Crush washer for 2001 RockShox SID
Bikes: 1986 Schwinn High Sierra, 1989 Supergo Access Comp, 1989 Nishiki Pinnacle,1990 Trek 750, 1990 Trek 970, 1991 Miyata Quickcross, 1992 Bridgestone RB-2, 2002 Stumpjumper M4 Pro
Liked 311 Times
I did my first ever lower leg service and there may be the slightest of leaks from the right leg. Any suggestions for the type/size of crush washer to get? It's a 5mm hex bolt.
Btw, when I had the bolts off during service, the crush washer didn't seem to slide off easily... not at all in fact. Any tips or thoughts on that?
Thanks in advance!
Thanks in advance!
Most big auto parts stores carry crush washers. I would imagine some bike shops carry them as well, plenty of suspension bikes being sold these days. Not sure if it matters in this case if it's a copper or aluminum washer as I've purchased various motorcycle hydraulic parts where the replacement washer was not the same material as the original including forks that had the same bottom bolt setup as yours and never had any issues. Not uncommon for crush washers to spread and become hard to remove from bolts so if the new one slides on easy it's not an issue.
Likes For Crankycrank:
Liked 3,091 Times
the black plastic ring or crush washer is reuseable if its not damaged according to RS. you may find someone selling them separate but usually in the maintenance kits.I also have used oil resistant silicone sealer on the bolt threads and a smear on the bottom fork leg contact surface & worked well, after cleaning the surfaces well.https://mikesbikes.com/products/rock...3&gad_source=1
I tried this kits wiper seals & they would no fit into the fork no matter how hard I tried.RS says you must use a tool but I hammered on a socket & still no luck so I sent them back.sticking to enduro brand from RWC,but no crush washers included.
https://www.realworldcycling.com/pro...s/FSKRS30.html
Likes For '02 nrs:
Liked 311 Times
When the washer crushes it spreads out, so the hole that was 5.2 mm diameter is now 4.7 mm and that doesn't fit over the screw threads. Cut it with side cutters and twist it off with pliers.
