Cycling and Fat loss
#176
Newbie racer
Bikes: Propel, red is faster
Quoted: 1033 Post(s)
Liked 783 Times
"Diet" as a verb should be stricken from people's vocabulary. "Diet" is most useful as a noun.
It's what a healthy human consumes day in and day out, mostly for lifetime.
It's not something you do once every 5 years once a doctor tells you of some pending disaster or ailment. Of course, it could be that should you find yourself in that situation.
But, treating it more like a noun might help one not find themselves having to use it as a verb.
If you want to argue keto and human history...........agrarian society has signs as far back as 23000 years ago. I'm not a "5000 years old Earth" person, but bread appears super early in the Bible also.
Meaning, it's disingenuous to claim keto is "the diet of our ancestors". It's not, unless you're talking about even more than 23000 years ago.
For reference, Neanderthals interbred around 70000 years ago. So, 23000 years is plenty of time for genetic adaptations to agrarian society.
It's totally unnecessary to try to draw that parallel to justify keto because it doesn't make sense. People didn't start getting obese and diabetic at modern rates until maybe 30 years ago. Maybe 50. Not 23000 years.
#177
It only demonstrates that exercise is not a magic bullet that will transform an obese individual to a fit, healthy one in 4 wks.
What the study found was that with a very moderate amount of exercise (1760 Cals/wk) 75% of the individuals lost weight. On average they lost over 3lbs in 24 wks using exercise alone (they also increased their food intake). It's not rapid weight loss but most people don't put weight on quickly either. The point is if you can incorporate regular exercise into your lifestyle weight becomes much less of an issue. With obese individuals the amount of exercise they can manage will go up over time as they become more fit and drop weight.
I'm 59 and manage to average about 6000 Cals/wk of exercise during the year, so fairly certain a teenager could easily manage 5000+ Cals/wk of exercise. Yes, they may need to increase food intake but should be fairly easy to drop some excess fat. None of this works, of course, if you can't find some exercise that you enjoy doing on a regular basis.
No need for fancy diets. Exercise regularly and eat a balanced diet with lots of fruit and veggies.
Or you can take the 500 Cal off of daily intake? 50/50? Sounds good to me. It's probably what most people end up doing. This Keto stuff though ...?? I don't know the first thing about it. I do know from Low Carb. We all know what carbs are. It doesn't need to be harder than eliminating the 'worst' of what we call carbs: the simple sugars, and sharply reducing intake of the more complex carbs. I believe what people call a "Mediterranean Diet" accomplishes those goals. A person could take it even further and try to eliminate carbs altogether. Try being the operative word. What you end up with is probably sustainable for a long time and you will need a long time. The 50lbs. are not going to be gone in one month! But if a diet is asking you to add fats ... melt sticks of butter into $10/lb. coffee ... IDK ... there is such a thing as trying too hard ...
Likes For Leisesturm:
#178
Quoted: 11 Post(s)
I must have totally missed where you mentioned kidney stones in your original post:
Still not seeing it. But don't worry, this study with 10 whole participants doing a diet for 5 days shows that a vegetarian diet has slightly less uric acid excreted than an omnivorous diet has me convinced. Never mind that, by showing how the body regulates acidity, this study specifically refutes your statement about the body's pH levels changing.
Just give it up already. A plant-based diet is not inherently healthier. It beats a standard western diet, but then so does pretty much every other diet, including ones that are essentially the polar opposite of veganism.
That, at least, is generally true.
This is not. Fewer animals are harmed, but lots of animals still die in order for you to eat.
From your link on nutrition facts:
But he's totally unbiased right?
Yep... totally unbiased.
How very scientific of him.
I'm actually wondering if that article is a parody. Dr. Oz? Well, that settles it.
The article then links to a video discussion the evils of eggs... something that mainstream science considers to be quite healthy.
#179
So someone with a serious amount of weight to lose ... cycling (this is a cycling forum!) is not going to cut it.
Teens? Why are we bringing teens into this anyway?
#180
I'm cross-chained
Quoted: 4228 Post(s)
Liked 3,208 Times
Low-Carb, High-Fat: Nina Teicholz on why you should eat butter, meat, and cheese
Podcast with Amy Alkon and Nina Teicholz
#182
Quoted: 957 Post(s)
Liked 245 Times
Weight loss is mostly about diet... but the idea that you can't burn a fair amount of calories through exercise isn't true either.
#184
Likes For wolfchild:
#186
Quoted: 11 Post(s)
Non omnino gravis
Likes For DrIsotope:
#188
I'm cross-chained
Liked 3,208 Times
Keto-vegan cage match!!!!!
