Ask your small, random, track-related questions here
#4001
Bikes: I don't even
Quoted: 80 Post(s)
Liked 191 Times
I've known some guys to run their saddles slightly lower on their track bikes vs their road bikes to help smooth themselves out at higher cadences though, and by lower, I mean millimeters difference.
Another thing to note, if you find yourself interested in any of the timed events that allow aero bars, saddle height may change again. I find myself sitting further forward on my saddle when on aero bars and it requires me raising my saddle a few mm to compensate for the difference.
#4002
Quoted: 9 Post(s)
That's good info blackbullet. I followed your example by adding the 2.5 mm and got pretty close. I've done some high rpms on the rollers and it feels pretty good but I need to get on the track to get this dialed in. I'm sure I'll be moving things around as I learn more about the track.
I run 172.5mm cranks on my road bikes and I feel like I have a little more power available with the longer cranks. I've read that the shorter cranks keep you from scraping the pedal on the track but I can't imagine it would make that much difference. I would prefer 172.5 if others run that length. The track in Frisco is 44 degrees so would it vary by track?
#4003
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
FWIW (I'm fat, slow, haven't ridden on the track in a couple years, etc) I run 172.5 on the road and 167.5 on the track. Partly for higher rpm, partly because that's what people said is done, and partly for the extra clearance in the corners for low speed tactics.
I raced in Rock Hill, which was 44.5* I believe. Now I'll be at T-Town, which is not nearly as steep, so I'm not sure if people tend to longer cranks or still stay short for RPM.
#4004
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Rules of thumb from road to track should be avoided. Remember the one about, "The TT on your track bike should be 2cm shorter than the TT on your road bike...period." or "All track bikes should use 165mm cranks...period."? People really believed that.
Crank length also depends on your events and riding style. There is no rule of thumb that will be perfect for everyone. The demands of a team sprint, flying 200, match sprint, kilo, 3K, and 4K are different.
Even in local racing, there are specialists and generalists. If you are going to be a specialist, choose your components that supports the events in which you will specialize.
This is a sport where winning and losing (even at the local level) is often decided within a couple of seconds or less. These things matter.
#4005
On the road you are kind of restricted gearing wise with compact and standard cranksets and set cassette combinations. On the track you can virtually have any combination you want. With that in mind you need to consider your gain ratio. What that does is takes into account all your gearing, including your crank length. So all things being equal, a 100" gear using 165mm cranks will equate to a 106" gear using 175mm cranks due to the 6% difference in crank length and therefore leverage.
On the track you will find that you have a sweet spot cadence range for whatever event you do. That will depend on you, your crank length and the event's demands. Play around with gearing to get a feel for it. Go high, go low and go everywhere you can in between and see what results.
#4006
Bikes: I don't even
Quoted: 80 Post(s)
Liked 191 Times
172.5 is on the longer side of what most people run, but I'm 6'4" and it's what feels good to me. I'd say go ahead and give the 170mm cranks a try and see how you like them over time. Maybe even try something shorter and then settle on whatever you like best.
#4007
Elitist
Liked 92 Times
Don't forget to factor in BB height/drop. This measurement can vary by 1cm between popular make/models of track frames. 2cm if you count Serenity bikes which had an unusually high BB (which is probably why people said it felt different to ride).
#4008
Lapped 3x
The BTs have a 2cm difference in BB drop between the Sprint and Enduro bikes. 45mm for sprint, 65mm for enduro. These tend to be on the higher end of BB drop. Many "all-rounder" or sprint oriented track bikes have 55-60mm BB drops. Dedicated pursuit bikes can be around 75mm.
#4009
Searching for recommendations for a cycle computer. I'd like this thing to be as basic (and cheap) as possible. I have few requirements:
-The only functions I really need are current and maximum speed
-Wireless (will have to remove it for racing)
-Want to mount sensor on the rear wheel and head unit on bar/stem (rear wheel mount for data while training on erg)
Any recommendations? Thanks in advance
#4010
Garmin Edge 25? You can get a bundle with a speed sensor for the rear wheel pretty cheap ($200 ish in Aus) I'm not sure about cat eye computers being able to upload stuff, and the price is normally pretty close to garmins by the time you get to the better ones. I can never concentrate on the screen during full gas efforts, so being able to pull the data off and view it in Ostrava or whatever is what floats my boat.
#4011
Thanks Minion1, but I'm talking MUCH simpler. I literally need only current and maximum speed, I don't need to download anything- I'm the guy who still keeps a training log in a paper notebook!
#4012
Quoted: 26 Post(s)
I've used a Cat Eye Urban - about $20 and wireless, with a mount that can work on the bar or stem.
