ISO and for trade thread part 5
#1751
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
I think there was a third version of the Accushift plus barcons which I've never seen.
#1752
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
Guess I need to tear these down and see if I can see what's going on. But I'll never use them ... so will probably just sell cheap instead.
#1753
Quoted: 1303 Post(s)
Liked 1,910 Times
The shifter set had the same spring in both left and right shifters, but they were installed in each separate shifter in opposite directions. The ratcheting wheels were the same and the clamping washers were both the same. The only difference was the orientation of the spring in the levers (which was designed in the down tube set to be a universal lever) The bar cons worked the same way, they just attached differently via the bolt through. The biggest problem with finding parts for these systems is the washers and spacers for the hold down on the shift levers.
As for the straight bar levers they were a different animal and had a two position setting, as they were a second generation lever. They had friction and six speed indexing and were specific to Suntour freewheel spacing. I may have a set around but it will be either NOS or removal from a working system which would hurt my monetary feelings. Smiles, MH
#1754
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
took can be posted, let's see. @dweenk Is this what you are looking for?
#1755
Liked 1,910 Times
francophile,
If yer gonna sell em shoot me an e-mail I have folks here in Bloomington who love them. Smiles, MH
#1756
Quoted: 887 Post(s)
Liked 335 Times
I went looking for MKS/Specialized pedal dustcaps and certain Shimano or Weinmann brake levers (no dice) but found a pair of SunTour friction thumbies. Hoping the pic I
#1757
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
ISO 26mm Campagnolo cassette lockring. Apparently they only made these from 1997-1998 or something. I just finished building a rear wheel, added the rim tape, installed a brand new tire, slipped on a brand new 9-speed cassette, and only then discovered that I didn't have the right size lockring.
If anyone can help me out, I'd be very appreciative. A local shop has a new one but they want $40. I'm hoping to avoid that, but I'd be happy to give a nice part in return in trade.
My Bikes
My Bikes
#1758
Quoted: 378 Post(s)
Liked 1,409 Times
ISO: 50cm Trek Y-Foil frame/fork. Not for me.
ISO: Campagnolo Record compact crankset, 8sp or 9sp, 170mm arms or smaller.
ISO: Racing T RD 8sp.
For Trade: 56cm Trek Y-Foil frame/fork.
For some/all of the following:
-9sp DA 7700 GS (med cage) RD
-Rolf Vector Pro wheelset (tubular OK, blue would be amazing)
-zero-setback polished seat post (at least not black) 27.2
-DA 7800/7850/7900 downtube shifters.
-28/32 Velocity A23 rimset.
-Black Campy calipers
-Soma Hwy One in 40cm
#1760
I *think* I have a Veloce 8s long cage which accomplishes the same thing with a bit less bling. Are you specifically looking for the one labeled Racing Triple? Started repainting my shop so I can't guarantee how long it will take to find the box it is in.
#1761
Quoted: 378 Post(s)
Liked 1,409 Times
But thanks a million. Maybe you can sell it at Brazen....if you find it. You really need a Y-Foil.
#1763
Quoted: 1199 Post(s)
Liked 1,354 Times
ISO: 3ttt stem 70-90mm...26.0 clamp...old logo
I noticed cracking on underside of mine.
FOUND ONE.
FOUND ONE.
#1764
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,091 Times
It’s gonna be a long search Rob. No such thing as 8 or 9 speed Campy compact. They didn’t come along until 10 speed era and AFAIK, only in carbon fiber in a square taper. You’ll need a triple or another brand to go smaller than a 39. I used FSA compact with 10 speed.
#1765
#1766
ISO: A junk Italian threaded bottom bracket shell. I only need good threads on one side. So, if that Italian threaded frame is heading to the dumpster and you feel like going at it with a hacksaw, think of me.
#1767
Quoted: 4510 Post(s)
Liked 6,377 Times
ISO/WTB Sugino Super Maxy TA clone crank arms 170, 172, 175, maybe 180, need both arms. TIA
https://www.bikeforums.net/attachmen...1&d=1312732428
#1768
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
#1769
Liked 6,377 Times
#1771
Bikes: large herd that needs thinning
Quoted: 13 Post(s)
Liked 7 Times
Misc Cogs for Trade
Not too sure what I have here but maybe someone has a need? 3 different types. First one has 2 connected cog pieces and have a big K and smaller S on it. One is 19-25 tooth and gold color and second piece with K S is 14-17. Super light. Second item is a 27 tooth cog
and has different center? Last item has 2 cogs? Thx
Last edited by Belg-Ital Steel; 11-21-19 at 06:39 PM. Reason: The two tone 8 speed cassette is no longer available.
#1772
Mavic Module E and/or H Plus Son TB14
ISO: Mavic Module E 700C 36h (need just a single, but will consider a pair)
ISO: Mavic MA2 pair 700c 36h
ISO: H Plus Son TB14 700c 36h pair (prefer silver but will consider other finishes)
Have to trade:
A bunch of classic 700c 36h tubular rims:
Mavic GP4, GL330
Wolber/Super Champion Arc en ciel (both polished and matte silver)
Mavic Sport/Normandy HF tubular wheel set (from a Gitane Interclub)
Suntour Bar End Shifters (early ratcheting type) with cables, down tube clip
Early 70's Aztec Lugged Peugeot U08 (24.5" ctt) blue complete bike (why not?)
Thanks!
Have to trade:
Mavic GP4, GL330
Thanks!
#1773
PM me your cotters
Liked 590 Times
You mind tossing in the old pulleys too? At least one looks to have some life left in it.
#1774
PM me your cotters
Liked 590 Times
Thanks!
#1775
ISO 27 mm seat post and binder bolt for Centurion Ironman I am building for my daughter. I don't have much to trade as far as seat posts go but do have a pair of Exage brakes , a new 14-28 7 speed Sunrace freewheel & some assorted chain rings someone might need. I can also do Paypal