#189
Non omnino gravis
No judgements, but every full-bore vegan I've ever known has been a top-tier ranked "sick all the time" type of person. Always made me wonder.
Counterpoint, every keto-adherent has been just... obnoxious. "Oh... I can't eat that. Or that. Or that, or that. I'll just have a burger patty with nothing on it. What grade is the beef?"
#190
In 1977, dietary recommendations (called Dietary Goals) created by George McGovern’s Senate Select Committee advised that, in order to reduce risk of chronic disease, Americans should decrease their intake of saturated fat and cholesterol from animal products and increase their consumption of grains, cereal products, and vegetable oils. These Goals were institutionalized as the DGA in 1980, and all DGA since then have asserted this same guidance. During this time period, the prevalence of heart failure and stroke has increased dramatically. Rates of new cases of all cancers have risen. Most notably, rates of diabetes have tripled. In addition, although body weight is not itself a measure of health, rates of overweight and obesity have increased dramatically. In all cases, the health divide between black and white Americans has persisted or worsened.
#191
I'm cross-chained
Liked 3,208 Times
[QUOTE=willibrord;21046813]https://thescienceofnutrition.wordpr...cal-fallacies/
"In 1977, dietary recommendations (called Dietary Goals) created by George McGovern’s Senate Select Committee advised that, in order to reduce risk of chronic disease, Americans should decrease their intake of saturated fat and cholesterol from animal products and increase their consumption of grains, cereal products, and vegetable oils. These Goals were institutionalized as the DGA in 1980, and all DGA since then have asserted this same guidance. During this time period, the prevalence of heart failure and stroke has increased dramatically. Rates of new cases of all cancers have risen. Most notably, rates of diabetes have tripled. In addition, although body weight is not itself a measure of health, rates of overweight and obesity have increased dramatically. In all cases, the health divide between black and white Americans has persisted or worsened."
At first I couldn't figure out why you posted a link to an article that so thoroughly debunks Teicholz, but then realized you thought you were proving something with that quote. Thanks for the laugh, I have never seen a more blatant case of someone not understanding what they're linking . and quoting absurdly out of context.
You do realize that the article you linked that contains that quote actually does so to completely debunk it, right? Teicholz lied about all of the cardiovascular trends, which have all gotten much better during the time period she's discussing, and cancer rates have remained fairly steady.
Try actually reading the article you linked instead of just incompetently quote mining and you'll learn why Teicholz is completely full of bs.
#192
[QUOTE=livedarklions;21046839]
Keto works:
read this article
https://www.bikeforums.net/newreply....ply&p=21046839
read this article
#193
I'm cross-chained
Liked 3,208 Times
[QUOTE=willibrord;21047233]
No. You have wasted enough of my time. /Ignore.
Likes For livedarklions:
#194
Quoted: 79 Post(s)
Liked 65 Times
I don't know of a form of exercise that burns more than 600 Cals/hr. YOU might be able to devote 10hrs/wk to an exercise program but today's teenagers have crushing school workloads and school phys ed programs have been slashed to nothing and the intramural athletics promote team sports that are largely anaerobic, and most players spend more time on the bench than on the field anyway.
But I'll add: rowing, jogging (even slowly), jazzercise, basketball, water polo, swimming. I mean, there are more exercises than any one person could possibly ever want to do. Even then, a person doesn't need to actually burn 6,000 calories a week or go at a high intensity for all the time he's exercising. We have enough studies to know that HIIT is very beneficial and you can combine that with some strength training.
Likes For guachi:
#195
Non omnino gravis
#196
My point isn't to collect exceptions to my point. I mean ... look at how far you people have to reach to find them ... seriously ... 200 watts for an hour? ... how many people with 50lbs. to lose are capable for sustaining ... hell attaining, 200 watts output? Rowing? I average 80 to 100 watts @30spm, and do intervals where I might hit 150W peaks. I challenge the average punter do do better than that. But come on, we are talking about using up excess calories on a daily basis, not post Strava KOM's. The 50lbs on your waist might be appear to be static avoirdupois but everyday, people are adding 1600 to 2000 and more (lots more) to the metabolic balance sheet and some of that is bound to wind up as 'static' avoirdupois on their stomach and backsides. It is a moving target that people are trying to treat like a fixed one. HIIT is great if you can. Those who can, don't seem to have a lot of understanding of how special their situation is.
Since you must also address the ongoing daily intake of calories, the best way to do that is through some kind of balanced food intake reduction. Not 'low carb', not 'vegan', not anything special, except a balanced reduction in food intake. Fairly drastic reduction at that. I know a couple of sedentary women that have ONE meal a day and are not skinny! Just one meal can provide sufficient calories to maintain weight. The main reason a Keto diet isn't sustainable long term is because of the geo-politics of agriculture. A meat/fat based diet is simply financially unsustainable for most Americans. In much of the world people pay rent by the year. And what they pay in a year is what an American pays in a month. And I'm not talking about Cambodia or Bangladesh.
