Chain Ring Guard/Chain-wheel Protector
Old 05-04-20, 01:36 AM
JackieYan
JackieYan's Avatar
Bikes: Merida Big Seven
Quoted: 8 Post(s)
Liked 10 Times in 7 Posts
I hope I can explain myself clearly, as I donít know all the names of the different parts. Iíve looked the parts up from a drawing, so hope Iím using the correct names.
Iím looking for something to cover the crankset/outer chainring on the front crank.
My problem is when sitting at traffic lights, for example, and I turn the crank to get it in the right position to move off, I sometimes rub the inside of my leg/sock along the chain itself, becoming covered in oil.
I googled, and ebay came up with something called ďBicycle Crankset Cap Bike Chain Wheel Cover ProtectorĒ
It looks to me like it screws into the crankset and is a larger diameter than the outer chainring. To my mind Iíd hope that would prevent me touching the chainring and chain?
The one I saw said, ďThis bike chain cover is available as long as your bicycle tooth tray is 42T, 44T, or 46T. To use this cover, you must have screws in the crank hole of your bikeĒ
I have four unthreaded holes in my crankset.
I have a Merida Big Seven 300. I counted the number of teeth on the outside chainring(?) There are 40. The chainring is almost 17cm in diameter (including the teeth)
Or perhaps someone can suggest a better/easier alternative to stay clean?
JackieYan is offline
Old 05-04-20, 04:25 AM
Ross520
Quoted: 173 Post(s)
Liked 172 Times in 99 Posts
Why not just be more careful?
Can't say I've ever gotten a chain tattoo rotating my crank.
Ross520 is offline
Old 05-04-20, 06:11 AM
hillyman
WALSTIB
hillyman's Avatar
Quoted: 280 Post(s)
Liked 374 Times in 180 Posts
Might be tough to find one that will fit your particular crankset if even exists or will even work at all. Some cranksets come with a factory one already installed but that's another can of worms if will work with your system. Maybe somebody here more of an expert but I basically agree with Ross520, you will learn easier to keep your leg out of the way than hours trying to find, buy and install a guard that is a coin toss on fitting.
www.bikeleague.org
hillyman is offline
Old 05-04-20, 06:48 AM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1108 Post(s)
Liked 1,162 Times in 788 Posts
I hope I can explain myself clearly, as I don’t know all the names of the different parts. I’ve looked the parts up from a drawing, so hope I’m using the correct names.
I’m looking for something to cover the crankset/outer chainring on the front crank.
I googled, and ebay came up with something called “Bicycle Crankset Cap Bike Chain Wheel Cover Protector”
It looks to me like it screws into the crankset and is a larger diameter than the outer chainring. To my mind I’d hope that would prevent me touching the chainring and chain?
The one I saw said, “This bike chain cover is available as long as your bicycle tooth tray is 42T, 44T, or 46T. To use this cover, you must have screws in the crank hole of your bike”
My Norco came with a chain ring guard like that, and it does keep my pants off the chain ring, but it doesn't keep my pants off the chain. Due to that, I simply use a velcro strap around my pants leg on that side to keep my pants snug against my leg.
IMO, a chain guard that at least covers the top run of the chain and half of the chain ring is much better than a just a chain ring guard. But that's probably going to be something not easily mounted to your bike.
FiftySix is offline
Likes For FiftySix:
Old 05-04-20, 07:43 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1478 Post(s)
Liked 974 Times in 660 Posts
What crankset does your bike have. Determine that and then what the BCD of the chainrings are and search "bashguard 40T XXX BCD" for whatever BCD your crank uses.
dedhed is offline
Old 05-04-20, 07:45 AM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 919 Post(s)
Liked 532 Times in 370 Posts
MRP makes some.
2cam16 is offline
Old 05-04-20, 07:57 AM
GeezyRider
Another Bozo on the Bus
GeezyRider's Avatar
Bikes: Panasonic DX-3000, Trek Multitrack 720, Mercier Galaxy SC1, Raleigh Pursuit, Retrospec Judd, Rans Stratus LE, Catrike Trail, EZ-1 SC, BikeE E2
Quoted: 64 Post(s)
Liked 103 Times in 68 Posts
To go along with the advice from dedhed, here is how you measure the bolt circle diameter (bcd):
https://www.wolftoothcomponents.com/...e-diameter-bcd
You also will have make note of whether you have a 4 or 5 bolt pattern on the chanring.
Don
GeezyRider is offline
Likes For GeezyRider:
Old 05-04-20, 09:23 AM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M27R & M6R, Dahon HAT060 & HT060, ...
Quoted: 540 Post(s)
Liked 123 Times in 101 Posts
Fitting chain protection is notoriously difficult and depends on bike details. The options include placing an outer disk, and there following the directives of dedhed and GeezyRider, and/or mounting a chainguard that extends backwards over the chain. A good source for both is AliExpress but with long delivery times. Also a lot of browsing, looking at details, is required. Given low prices, long delivery times and high chances for mismatch, it is presumably advisable to order two or more solutions, hoping that at least one will work.
