So I bought a Nashbar Touring bike today...
Bikes: Steel 1x's
Quoted: 632 Post(s)
I have setup my Specialized Secteur to do touring on, but after doing several longer rides on it, I'm still just not digging it. Can't put my finger on exactly what the issue is.
So I started doing a little research on touring bikes again. I just didn't want drop a bunch of money into a Surly or something similar so I was looking at the REI, Performance Bike and Bikes Direct stuff. I really wanted to get away from disc brakes for this bike and I did not want to get bar end shifters either. So I ran across the Nashbar Touring bike and its setup like I want and happened to be on sale today with free shipping and lifetime return policy for $690 to my door. So I pulled the trigger.
Not sure when it will be here, but it should be interesting to see how it goes. The tech said they are only 24 lbs with the rack installed. Seemed fairly light for a touring setup. I think my Secteur weighs more than that right now with everything on it.
Here's the bike:
Nashbar TR1 Touring Bike
Here's the bike:
Bikes: Steel 1x's
Quoted: 632 Post(s)
FRAME CrMo 4130 T/T & D/T D.B. (AHJ1280A) Weld No Lug ST29.8mm FOR POST 27.2mm
FORK Hi Tensile Steel 1" Steerer
HEADSET NECO H-807W 1" CROWN RACE 27 BK W/O LOGO
CRANKSET FSA CK-4001SST Omega Triple Casted / MegaExo / N-10 / 50-39-30
BOTTOM BRACKET FSA
SHIFTERS Shimano Tiagra 3 x 10
LEVERS Shimano Tiagra
HANDLEBAR Kalloy Uno
STEM Kalloy Uno Alloy Quill
FRONT DERAILLEUR Shimano Tiagra
REAR DERAILLEUR Shimano Deore
CASSETTE SRAM CS PG-1050 11-32
BRAKES Tektro Alloy
WHEELSET ALEX DC-19 Alloy 700c
TIRES KENDA K-197 700x32C
BOTTOM BRACKET FSA
BRAKES Tektro Alloy
24 lbs? Seems a little bit light based on the specs. That seems like an excellent buy for that kind of money. My touring bike had similar specs (maybe a little higher quality frame) but I spent nearly $1300 on it several years ago.
It's basically the same bike as the Windsor Tourist and Fuji Touring. I have a 2012 Windsor that's 9-speed and doesn't have the extra brake levers. It's a very good bike for the money. Mine weighs more like 28 lbs with the rack installed, but may have some different components such as the wheels.
Bikes: Steel 1x's
Quoted: 632 Post(s)
I thought 24 sounded a little light, but my scale will let me know. Either way, I didn't buy it to be light. Hopefully it will be a nice, comfortable touring bike.
Quoted: 18419 Post(s)
Liked 15,560 Times
You planning on taking it into steep territory fully loaded with a 30x32 low gear?
Liked 15,560 Times
Because that's not that low of a granny gear for mountainous/steep terrain when fully loaded with what I will call an average load. To give you a frame of reference, the stock gearing on an LHT has a low gear of 26x34. When I was in my mid-30s I crossed the country and then some with a lot of weight. Had MTB gearing on my Cannondale. Think my granny was a 22x34. I am glad I had it. If you go ultra light it might work. Depends on you and where you go.
Bikes: Steel 1x's
Quoted: 632 Post(s)
I just pulled this from the LHT site:
Crankset
Andel RSC6, 26/36/48t. Square taper interface. Silver
[HR][/HR]Cog or Cassette
Shimano HG-50-10, 11–32t
I guess if I plan to hit the mountains I can look at another crank.
Right now, just Texas and Oklahoma on the radar.
Crankset
It's a nice bike for the price for sure (especially with today's 17% off), but it does show some compromises, which is typical for these Nashbar bikes. The main thing is for touring you'd usually want a sealed cartridge/square taper bottom bracket (mainly because they're bullet proof against wet conditions), this appears to come with an outboard bearing BB, and an FSA one at that which is notoriously poor quality.
Seems like an obvious "upgrade" would be to get a Sugino square taper crank more aimed at touring, with a new bottom bracket to support it. There's your 17% off spent right there.
Quoted: 5888 Post(s)
Liked 3,471 Times
It will be fine. The gearing may not be ideal for heavily loaded touring with a lot of climbing but that depends on your conditioning as well. I did a cross country with roughly the same gearing and it was not an issue. That was in '97; I sure as heck plan on having mellower gearing for my next cross country. If swapping out the cranks, I'd take a long hard look at the shimano trekking triple. It's not a no brainer by the way to get the brifters working with a non-shimano road triple crankset. I got Shimano brifters to work on my ritchey mtb triple crankset but it took some fiddling.
Liked 15,560 Times
Then they have respected it since I got my LHT in '11. Or the specs are incorrect as a search shows the HG50-10 as being a 11-36.
Bikes: 1989 Greg LeMond Le Vanquer, 2005 LeMond Zurich, 2010 LHT, Marlboro Fuji Folder
raise you're hand if you have had bottom bracket failure
just wondering
I think you made a good buy......have fun
just wondering
Bikes: Steel 1x's
Quoted: 632 Post(s)
I've been doing a few searches and not finding anything about this type of bottom bracket being anymore of an issue than anything else.
Cale, I'll definitely post some info on it This will be my first steel bike since my Schwinn Varsity in the 80's I'm not getting my hopes up too much, just hoping it will be a functional touring rig.
That said, there's a reason why touring bikes usually go for the old fashioned style bottom brackets, and that's because the outboard bottom brackets are more likely to fail due to water and dirt incursion, which is much more likely to happen if you're touring, as you ride through the bad weather, rather than staying home. For that reason, cranksets that are designed for touring, like Sugino's, are almost always square taper. Which is really why I mentioned changing the BB type, as to get a more touring orientated crank you'll likely need to get some with square taper.
Bikes: Steel 1x's
Quoted: 632 Post(s)
I found this interesting. It's the same crank/bb combo they use on Specialized's $1550 AWOL Elite Touring bike:
Specialized Bicycle Components
Speaking of steel bikes, consider getting something like J.P. Weigles Bicycle Frame Saver Rust Inhibitor or even using linseed oil to coat the insides of the frame. That's what I did with my steel bikes over the years.