Maybe in Western Europe you aren't going to pay $1200/yr. for rent, but you are NOT going to pay $2500 for a root canal. You don't HAVE to have a $30K car to get to work everyday. You can afford meat, butter, eggs, etc. to excess. Americans think they can, but every month they are going >$500 in debt on their credit cards to sustain what isn't even a Middle Class lifestyle anymore. Without even realizing it we bias our diets to the carby side of things because it is more financially sustainable to do so. Carbs are cheaper sources of nutrition. Period. Keto appeals to those who (think they can) afford it like many behaviors humans engage in. The Achilles heels of all these 'diets' being discussed is that by definition they are term limited. Once a specific goal of weight reduction or blood pressure level or blood sugar level ... once the 'goal' has been reached, the person subjected to the torture is only too happy to end the diet program and ... well you all read these forum posts just like I do. How many are on their second and third cycles of weight gain/loss? At the end of the day, prevention is always better than cure. Do not allow yourself to become morbidly obese, because getting it under control is way more difficult than it is being made out to be here. It's damn hard, and fairly expensive to do. But even more important is to realize that, like a recovered alcoholic, once you have come back from morbidly obese territory, the methods that brought about the weight loss must be normalized. You can never 'eat normally' again. That sounds awful but its all in the interpretation. I didn't have 50lbs. to lose but I do have an A1C that I'd like to get below 6 and keep it there. The way I eat and the exercise regimen that I have adopted have to be maintained for as long as I live. That's just the way it is.
Edit: Bonus weight loss and Super Saver tip: whatever you served yourself for dinner ... eat half of it, and eat the other half for lunch the next day!
#197
I'm cross-chained
Liked 3,208 Times
#198
Non omnino gravis
I could stand to lose 30lbs, and can sustain 200W for several hours, not just one. Being fatter doesn't make me weaker, it just makes me slower up hills.
I'm not providing an exception to the randomly chose "600kJ/hr" figure-- I'm saying that's right around my average. A typical day at endurance output (mixed Z1/Z2) will see 33-36kJ/mi, combined with an average pace of 17mph makes for 560-610kJ/hr.
Even at that, I'm not losing weight. I'm maintaining it, poorly at times, because I can top 4,000kcal a day several times a week. Eating is easier than cycling, that's for sure.
#199
I WAS doing really well with my weight....then due to my disease Sarcoidosis moving into my bone (still better than the bone cancer or lung cancer they thought it might be) I had to go on Prednisone for a year and a half. Not only did I put on close to 50 lbs it moved my fat from my legs and hips to my stomach area. Its been almost a year I think since I weaned off it (still on Methotrexate for 1 more month) It did do what it was supposed to and put me into remission. But it is so hard to drop the pounds now when the hormones are all out of whack (side effect of pred supposed to start straightening up at the 1 year point) But I keep plugging at it.
I swim on most days I don't bike, now lap swimming is a serous way to use calories. 45 min was about 1200 cal. But the pred came with a price too, the joints are worse, and I had to take 3 weeks off in Dec to have a small skin cancer heal from my face-it did hardly a scar. But in 3 freaking weeks my shoulder went from doing laps to nope, nada, oh crap I can't put my arm up. It took 3 months to be diagnosed with a frozen shoulder, in which I was scared to move my shoulder since it felt like I was ripping stuff in it.
I still was in the pool and on the bike but careful and jogging in the water not laps. After a couple of months of PT I just started doing laps again, it is painful. But after a few laps the shoulder loosens up and it get easier. I can do about 20 30 minutes, but its nothing like I used to, and I have to mix it up a lot as the weak muscles get sore. But I will get there.
I do have to say the running helped my biking a lot. And I have seen a reduction in size a bit... very little. But I will keep on plugging away. But as we all know we walk a fine line of over use and under use... especially with my joints. I will make certain of one thing, my shoulder joints will be used daily as I never want to freeze up again!
Getting older sucks!! But the exercise makes it worth it, I swear it is an addiction. Gotta keep moving, to stop is to freeze up....
Likes For Marci:
#200
Hi to all, I am a 16 year old and although I do have a good physical shape I would just like to ask if cycling can help with loosing belly/waist fat. I also do upper body/back/core training aswell but Im just looking for an answer if cycling can effectively help with excess fat loss around those areas.
You'd do better to run slowly in combination with weights and eating less.