2_i is offline
Old 05-04-20, 09:50 AM
JackieYan
JackieYan's Avatar
Quoted: 8 Post(s)
I'm not over technical on this. If I only knew what BCD means?
According to the Merida spec - if I'm quoting the right thing, it says FSA Alpha Drive, then "36-22 teeth". I 'don't understand that, as the front crankset has 3 "chainrings", and as I said that I counted the outer (largest) one which has 40 teeth.
I can attach a photo if you need - let me know, but this is the Merida page https://www.merida-bikes.com/en/bike/56/bigseven-300 if it helps?
Thanks.
Old 05-04-20, 10:09 AM
dedhed
SE Wis
dedhed's Avatar
https://www.qbp.com/diagrams/tech_co...crank/bcd.html
dedhed is offline
Old 05-04-20, 10:15 AM
AlmostTrick
Tortoise Wins by a Hare!
AlmostTrick's Avatar
Quoted: 1451 Post(s)
Liked 749 Times in 401 Posts
I've ordered several bash guards from BBG, and have been very satisfied.
https://bbgbashguard.com/shop?olsPage=products
AlmostTrick is offline
Likes For AlmostTrick:
Old 05-05-20, 12:49 AM
JackieYan
JackieYan's Avatar
Quoted: 8 Post(s)
Thanks dedhed and AlmostTrick for those two links.
Iíve had a look at the BCD for chainrings.
I measured the distance between the two holes (my FSA Alpha Drive has four)
It was 67/68mm, found it difficult to be certain.
To my mind, that gives a BCD of 94.73 for 67mm B measurement
or
a BCD of 96.15 for 68mm B measurement
Now looking at the BBG bashguard website, I see it has products listed by BCD. I want something larger than the BCD measurement, as that is less than the size of the whole chainring.
Am I right in guessing if ordering by BCD, the bashguard diameter allows for this, and is actually larger than the outside diameter of the crankset, so it overlaps the chain by a certain amount?
I can only see one 94BCD and one 96BCD.
The 94BCD has five mounting holes, so would I need the 96BCD, as that has four mounting holes like my crankset?
Next question: What is 30T or 34T? I need to select one of those. Is that something to do with the number of teeth?
The Merida spec says my FSA Alpha Drive has ď36-22 teethĒ. Again guessing thatís the middle and inner chainrings, as I counted 40 teeth on the outer one (not easy to count the other two).
As an aside, I've already contacted BBG to ask if they ship to Thailand, where I live. They do and ship via USPS for $14, although I don't know if that's surface or airmail (even if it's available right now?)
Old 05-05-20, 07:35 AM
2cam16
2cam16's Avatar
Quoted: 919 Post(s)
Usually the tooth count is etched on the chainrings. Check both sides of each chainring.
2cam16 is offline
Likes For 2cam16:
Old 05-05-20, 07:59 AM
JackieYan
JackieYan's Avatar
Quoted: 8 Post(s)
Thanks for that bit of information.
So far I can see the largest one has "40T" on it.
The other two are more difficult to see, not only because you can't see all of the chainrings easily.. I'll try again in the morning in daylight.
Old 05-05-20, 08:13 AM
Kapusta
Cyclochondriac
Quoted: 1739 Post(s)
Liked 1,003 Times in 604 Posts
I suggest you do some googling to familiarize yourself with a few terms:
Double crankset (or 2x) vs Triple crankset (or 3x)
Chain-guard
Chainring
Crankset.
Also, look at your crankset and see if you can find a model number.
You are getting a bit of advise here from people who are not reading what you have written, and could lead you down the wrong path.
Kapusta is online now
Old 05-06-20, 03:06 AM
JackieYan
JackieYan's Avatar
Quoted: 8 Post(s)
Chain-guard
Chainring
Crankset.
Which of the terms do you think I haven't understood (it's a straight question).
I have an image of a bicycle I downloaded to find the names of the parts, as I didn't know them, and have used those names.
The heading I used "Chain Ring Guard/Chain-wheel Protector" was copied from an eBay advert, as I wasn't sure of the name of the item at the time.
The double crankset and triple crankset I follow, as that's the number of chainrings on the crankset.
What I don't understand is from the Merida spec, it just says "FSA Alpha Drive" and below it "36-22 teeth"
That indicates to me it's a double crankset? Yet it has three chainrings, the largest being 40T.
You asked if I could see a model number. did you mean other than the Merida listed one, which it says on the chainring and the crank arm ? - "FSA Alpha Drive"
On the 40T chainring it says "M-10", if that's relevant?
I've tried to see the number of teeth stamped on the other two chainrings. I just can't get at them to see, and short of taking every apart, trying to clean them isn't easy as they are both overlapped by the 40T one.
Old 05-06-20, 04:40 AM
AlmostTrick
You don't need to know the tooth count of the smaller chainrings. You only order based on largest ring tooth count and BCD. (and 4 or 5 bolt, obviously!) Some like to run a slightly larger (higher tooth count) bashguard for a little extra protection. I've done this at least once.
