C02 Inflator Blow-Up
I had a flat on my commute this morning. I put the inflator on and pressed to fill the tire and boom. I thought I blew the tire but the inflator was in pieces. I put it all back together and it happened again. Finally, I got it together enough to work and was on my way but now I don't have much confidence in the inflator.
I use the Genuine Inflations Airchuck
Is there a better. I prefer not to have the canister so I can use different size cartridges for my road and mountain bikes but this isn't a deal breaker. I like how you push to inflate on this one.
BTW, when I don't use a full cartridge I just keep the cartridge on the inflator. I guess this didn't cause the problem but maybe it did.
Any thoughts would be appreciated.
Quoted: 942 Post(s)
Liked 526 Times
climber has-been
Quoted: 3422 Post(s)
Liked 3,559 Times
Hmm. Do you know which part of it failed?
I've been using one of those Genuine Innovations AirChucks for at least 10 years without a hitch.
On the plus side, it has a lifetime guarantee. They ought to replace it for you, upon request.
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
The head came apart. There was a metal washer, a rubber grommet and a metal piece.
BTW, thanks about the guarantee. I emailed the company.
Update: Genuine Innovations has already sent a replacement.
Quoted: 5224 Post(s)
Liked 3,581 Times
I have this unit. there is no regulation. you screw the cartridge on, then press the head on your valve & it inflates. you remove it when you think enough air has exchanged between the cartridge & the tire/tube. if you take it off & there's more in the cartridge you can generally press it on again to add more air. I've done this with a slow leak. however, recently I was filling a repaired tube & after removing it I couldn't add more. I removed the cartridge & when I did, some gas escaped from the cartridge, meaning it didn't empty completely. wound up using another cartridge to get a complete fill. regardless, I bought a new unit just in case the old one was wearing out or something
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
It blew up in your hand? Sounds scary, but I guess you didn't get hurt or you would have said
