" you need is a good bike repair book and a tour through Park Tool's web site tutorials.
Bikes: Many
Basically what HillRider just said. You will need some very specific tools for facing the headtube, bottom bracket etc, these will be quite expensive, you may even end up spending more on tools than you do on the frame and components. On the plus side you will have a pretty nice workshop set up if you want to build more bikes!
I'm not sure yet what components or even what frame I'm choosing so I guess I have to bump this again after I know what I will get.
Kinkicycle, yes I want my own tools so I can fix and update my bike(s) by myself. One tool costs about as much as taking the bike to the shop and pay them to open something. Also I want to learn to do it myself since I enjoy it
I'm looking to buy another bike too which is fitness type flat bar bike (pre built). One thing that I might want to change to it is different cranks so I get larger Q factor. The bike has Truvativ Stylo crankset. Is there way to know what tools I need to change the crankset? I guess I have to change the BB too so I need tools for that too? Link to bike: Click.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
The cost of some of the tools specifically the facing tools cost many times the cost of having the LBS do the work and headset press is another example. These facing and thread cutting tools will probably only be used once on a bike. I have only removed the headset once on one of my bikes and that was to strip it down to be painted. Some tools just cost too much, it is cheaper to have the LBS do the work due to the infrequency of the work.
Yes some tools might cost too much, but for example removing BB and crankset costed 25$ last time, tools for removing those can be bought for same price I think?
Bikes: 1992 Marin Eldridge Grade, 2007 Kona PHD and 199? Trek 1000 (current build project)
Yeah - a crank puller and a BB tool can be had for around $15-20 each.
Liked 1,096 Times
Here is one source but there are a lot of others:
https://www.amazon.com/s/?ie=UTF8&key...l_1hmy5zygsa_e
Quoted: 305 Post(s)
Liked 2,038 Times
But my point is that the OP wanted to purchase his own tools but some tools are very expensive and infrequently used, and the home mechanic is better off going to the LBS or Co-op for certain work.
Mechanic/Tourist
- You don't know what tools are used for what parts.
- You apparently are unable able to find that easily obtainable information on the Internet.
- You either don't know or don't care about using clear terminology, so refer to tools to "open" or "tighten," in spite of the fact that pretty much every site that discusse repair procedures uses the term removal and installation.
- You did not understand that it's impossible for anyone to answer your question when you don't know what frame or components you will have.
- Yet you have decided to build a bike from scratch (with no specified reason or goal) and you are worried about Q factor, two things that over 99% of cyclists never deal with or worry about.
As for tools, all you have to do is go to parktool.com/blog or Sheldonbrown.com or just use Google to search for install, replace or adjust and the name or brand/model for a given component. Waiting for answers regarding the tool for each part is a colossal waste of time and resources. Besides, all you will know at that point is the name of the tool - not how to use it, nor how to select the correct part to install for your usage or compatibility with the rest of the bike, nor how to adjust once you've installed it.
Are you aiming at the end point, or the journey.
It's often cheaper to make use of LBSs economies of scale and just buy a complete bike - especially when you factor in the tools.
But if you're intent on building a bike for the pleasure of it then buy the tools as you go along.
You may screw a few things up and have to buy parts again - this is a good way to learn. Have fun
Park tools website, Sheldon Brown and innumerable youtube videos are good things to refer to at each step. Look at more than one source each time though.
Mechanic/Tourist
Screwing up and spending even more time and money as a result is not a good way to learn, and certainly no fun. Mistakes will occur, but learning by trial and error is silly when there are plenty of resources available to help avoid mistakes.
Torque wrenches have a useful range so those You Need 3_ 1/4, 3/8, 1/2" .. example:
3/8" beam wrench range for external BB installation , pegs out of range , then you need the 1/2" one.
Carpe Velo
Bikes: 2000 Bianchi Veloce, '88 Schwinn Prologue, '90 Bianchi Volpe,'94 Yokota Grizzly Peak, Yokota Enterprise, '16 Diamondback Haanjo, '91 Bianchi Boardwalk, Ellsworth cruiser
Liked 14 Times
Some general tools are easy to suggest.
Allen wrenches
Cable cutter
screwdrivers
tire levers
Spoke wrenches
Workstand
Pedal wrench
Some are optional but very convenient to have:
Fourth hand tool (cable puller for brake adjustments)
Three way Allen wrench (my most often used tool)
Digital calipers to measure part diameters
Other tools are specific to the make and model of parts you are using:
Bottom bracket wrenches, for example.
I buy the special tools as I have need for them.
Allen wrenches
Cable cutter
screwdrivers
tire levers
Spoke wrenches
Workstand
Pedal wrench
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
The Park Tool web site https://www.parktool.com/ is an excellant resource for tools and their use.
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
Let's see:
- Duh, that's why I made this thread.
- Maybe we should close this forum because most information people ask can be found on the internet?
- English is my third language.
- You didn't understand that I understood it.
- Maybe you should read my posts few more times before replying.
There are pedal extenders that space the pedals further away from the crank arms and give the effect of a larger Q-factor. They are a lot less expensive than changing the crank and bottom bracket.
Allen wrenches
Cable cutter
screwdrivers
tire levers
Spoke wrenches
Workstand
Pedal wrench
Allen wrenches
Cable cutter
screwdrivers
tire levers
Spoke wrenches
Workstand
Pedal wrench
Liked 1,096 Times
cny-bikeman's post may have seemed a bit dismissive but he made some very good points. Your OP made it sound like you had absolutely no knowledge of bike mechanics or what components you were going to build or buy or what to do with them once you had them. If you are more experienced than you made it seem, fine, but you gave us very little to go on.
Mechanic/Tourist
Let's see:
Mechanic/Tourist
Mechanic/Tourist
...as I said - "a little more money" is still more, and the final cost has yet to be determined.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Again cny, "spending" more time writing an angry non-response than the amount of time wasted by reading the thread up to this point... why do you bother? You should keep a RTFM.txt on your desktop to paste from for threads like this. It'll save you a lot of time I'm sure...
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Plus, as mentioned above, youtube, park.com, sheldonbrown.com etc are your friend (in reverse order, actually). TONS of invaluable advice there.
EDIT: I see the word "carbon" up there now, you will probably need two reliable torque wrenches (for different torque ranges, socket drive sizes), carbon assembly paste, and if there's anything else special for carbon, probably somebody else can say.
