Old Giant Iguana needs TLC
Old 05-05-20, 03:48 PM
synonymy
Hello and good day everyone..
I have an old Giant Iguana 26"wheel mountain bike that has no suspension that has a worn out drivetrain that I would like to replace if possible.
The original was a 21 speed I believe, but I am open to making it into something with only one front crank sprocket if possible.
In essence, I can see turning it into something just for the roads and easy trails, no knobbies or anything, just easy running tires etc..
Can anyone offer some pointers and possibly some links to hardware that can make this bike run again?
I am open to making it into a single speed as well, but I imagine that's not easily possible?
Not looking for space grade materials either.
I like the schwalbe big apple tires.
Thanks for any info you can offer
Scott
synonymy is offline
Old 05-05-20, 07:06 PM
GeezyRider
Another Bozo on the Bus
GeezyRider's Avatar
Bikes: Panasonic DX-3000, Trek Multitrack 720, Mercier Galaxy SC1, Raleigh Pursuit, Retrospec Judd, Rans Stratus LE, Catrike Trail, EZ-1 SC, BikeE E2
Quoted: 64 Post(s)
Liked 103 Times in 68 Posts
These are before and after photos of a Giant Iguana I rescued from a dumpster at my Sister in Law's condo. The after is a rattle can paint job and some of the mods you are proposing for your bike. Fun project.
Don
GeezyRider is offline
Likes For GeezyRider:
Old 05-06-20, 02:33 AM
Korina
Happy banana slug
Korina's Avatar
Bikes: 1992 Specialized Rockhopper Sport, 2016 Giant Liv Rove Lite, 1995 Trek Singletrack 930, 1994 Trek Multitrack 750
Quoted: 780 Post(s)
Liked 441 Times in 300 Posts
Scott
The Classic & Vintage forum is where you want to be; the mtb. upright conversion thread has lots of inspiration.
Korina is offline
Old 05-06-20, 09:36 AM
Ogsarg
Quoted: 485 Post(s)
Liked 683 Times in 296 Posts
I actually have an old Giant Iguana that I think was bought around 92. That is what I used to get back into riding 4 or so years ago and still ride it regularly. Mine is a 3 X 7 Shimano Altus setup and I've had no problems finding replacement parts and pretty inexpensively.
When I first got it out of storage, I found the rear wheel rim bent and purchased a used replacement wheel from my local bike shop. I think he charged me 15 bucks. Both trigger shifters were gummed up and I found replacements on amazon. I think those were less than 20 for the pair. The originals were a combo brake lever/shifter and the replacement was just the shifter so I took a dremel to the old levers to cut off the shifter part and have both mounted on the bars. There are plenty of tires available for the 26 X 1.75 rims from knobbies to slicks so you can run whatever tires you want. I have Schwalbe Marathons on mine. I also cleaned and repacked the bearings on both wheels and the fork bearings.
I think that is all I did just to get it in good working order initially. After riding it regularly for a while, I noticed a grinding sound in the bottom bracket so got a replacement for that, which was I think less than 20 bucks. The two larger ring gears were pretty worn so I found a replacement crankset on amazon that was around $40 and figured since I was doing that, I'd get a chain and cassette as well, neither was very expensive.
All that stuff was easy to find. Search for parts using Shimano Altus in the search.
I ride this bike in the early mornings and sometimes in the winter when the weather is lousy so I've also added fenders. Right now I'm putting 50-60 miles a week on it and it's quite reliable.
Ogsarg is offline
Likes For Ogsarg:
