Campy mystery tool... What is this thing???
Bikes: 02 Litespeed Ultimate, 84 & 85 Raleigh Grand Prix, '84 Raleigh Prestige, 85 Raleigh 555 RSL, '20 Raleigh Tamland, 38 Raleigh, 85 Landshark "Raleigh", '84 Marinoni Levi's Raleigh, SB4484, SB7979, Raleigh SSCXWC, 87 Raleigh USA 531 Prototype
Quoted: 202 Post(s)
Liked 147 Times
Frame building, I assume?
Quoted: 18375 Post(s)
Liked 4,510 Times
Somebody having fun?
It doesn't appear to me to have any specific use with bicycles, but I do wonder if somebody built it as a custom wrench for something, possibly not even bike related.
Chainwhip? Still, it would need to be anchored.
Quoted: 2026 Post(s)
Liked 1,096 Times
Yeah, looks like someone just made a toy with left over parts. It's just a set of Campy dropouts hooked together with a bit of spare chain. I suppose they could be a set of 9 mm and 10 mm open end wrenches with no handles for leverage.
Quoted: 202 Post(s)
Liked 147 Times
Apparently multiple of these were found in the Campy toolbox...
Liked 4,510 Times
Anybody know when Campagnolo started stamping their chain plates?
The rear dropout appears to have been clamped by a skewer multiple times, but I don't see any signs of brazing.
Perhaps this was used to apply tension to the cones while adjusting.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Those look to me like SedisSport chain links.
The black oxide would have been dissolved by the brazing flux had they ever been brazed. I thought the same about them being used for cone adjustment. The OP states there were many of them in a box. I wonder if there were similar left-side pieces chained together.
In any case, it's home-made, not a Campagnolo factory tool.
Quoted: 202 Post(s)
Liked 147 Times
This was purchased in a lot with a frame jig as well... Dunno...
Liked 4,510 Times
If it is homebuilt, there may not be an easy answer.
One could use it to protect dropouts from a knurled skewer during building, but then why not just find non-knurled skewer
I'm leaning towards a spacer for cone adjustment. But, you could try the Frame Builder's subforum if you think it has to do with frame building.
Likes For CliffordK:
Likes For I.B.Roots:
Quoted: 4806 Post(s)
Liked 3,928 Times
My guess - used in pairs to be clamped with the QR when adjusting the cones. Adjust cone, tighten QR, feel axle, repeat. No bike required. Takes up little space in a toolbox. There might even be a creative way to hang the other dropouts on the wheel so the ones being used stay in place while wrenching the cones. (Stick through the spokes?)
Ben
Ben
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
IIRC: used by the mechanic in the support car to pre-adjust the QR on the spare wheels. This speeds wheel changes by not having to check the adjustment on the QR after a wheel swap: rider flats, removes wheel, mechanic installs spare wheel and clamps down on re-adjusted QR, rider sprints away.
Jeff Wills
Jeff Wills
Quoted: 202 Post(s)
Liked 147 Times
Liked 4,510 Times
although IB Roots answer gets points for funny.....and the associated visuals.
Liked 1,096 Times
Liked 4,510 Times
And, probably yes, 2 or 3... plus a few spares for the ones that get lost. The two sides would need to be rather independent, although perhaps could be tied together with a piece of string.
this may be a support car tool but how is this practical?
Liked 4,510 Times
If I was doing it, probably 1 tool for all.
The chain would be a fun way to connect it all together, and would reduce tangles of having multiple strings or cables.
Likes For ksryder:
Quoted: 550 Post(s)
Liked 325 Times
1999 Record front hubs used a unique adjustable preload cartridge bearing.
Quoted: 550 Post(s)
Liked 325 Times
Likes For Drew Eckhardt:
Quoted: 805 Post(s)
Liked 706 Times
I see a front dropout attached to a rear dropout. You would have two of these setups and use them to adjust the tension on the QR's while you're just riding along or while caring for spare parts between stages. A couple of these beats carting a frame & fork around just to check the QR's. Having the two dropouts chained together beats having a bunch of loose dropouts sitting around, waiting for one to get lost.
Jeff Wills
Jeff Wills