#4013
Elitist
Liked 92 Times
https://www.amazon.com/CatEye-CC-RD3...dp/B00JXN78IM/
Street price is around $40 or less. You might find them at most well-equipped bike shops.
Unsolicited advice: Maybe spring for a system that records cadence as speed and distance on an ergo don't mean anything because you are not fighting air resistance. Cadence does. I'd imagine your ergo workouts would be centered around time and cadence as opposed to time and speed or time and distance.
#4014
Thanks guys. Based on this and some cyber-snooping I've just ordered a Cateye micro, should do the trick. And Carleton, yeah, these workouts are based on cadence, and thanks to your excellent track apps for iPhone (*shameless plug*) I'll just use speed and gear to give me cadence rather than pop for the more complicated computer with a cadence sensor.
#4015
Elitist
Liked 92 Times
thanks guys. Based on this and some cyber-snooping i've just ordered a cateye micro, should do the trick. And carleton, yeah, these workouts are based on cadence, and thanks to your excellent track apps for iphone (*shameless plug*) i'll just use speed and gear to give me cadence rather than pop for the more complicated computer with a cadence sensor.
#4016
I have a Performance Ascent fluid-trainer for my 2008 Sirrus (I'm new so I can't post a URL so you'll have to look it up...)
The problem I'm having is it is "Stiff" - its the only word I can think of. The roller doesn't roll freely, so when the wheel is against it and I'm pedaling, it only rolls with the revolution of the crank - then it slows to a stop - imagine pushing a treadmill with the strength of your legs (obviously this is different, but....similar). So my question is - am I doing something wrong? I know that I have it set up correctly, but I wonder if the trainer is malfunctioning, needs lubrication (if so...how?) etc.
Please help!!
N
Please help!!
N
#4018
Sweet, if it's mostly indoors stuff you should be ok - I do top cadence efforts on the trainer once a week or so, and I've got no chance of focussing on the screen to know and remember my cadence. I also wear glasses, and sweat like a pig, so I've got no chance of seeing anything 90% of the time.
#4019
Quoted: 40 Post(s)
Quick question about the world cup: How do trade teams qualify? I assumed it was an event for countries, but it seems like 2 of the riders in the women's sprint in Cali were from a Russian trade team which had entered alongside the Russian national team.
#4020
aka mattio
Individual riders, whether they'll be racing with a national team or a trade team, must qualify by earning UCI points before the World Cup season.
Here's USAC's nomination worksheet provides a bureaucratic overview of how it works.
#4021
Quoted: 40 Post(s)
UCI Pro Track Teams don't need to qualify - they're eligible, along with national teams, to race World Cups.
#4022
Looking at the Tissot lists of riders for the LA World Cup there appeared to be several track trade teams competing.
https://www.tissottiming.com/File/Dow...FFFFFFFFFFFF01
https://www.tissottiming.com/File/Dow...FFFFFFFFFFFF02
#4023
Quoted: 13 Post(s)
I'm looking to race the track this year. I would just ride the rental bikes, but no adjustments are allowed to be made other than saddle height, and they won't allow you to race on them anyway. My question is, what's stopping me from buying this bike?
Aventon Cordoba. (The older model) the 2017 model provides too much rake in the front end. (I don't have enough posts to include a URL sadly.)
In my size, I get a 75 degree ST and the HT with the supplied fork nets me a trail of 56mm. The 52mm BB drop seems acceptable for my track. (333 meters, and 33 degrees in the turns)
I know it's not the brand name that everyone knows and loves, but I actually have some SRAM Omniums, and a Carbon Specialized Tri-Spoke I pulled off a 'hipster fixie' find on Craigslist. And from what I've been told and gathered, 6000 series aluminum is all the same. With that said, some decent bars, and a better rear wheel for racing would make this a decent bike for my purposes.
I'm not trying to break the bank as I still need to pay for season fees on top of this. I'm not afraid to go the upgrade path of parts over time, and the fixed gear scene is big enough in my city that I shouldn't lose a ton trying to sell the parts I replace.
If this is a terrible choice, please point me in the direction of something else.
#4024
Bikes: Too many to list
Quoted: 1764 Post(s)
Liked 1,119 Times
Whatever gets you out there ---- At worst you ride it for a couple of months until you figure out what (if any) of its shortcomings are , then sell it and purchase something better for you ---
BEst case scenario, -- it works rock solid and you have a nice bike for track days --- Some of us geek out and spend a small fortune on equipment, --- but its not necessary to get started .
#4025
Quoted: 13 Post(s)
