Squeaking noise coming from rear wheel.
I have one really annoying problem,when i ride or even when i turn the rear wheel with my hand it starts squeaking and the sound's coming from the hub part (not sure if it is because of the hub),i thought the wheel wasn't mounted properly and was off balance,but it was fine and it's centered today as well.The noise is really annoying and it's squeaking/screeching when i ride it (hard to precisely explain with text) almost like when something stays longer time without using it and and with no lube.Has anyone had same or similar problem?
I really wonder what the problem could be.
The only thing is idk what was the last time when bearings of rear wheel were changed.Maybe even 2.5 yrs ago.
Pads are ok and centered they don't rub the rim,chain is lubed.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Liked 826 Times
Does your bike have a plastic spoke protector between the gears and the spokes? Often that will warp and cause a problem, at least when coasting.
If that's not it, try removing the wheel from the bike. Rotate the moving parts by hand to see if you can identify a problem. It's rare a hub bearing will make a noise like you describe, though.
More information on the bike would help.
Likes For andrewclaus:
Squeaking from a hub is often caused by a rubber dust cap, if one exists. Look at the non-drive side of the hub where the axle comes out - is there a black rubber part on there? These often get squeaky but can be fixed by a drop or two of oil on the rubber where it meets the metal of the hub. You can pry the edge of the rubber bit back a bit with a screwdriver or a fingernail to get the drop of oil more effectively between the rubber and metal.
Likes For ClydeClydeson:
Liked 3,302 Times
rotor might be slightly catching the pads, or the axle/skewer is not properly secured.
-YMMV
-YMMV
Squeaking is usually the jockey wheels in the derailleur cage. It can sound like a bird's following you around everywhere you ride. Although that can actually happen as well.
Take them apart, clean them up and put back together with grease inside the grooves where those chintzy metal covers run.
In my case it stays in place,but if i kinda move it,pinch it toward the hub it starts to rotate.
And btw,there'a bit of play in my QR skewer lever (pointer with an arrow on the pic) is that normal?
Here's a few short videos with sound (wear headphones if can)
CLICK HERE
I have no idea what you mean by 'play' in the quick release skewer (I can't watch the video). If the QR is not tightened down holding the axle and frame together, it will be all sorts of floppy looseness. If there is play or looseness when the wheel is fastened I don't know what to tell you.
THe front hub on my bike has rubber dust caps that do not rotate with the hub.
Liked 206 Times
While you have it upsidedown, very lightly apply the brakes to see whether the sound changes. I cannot see whether the brakes are touching, but as you apply them they may push the wheel slightly too one side before both pads grip. See if that changes the sound.
Thanks!!
Likes For KaraBarnes123:
