Anything else I should know about latex tubes?
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I'm trying out some Michelin latex tubes tonight (with Conti GPTT tires) for the first time, and just want to make sure there's nothing else I should keep in mind.
Installation and inflation when fine, so assuming I don't overheat the rims (which I don't anyway, and the TT course has minimal to zero braking), is there anything else I need to be aware of? I know they'll need to be inflated before each ride, that's not a problem, I always check my pressure anyway. From what I've read, it sounds like if you make it through the installation without popping them, and don't overheat them, they'll be ok. I did the talc thing, made sure no part of the tube was stuck under either side of the tire bead, and added an extra layer of rim tape just to be safe.
These are only going to be used for race days and for practices on the race course, not for regular daily riding, I'll switch back to my butyl/GP4K setup for that. Eventually they'll live full time on a set of TT wheels, but just wanted to experiment for now as I get more into this TT thing.
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Be VERY patient with installation. It's so easy to have a bit of the tube caught under the tire bead. Allow some extra time and play with the tube to coax it under the tire. You may want to inflate tube to 5 PSI and deflate again, check/recheck/triple check that it's not under the bead. Also be sure there are no rough spots on the rim.
Your patience will be rewarded. Your impatience will be punished.
Quoted: 733 Post(s)
Liked 815 Times
Liked 8,925 Times
Yup, that's pretty much exactly how I did it. I put extra talc on them, mounted one side of the tire bead, slightly inflated tube and mounted it, deflated, mounted other tire bead, checked that they weren't pinched anywhere under the tire, inflated slightly and double checked for pinches, inflated to 30-40psi and triple checked for pinches, then inflated all the way. Mounted both of them up last night with no issues and did a quick spin around the parking lot, gonna ride them on the TT course this evening. Rims are smooth with three layers of tubeless tape, so hopefully they'll be ok.
Let us know how you like them.
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 159 Post(s)
Liked 138 Times
I put Vittoria latex tubes on my everyday ride a few weeks ago. First time to try latex. Like you I used talc, installed carefully, and they went on without incident. I think I noticed a difference (suppleness, faster, better cornering, etc.) when I first rode on them, but after ~400 miles that feeling has become part of the overall feel of the bike and I don't notice it as an individual component anymore. What I do notice every time I ride now, is that they "sing" to me. I can hear a difference as they roll: a little bit of a higher pitch, a little louder than buytel. Music to the ears. I wouldn't hesitate suggesting latex as an every day tube.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
I only run latex tubes in my clinchers. Better feel, lighter, lower rolling resistance, and better puncture resistance. I do carry a butyl tube in my seat bag - latex can be a bit tricky to install on the side of the road in the rain or when you're sweaty - but other than that, there's no reason not to use them.
FWIW, the overheating thing is only an issue if you're cooking down major mountains on rim brakes on a regular basis.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Any advice? Sure...don't use petroleum jelly or any other petroleum based lubes.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Quoted: 1975 Post(s)
Liked 232 Times
Why not every day?
Quoted: 733 Post(s)
Liked 815 Times
First ride went really well. Picked up .8mph on three loops of the 7 mile TT loop I rode on Saturday (23.6 vs 24.4 avg). Can def feel the difference with the latex tubes and GPTT tires. I even set a new single loop PR, and my previous PR was set on a group ride, felt good to beat it solo. I also understand that since I'm still fairly new to cycling, my bike fitness is still improving, so that's prob part of it too.
Why not every day?
Thanks, I did read that!
Quoted: 733 Post(s)
Liked 815 Times
One more question, I ran the same pressure I normally run, 90/110, but this loop is pretty smooth, so I'm wondering if they might be a touch faster with some more pressure? I'm 6' 185lbs, so I keep the pressure up to avoid pinch flats, comfort level is fine for me. These are 23mm that measure out to 27mm on my 21c rims.
Quoted: 672 Post(s)
Liked 417 Times
...the main reason I don't run them on my every day bike is because I would hate pumping every day. Was running butyl in the every day commuter but have gone to tubeless now and you get the same supple feel and after the latex sealant migrates into the sidewalls you hardly lose any air
Run what you want, but a 30 second tire check and 2-3 pumps with a floor pump shouldn't stop you from running the technology you want to.
Quoted: 672 Post(s)
Liked 417 Times
Quoted: 733 Post(s)
Liked 815 Times
Adding the 5-10% that latex loses between rides isn't any more time consuming that adding the 5-10% my tubeless lose between rides. Even butyl tubes perform best if you check regularly, and they'll love 2-5% overnight. Checking tire pressure shouldn't be any more time consuming than checking to be sure your breaks work, tires, spin, and your chain is in decent shape.
Sounds like I'll def need to do some experimenting, allowing for average pavement, lil lower pressure might be better.
Quoted: 741 Post(s)
Liked 412 Times
It depends on what he means by pretty smooth. Lower pressure is faster on uneven surfaces. Smooth surfaces favor higher pressure. Track riders tend to ride higher pressure for this reason.
You should know latex degrades gradually and is susceptible to various solvents and oils. Butyl is not. I can recommend light 80 g butyl tubes. Seems less finicky to me.
Quoted: 733 Post(s)
Liked 815 Times
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Disk brakes won't heat up the rim...
Genesis 49:16-17
Genesis 49:16-17
Liked 8,925 Times
Quoted: 672 Post(s)
Liked 417 Times
Even smooth roads aren't as smooth as a good track. That contact patch is stil doing a lot of conforming to variations in the surface. But as I said, you don't have to take my word for it, do the reading. Try it out for yourself with a power meter and tire pressures at 5 psi intervals.
Quoted: 672 Post(s)
Liked 417 Times
FWIW, my only complaint about latex tubes is that I can't find latex tubes with long valve stems, so I have to use valve extenders on my deep section rims.
Is it safe to assume from those using latex tube here, that assuming I don't mount tires like a dope, there's nothing to worry about with latex? I'm been mulling over trying them also.
Quoted: 672 Post(s)
Liked 417 Times
Yes. Try them.
Advocatus Diaboli
Quoted: 4734 Post(s)
Liked 1,532 Times
Quoted: 741 Post(s)
Liked 412 Times
