Touring tires on rollers?
Old 09-13-20, 08:35 PM
MiE
Quoted: 13 Post(s)
Liked 4 Times in 3 Posts
has anyone used touring tires on rollers? I need some new tires (700x32c) for my bike. Looking at touring tires for winter. I don't have the money for another wheelset dedicated to indoor on a trainer but can't find any info on whether they work ok. Probably riding an hour total on the rollers and a 60 mile ride outside each week. Any tips or suggestions are welcome.
MiE is offline
Old 09-14-20, 07:20 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
I don't see why you couldn't pump up the PSI and use it on your rollers. I do not use special tires on mine...I have road bikes.
jadocs is offline
Likes For jadocs:
Old 09-14-20, 11:19 AM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,290 Times in 743 Posts
Knobbies make it more interesting.
phughes is offline
Old 09-14-20, 09:33 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
you can use foam filled captive air tires like Tannus, they're heavier rolling but you are into it for the fitness workout ,. right ?
fietsbob is offline
Old 09-16-20, 06:23 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
Rollers are dumb. just go outside and ride.
c_m_shooter is offline
Old 09-16-20, 11:01 AM
phughes
phughes's Avatar
Come up to the North in the dead of Winter and say that.
phughes is offline
Old 09-16-20, 11:08 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
You could, but they'll probably be loud and you'll wear off whatever tread is on those tires more quickly.
caloso is offline
Old 09-16-20, 01:54 PM
c_m_shooter
Quoted: 186 Post(s)
I have and do. I was raised on a farm in Greenford Ohio and lived in Kenosha Wisconsin for a couple years after I finished school. I carry a bike with me every time I go visit family whatever the season. The summer heat here can be as brutal as the cold winters there.
Old 09-16-20, 02:15 PM
phughes
phughes's Avatar
Great, then your statement made absolutely no sense. Yes, I commuted in the Winter, but I also had a bike on a trainer for exercise. I ended up stopping riding as much in the Winter around here due to the salt damage to the bike, and the fact here we have narrow twisty roads with very steep hills. By steep, in less than a mile from my house there is a +20% grade. The one I generally ride when I commute is around 15% within an eighth of a mile from the house. Couple that with snow, ice, curves, and idiot drivers, and you will see how rollers can make sense. It can get dangerous i the Winter. There are no shoulders, and sometimes the right of the road is an immediate hillside, and the other side of the road is a drop off, so no riding off the side of the road.
The heat you have isn't so bad, you lack much humidity. I used to live in West Texas, so I experienced the heat as well. When I lived in Branson, MO, I commuted on the hills there, with 50-88% humidity and temps between 95 and 105 the two Summers I lived there. Brutal with the humidity.
phughes is offline
Old 09-16-20, 07:56 PM
grolby
grolby's Avatar
Quoted: 288 Post(s)
Liked 86 Times in 60 Posts
I don’t think the question really called for this sort of negativity.
grolby is offline
Likes For grolby:
Old 09-16-20, 08:00 PM
grolby
grolby's Avatar
Quoted: 288 Post(s)
I haven’t used touring tires per se, but I have used a Panaracer T-Serv on a stationary trainer and it was noisier and made more vibration than a normal road slick. The problem would be less pronounced on rollers, but I would be prepared for some more noise and vibration. They won’t hurt anything, so if a little extra noise is ok with you, it should work just fine.
grolby is offline
Likes For grolby:
Old 09-16-20, 08:21 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Touring tires are for going places.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 09-17-20, 09:29 AM
phughes
phughes's Avatar
Tire wear on rollers is not bad. A trainer would be worse. I run my normal tires on a trainer, and wouldn't hesitate to run them on rollers.
phughes is offline
Old 09-17-20, 10:16 AM
blacknbluebikes
blacknbluebikes's Avatar
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times in 410 Posts
They will work, but if you're going to be on rollers a lot, you will be much happier changing to slicks. You don't need new wheels or anything, but it really is a big comfort upgrade over a couple hundred hours in the off season. Doesn't have to cost a lot.
blacknbluebikes is offline
