Squealing brakes (new pads, toed in)
Old 05-26-20, 07:19 AM
majhi
Quoted: 5 Post(s)
Hello all! I recently purchased a new bike (with V-brakes) and the front brake pads that came with it are really loud (but not the rear brakes, which are fine). I've already toed the pads in and adjusted the cable tension to varying extents in my attempts to fix it with mixed success (depending on toe angle). I've now gotten them quiet-ish, but they still squeal a bit. This leads me to two questions: 1) once the brakes have been broken in after a few rides, will this problem be resolved, and 2) could it be the compound of the pads themselves? Thanks in advance!
majhi is offline
Old 05-26-20, 08:20 AM
Chuckles1
Bikes: 1981 Raleigh Super Grand Prix, 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike)
Quoted: 76 Post(s)
Liked 52 Times in 37 Posts
Don't know if it will resolve, but could be the compound. I recently got new aluminum wheels and had squeal and shudder on front with dual compound Kool Stop black and salmon V brake pads. I put on a set of Red Kool Stops, and braking is quiet, smooth, and strong. I think the red pads are soft relative to the black and salmon.
Chuckles1 is offline
Old 05-26-20, 08:28 AM
GeezyRider
Another Bozo on the Bus
GeezyRider's Avatar
Bikes: Panasonic DX-3000, Trek Multitrack 720, Mercier Galaxy SC1, Raleigh Pursuit, Retrospec Judd, Rans Stratus LE, Catrike Trail, EZ-1 SC, BikeE E2
Quoted: 64 Post(s)
Liked 103 Times in 68 Posts
Two easy things you can try are rubbing the brake pads over some sand paper and cleaning the braking surface on the rim with alcohol. This has worked for me in the past.
Don
GeezyRider is offline
Likes For GeezyRider:
Old 05-26-20, 06:14 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1499 Post(s)
Liked 455 Times in 270 Posts
My first trick is to dress up the brake pads with a fingernail emery board. It's just the right grit, it's nice and flat, and my wife (unknowingly) buys them for me. That works about 90% of the time. The other 10% can be a PITA.
Retro Grouch is offline
Old 05-27-20, 06:28 AM
majhi
Quoted: 5 Post(s)
I tried sanding them down a touch with an emery board and also wiping the rim with rubbing alcohol. Neither trick seemed to work.
majhi is offline
Old 05-28-20, 07:01 AM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1226 Post(s)
Liked 326 Times in 215 Posts
Is this a cheap dept. store bike by any chance? One thing that can cause squeal is cheap calipers that flex under braking. In that case, the fix would be to replace the cheap V-Brakes with some better quality ones.
BlazingPedals is offline
