Help me with my fit
#51
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The cheapest, lightest, strongest and most bike-uniquifying solution to your bar-end shifter problem is Retroshifts. Since you can reuse your shifters, $129 for a pair, minus whatever you can sell your take-off brake levers for.
Glad the 56cm is working out better. I look forward to the new pics.
#52
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
And hey, if you can stand taking your hands off the bar to operate the bar-end shifters, then you could probably stand taking your hands off the bar to operate DT shifters.
#53
Quoted: 276 Post(s)
Liked 6 Times
If got the Retroshifts, I can just reuse my bar end shifters? Is this a pretty easy DIY project? I have never replaced derauiler cables or adjusted them on my own but I've done brake cables and I'm good at watching Youtube videos and following along ;-)
If I can reuse my shifters, is it possible to just relocate the Retroshift brakes without re-cabling?
#54
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
If got the Retroshifts, I can just reuse my bar end shifters? Is this a pretty easy DIY project? I have never replaced derauiler cables or adjusted them on my own but I've done brake cables and I'm good at watching Youtube videos and following along ;-) If I can reuse my shifters, is it possible to just relocate the Retroshift brakes without re-cabling?
If you have done brake cables, you can do shifter cables. There are youtube videos aplenty, the park tool website is good too. It will be easy since you shouldn't have to adjust the limit screws at all (and especially not have to adjust the height/angle of FD!!), just pull the cable through again, pull it taut, tighten the pinch bolt, and then adjust tension at the cable stop. I'm guessing that the distance from barend out and back to cable stop is maybe a little longer than brake hood to cable stop, so you might want to trim the top cable housing a little bit. If you don't have a decent housing cutter, you can get clean cuts with a dremel with a cutting wheel. If you don't have that either, you can probably do OK with a hacksaw and clean up the end with pliers or an awl or something.
To install retroshifts you will definitely need to recable, as the cable needs to go through the little 'hood' above the brake lever. Also you will need to take off all of your bar-tape to get the old brakes off and the retroshifts on. Note Retroshifts are packaged with brand-new cables (shorter for the FD, don't accidentally install the long one on the front and trim it!). Even though your existing cable are new, they are squished a little at the pinch bolts. There's a good chance you can easily reuse them, but if they give you any trouble, it's probably worth it to just use the lovely straight new cables. Save the others for a rainy day, or trim the longer rear one for later use as a front.
Also if you re-pull your cables, you should consider crossing them to get a wider radius bend and neater-looking cable routing up front. Here's a current thread with more info.
#55
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
Actually I take that back, I think my Retroshifts came with cables because I had to buy the shifters too. Just Retroshifts with no shifters might not come with cables. You should be able to reuse, otherwise new cables are only about $1 apiece.
#56
Thread Killer
Quoted: 3143 Post(s)
Liked 1,707 Times
Retroshift are cool, but I'm not sure what about this application recommends them over a set of Sora STI levers, which can easily be had from Amazon or other sources for $135 including cable and housing. Short selling the old barcons for $50 shipped would probably get 'em gone on eBay in a day, plus another $25 for the brake levers makes net cost to throw on Sora STI roughly $70.
More than price, it's really a style issue, though for functionality in this app, I'd probably give a slight nod to the STI.
#57
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
The only thing I would add is, with the traditional brifters, you get shifting both ways from the drops. (These newer Soras have inner return levers, instead of the old thumb-button everybody used to complain about!) With Retroshifts, you lose shifting from the drops, but you gain whole-cassette shifts in a single movement.
So style, and that tradeoff. For me, whole-cassette shifting + style beat drops-shifting. But it's not for everybody. But the original fit pics give me a slight hipster vibe, and I'm thinking OP would like to have a bike which is not just another CrossCheck. We all like our bikes to make a statement about us...
Am I right rms? Are you a little bit of a rebel? Do you want to be different just like the rest of us cool kids? Here, get a little closer to this cliff, we're all gonna jump off on the count of pi: 1, 2, 3, 3.1, 3.14, 3.141...
#58
Thread Killer
Liked 1,707 Times
$135? checking amazon right now I'm seeing $167 -- which is still a good price. So yes, this way (minus take-off resale value) would be better cost-wise. So remove cheaper from the list of advantages, and you've got lighter and more durable, but for a commuter those characteristics are not too important. Thus it does come down to style. (Also, Sora is low-level (not that it really makes a huge difference), but even stepping up to Tiagra is a big price jump)
Though their real functional value is probably lost on road bike applications, I agree Retroshift is hands-down the cooler choice from a hipster style perspective. Hell, if style is worth anything, Retroshift is the obvious choice.
Here's the STIs I was looking at on Amazon, in the event pragmatism should have its way: https://www.amazon.com/Shimano-ST-340...d+bike+shifter
#59
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
#60
Thread Killer
Liked 1,707 Times
One thing to be said for the Sora setup vs. Campy's is that it avoids the accidental shifting that I've experienced from taking an unexpectedly jolting hit while riding light on the hoods. Nice, but I'd prefer to be able to shift from the drops if it's an either/or thing.
#61
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
Looks like Shimano changed Sora to inner levers since then; link
#63
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
As for the cockpit, it's got you sitting up a bit more upright than I would favor, but (a) looks like you've got the stem all the way up, max spacers, so you can swap around and experiment if you want lower, and (b) you might like upright.
#64
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
You could ride either the 54 or the 56. The Cross Check runs long on the top tube. I ride a 56 (my favorite bikes are 56 st and 56 tt) in most bikes but the 54 Cross Check has the same top tube length as my favorite 56cm road bikes. I prefer a more aggressive seating position and my bar tops are three to four inches lower than the seat crown just like on my road machines. I would not fixate on the numbers, the Cross Check top tube is low, the steering tube is short and the top tube is long for a given size frame. The Cross Check has become my favorite bike, the "56" feel too big for me. I am 5-10.5, 165 pounds, cycling inseam is 86cm. I am not convinced the first bike was a 54. But, your saddle is way too low in the pic. As the saddle goes up it also moves reward and you can further move the saddle rearward on the rails. Riders who like lower bars (like me) typically prefer the smaller frame, but that is a preference, every fit is a compromise and the truth is we can ride a range of frame sizes depending on our preferences and the purpose of the bike.
LC
LC
mtthwgss
Fitting Your Bike
9
02-28-14 02:30 PM
magilla
Road Cycling
7
10-29-10 10:57 AM
