Eye/Bar/Hub alignment?
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
Hey,
I am quite happy with my current fit, but I recently read there's a rule of thumb where the front hub should be blocked from view by the handlebars when you're in the hoods.
How accurate is this? For me, the front hub is pretty much halfway between my bars and my steerer tube, and it seems like it would be a pretty radical change to meet the rule of thumb. I guess the way to do it would be to switch to a really short stem?
Details; I'm 6' on a 60cm Surly CrossCheck, and I"m using a 110mm stem. If it makes any difference, the bottom of the stem is 46mm above the top of the headtube (what with thick aheadset, brake cable hanger, and 10mm spacer)
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
In light of this:
I wouldn't change a thing to conform to the rule of thumb, which is about as valid as the KOPS rule. Sounds like you just have extra-long arms.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 48 Times
I'm a believer in that rule of thumb, but I use it more to tell if the bike might be too "short" - bar appears to be "behind" the hub. If the bar appears to be "ahead" of the hub, but don't feel too stretched out, then that wouldn't worry me.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
Interesting; thx for the tip (about the tip)
That rule of thumb has a lot of history, but I don't think anyone knows why.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
I was looking more carefully, and when I am actually fully out to the hoods, the hub is 2/3 or 3/4 of the way towards the bar, in my field of vision's headset-bar gap. It's when I scoot back to rest my palms on the bends that the hub actually appears midway between headset and bar. So I guess I 'm even closer to meeting the rule of thumb.
Worked for us but if you are comfortable and feel efficient, good to go.
-Bandera
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,399 Times
Thx I'll check that on my next ride too
