WTB: Suntour friction bar end shifters
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 469 Times
*Disregard - I'm going to try a different chain instead.
Hi,
I'd like to buy some Suntour friction bar end shifters for my 7 speed / triple setup on the Voyageur. Also open to other equivalent bar end friction shifters.
I currently have a Suntour Accushift Plus XCE group set, including Accushift Plus 7 speed indexing bar end shifters in nice shape. The indexing doesn't work properly once components like free wheels age out and aren't replaced with Suntour parts. I'd rather just run a friction set up.
Thanks.
Hi,
Thanks.
Why don't you just run the Accushift Plus 7 speed indexing bar end shifters in friction mode?
Quoted: 152 Post(s)
Liked 237 Times
@Ged117 Not to talk you out of a purchase but I thought the same.
I currently have the set up listed below on my Schwinn Premis and find the shifting to be great.
It flat out works.
This is information from @canklecat
Found at this link: Suntour indexing Bar End Shifters
It flat out works.
Balky index shifting with Suntour Accushift can be improved by switching to a SunRace freewheel and KMC Z72 or comparable chain (side plates formed to ease shifting). Specifically the SunRace 7-speed chromed 13-25 MFR30 and 13-28 MFM30. Shifting is much crisper and the chain rides more quietly than with the Suntour freewheels and any compatible chain I've tried including the original Suntour.
Quoted: 360 Post(s)
Liked 469 Times
It flat out works.
It flat out works.
Quoted: 838 Post(s)
Liked 1,082 Times
marius.suiram had some for sale awhile back I believe.
Quoted: 152 Post(s)
Liked 237 Times
If you have everything else in place and
if all that it will take is a new chain, why not try it and see for yourself ?
Chains aren't that expensive.
For myself, it was worth making the changes.
best,
Rick
Quoted: 360 Post(s)
Liked 469 Times
I've got a KMC Z72 on order. Thanks for the suggestion. I liked the Suntour indexing when it worked a long time ago with the original components.
Quoted: 152 Post(s)
Liked 237 Times
The only other item that I changed was cables and housing.
Riding a bike from the late 80's with original cables and housing, I felt I needed to change cables and housing while I was at it.
Am very very pleased with the end result, I hope you will be as well.
Best
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
Friction solves a lot of issues, I have found...never fails!
