Shimano 12 Speed Dura Ace Cassette Installation
So I bought a new set of wheels to replace my non-tubeless wheels for my Aethos. I’m getting tired of flats.
The procedure for swapping over the cassette seems simple enough, but there are differing instructions about the subtleties, depending on your source.
This is a new Dura Ace 12 speed cassette going onto a Roval wheelset with the HG freehub. Nothing complicated.
1) Is there any consensus on applying a light film of grease on the outside of the freehub body? I’ve noticed the shops that have built up my bikes have typically applied a small film of grease to the freehub body to prevent corrosion and to make removing the cogs easier.
2) The shop I bought the wheels from said to apply Loctite to the lockring. This goes against everything I’ve read about cassette installation. To me, it makes more sense to grease, per the recommendation of most reputable sources, and tighten to torque.
3) Are there any miscellaneous washers, gaskets, or other parts on the cassette that I should be aware of? I know there are some spacers between cogs (I’ll be sure not to screw up the order). Any other parts I need to look out for as I remove the cassette from the old wheels?
I have Finish Line Teflon grease. I assume that will work fine for the freehub body and lockring?
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Liked 1,316 Times
I just installed the same 12sp cassette, greased the lock ring, nothing else.
40Nm (29’lb) and you’ll be fine.
There is a thin silver shim bonded to the rear of the largest spider. Just leave it there.
Don’t forget to test shifting before you ride it!
Last thing you need is to drop the chain between the cassette and spokes on the new wheels.
Barry
Barry
Don’t “quote” me on that. 8-)
You’re welcome, don’t “mention” it. 8-)
Bill fixed “mentions”. So we’re good to go there
Likes For Barry2:
I never put grease on free hubs. It can't hurt putting a little on so whatever floats your boat, I just don't see the need.
Never put loctite on the lockring. That's just stupid...it's supposed to be pretty tight, definitely doesn't need any help if properly tightened.
No, put the cassette on as it comes out of the box.
Barry
Barry
Di2 12 speed has been operating flawlessly. Only small nitpick is that the front caliper makes sort of a pulsing sound when braking. Sort of a machine gun frequency but very soft. I can’t find any sort of unevenness on the rotor and the rotor is true.
LR÷P=HR
Liked 1,316 Times
For Grease I use either some old black slop I've had for years, or if I can reach it easier a Copper Anti-Seize Lubricant.
Who cares what grease.... You're going to remove the cassette in 1000 miles and clean it........ right!
Brakes, are we talking MG42 fast or just Tommy fast?
Clean the rotor with IPA.
Not the beer,
Isopropyl alcohol (The rubbing stuff, (90%+ if you can get it easily)
Di2
Barry
Not the beer,
Di2
Barry
Make sure the caliper is parallel to the rotor.
Not the beer,
Di2
Barry
Not the beer,
Di2
Barry
Yes, perfectly parallel. Exactly centered. No runout.
LR÷P=HR
Liked 1,316 Times
Either way, it’s not my brakes!
or
its cheap, quick, easy, so give it a go and cross it off the list.
A couple of observations:
1) The metal clip doesn't fit snug around the pad like, say the SRAM clip would (where it actually holds the pads in place). I could imagine some kind of movement in the pads against the tips of this clip causing some kind of noise.
2) The pads weren't entirely smooth. I almost wonder if there's a little burr on the edge of the pad that is knocking into the edges of the caliper? I couldn't find any burrs or other issues on the rotors.
LR÷P=HR
Liked 1,316 Times
Mattie,
Welcome to bike forums.
You have woken up a Zombie thread, It's two years old.
Some frown on waking up old threads, not to worry, just thought you should know.
Your question should have been a new thread in the Mechanical area.
Yes you should go to E-Tube and change the cassette size in there.
The reason for this is Synchronized Shifting.
With Di2 in Sync mode, you change the Rear Derailleur (RD) and the system changes the Front derailleur (FD) & RD when it makes sense to do so.
The only way to know when to change FD and where to place the RD during that change is if the Cassette is of a known size.
A couple of pointers with Di2
1. Make sure you charge it with a USB brick rated at >1Amp
2. When using E-Tube be sure to "Disconnect" correctly, using the button in the Application.
If you don't Disconnect correctly, you wont be able to change gear,
All the best
Barry
All the best
Barry
Likes For Barry2:
Regarding the thin silver bonded shim mentioned above, how thick is it? I had a ring that was almost as thin as foil come off. The LBS added a spacer and now my bike shifts like crap. And I am wondering why the 11-speed cassette had no spacer and the 12-speed cassette does have one on the same freehub body. Seems counter intuitive.
