What Pressure Do You Ride in Your Road Tubeless Tires
Don't Bug Me
I know you can ride tubeless tires at slightly lower pressures, but what PSI do you actually run in your tubeless road set up? Also, what is your tire brand and wheel combination?
They both feel faster. I feel the Ultegras roll much easier tubeless. The Mavics give me about ~1km/hr advantage starting at around 33kph, IOW, faster for the same effort at ~31-32 kph; aero, tubeless, or a combination thereof.
In terms of comfort alone tubeless is an absolute win, IMO.
I’m running 25s and weight 154lbs.
Non omnino gravis
90F/90R, 700x25 Giant Gavia AC1 on 19mm (internal) wheel.
60F/65R, 700x35 Pirelli Cinturato Velo TLR on 19mm (internal) wheel
Rider weight probably about 215lbs. Obviously the latter has a bit more comfort than the former, but I've lost my basis of comparison for clinchers. Exclusively tubeless for almost 2 years now.
63F/76R - Schwalbe ProOne 30mm on 21.5mm (internal) rims. I started at 60/70, but felt a bit squishy to me.
Tires measure just under 32mm inflated. I weight ~205.
Quoted: 1743 Post(s)
Liked 1,281 Times
Mavic Ksyrium Elite USTs w/25 tires. I weight 189 lbs ......Front 80-85 psi and rear 95-100 psi. Recommended by LBS and on line sites. Seems to be working well. On a CAAD 12 & a Guru Sidero.
Senior Citizen
Bikes: Trek Emonda SLR7 Disc, Lemond Poprad, 1980 Colnago Super, '88 Specialized Rockhopper
Quoted: 69 Post(s)
Liked 576 Times
I weigh 170 lbs.... Bontrager Aeolus Pro 3 TLR w/26mm Bontrager R3 Hard Case Lite TLR, 85 psi F, 90 psi R.
Quoted: 18420 Post(s)
Liked 15,563 Times
Before each ride I roll a pair of 9-sided dice and inflate to the higher of the two possible number combinations. So 99 psi. max and 11 psi min. Learned to do this on this forum.
Quoted: 4717 Post(s)
Liked 1,882 Times
55/60psi
30mm Schwalbe G-One Speed + Light Bicycle 56mm(23mm internal). I weigh 180 pounds.
They felt a little squishy on the way to work yesterday, so I checked the pressure. They were down to 35/38psi.
I weigh 135lbs, run 700x28 Conti GP 5000 tubeless on Aeolus Pro 5 wheels and normally keep the psi around 85 for both tires.
Note: I've only begin running tubeless and these wheels for the past week or so, previous to this I ran 700x25 Conti GP 5000 with latex tubes on some fulcrum OEM alloy wheels at around 85psi a tire. So, I might change to a lower PSI on my new tire/wheel combo in the coming weeks/months.
Quoted: 850 Post(s)
Liked 344 Times
Here I go:
front is a 17mm rim, 25mm tire. Rear is a 20mm rim, 25mm tire. I weigh 135lbs.
I run 40-60 psi in the front and 50-65 psi in the rear.
I use tubes. I have never pinch flatted. My secret? Sealant... in my TUBES I’ve felt my rim clobber square edges HARD but I’ve never lost enough pressure to notice.
SuperGimp
I usually go 80/85 or maybe 80/90 if I'm going to be out all day on 28mm schwalbe pro 1 (which measure right at 28mm on my WH6800 shimano wheels). i'm 225 right now.
It is noticeably more comfy than 100-110 that I ride on clinchers but not low enough to be squishy. If I stand up to power up a hill, I do feel a little bouncing out of the rear tire but it's tolerable.
28mm Schwalbe Pro-One.. 60psi
650x47 WTB Byways 30psi
650x42 Donnelly MSO 40psi
weigh around 185ish
weigh around 185ish
Quoted: 20810 Post(s)
Liked 9,456 Times
Non omnino gravis
Don't Bug Me
I’m new to the tubeless party and the info I’ve picked up in this thread and others has been a big help. I’ve got years of riding on rock hard tires and old habits are tough to break.
Anyhoo, after a lot of experimenting, it seems like 90/R (25mm) and 85/F (23mm) work well with my Reynolds AR 58/62 carbon wheels and Continental Force/Attack tires. I’m 162 pounds.
If anyone has any suggestions for me I’m all ears.
I'm 170lbs. One bike has Scope R3 wheels with Hutchinson Sector 28's and they run at 65f and 70r. Second bike has Schwalbe Pro 1 28's and I run them at 70f and 75r.
