Better grips?
Better grips?
The grips on my Trek Verve2 are functional. My main complaint is that they slip/turn on the bar easily. Is there such a thing as a grip that doesn't do this? Ideally if there was a grip that doesn't slip and was even more comfortable it would be ideal.
Gyro Captain
Bikes: Sycip, Black Mountain Cycles, Kona, Fairdale, WeThePeople
Quoted: 112 Post(s)
Liked 270 Times
Tons of companies make lock-on grips that use allen bolts to secure the grip to the bar; any local or online bike shop will carry them. They work great, but because they have a stiff inner core, I don't find them to be as comfortable as non-locking grips.
With proper installation, non-locking grips shouldn't twist. Swish some rubbing alcohol inside the grip, and slip them onto your bars. Once on, you can shoot some compressed air between the grip and the bar or use a hair dryer to accelerate the evaporation. Otherwise, wait a day and they should be solid.
I'm using ESI silicone grips these days, and using the method just described, they really stay on the bars, to the point where it's a bit of a pain to take them off!
Hope this helps!
Hope this helps!
Likes For Rolla:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 6555 Post(s)
Liked 2,127 Times
But if you want to stabilize existing grips you can remove the grips, spray some hairspray (aquanet extra super is good stuff) in a grip and slide it onto the bar quickly, let sit for a couple hours. Some guys even go nuts and use spray paint. On the milder side, sometimes removing the grips, cleaning the bar with rubbing alcohol, then pouring a little rubbing alcohol into the grips and quickly pushing them on the bar and letting them sit for a while will sometimes be enough to make them stick.
Bikes: Aluminum Xootr Swift; Reynolds 853 hardtail MTB; Titanium mini velo
Quoted: 30 Post(s)
Liked 21 Times
I use Ergon grips on all my flat-bar bikes - huge improvement over any other grips I've used.
https://smile.amazon.com/Ergon-42410...4-135149aa9081
Likes For Trocadile:
Another Bozo on the Bus
Bikes: Panasonic DX-3000, Trek Multitrack 720, Mercier Galaxy SC1, Raleigh Pursuit, Retrospec Judd, Rans Stratus LE, Catrike Trail, EZ-1 SC, BikeE E2
Quoted: 64 Post(s)
Liked 103 Times
+1 for the Ergon grips.
Don
Don
Likes For GeezyRider:
Hair spray.
Cheerfully low end
Quoted: 177 Post(s)
Liked 255 Times
I’ve seen recommendations for using hair spray but I’ve always used cheap isopropyl alcohol and it’s worked so well I’ve never needed to try the hairspray.
Also, since you have bars with only a small sweep back, I’d give another nod to those excellent Ergon grips. That’s exactly what they are made for.
I use bars with a lot of sweep and mainly use the grips for riding out of the saddle including braking, so I just need a grip that is grippy and a has a bit of cushion. The Oury mtn bike grips are perfect for that.
Otto
Otto
Likes For ofajen:
Bikes: my bikes: Old: 1965 Schwinn 10 speed, 72 Monshee 12 speed, 77 Norco 12 speed, 95 Trek 850, two Specialized Crosstrails, 2016 Specialized carbon Sirrus. New 2020 Trek FX1
Quoted: 43 Post(s)
Liked 11 Times
+ 3 for the Ergon grips, mine are Ergon GP3's and have a small built in bar end, best grips I've ever had!
Likes For trainchaser:
Bikes: A really old BMX bike, Phantom 20 kid's MTB, Jackal Mio Gravel Bike
Quoted: 676 Post(s)
Liked 287 Times
I use this Rockbros lockon spongegrip which I got for $3.5 from a local online store ($6 in aliexpress).
https://www.aliexpress.com/i/32851515599.html
I put additional sponge foam at the ends to remove pressure from the carpal tunnel. Very comfortable even if you never use gloves.
Likes For cubewheels:
Looks interesting. Will it accommodate a Cat Eye mirror that goes into the end of the bar? That's what I currently use. You have to be able to drill a hole in the end of the grip.
Quoted: 30 Post(s)
Liked 21 Times
No need to drill. Ergons have a separate piece at the end which can either be inserted into the bar as a cap, or left out to leave the bar end open.
Likes For Germany_chris:
Quoted: 43 Post(s)
Liked 11 Times
aka Phil Jungels
I used to use Ergon grips, but switched to the Specialized equivalent. I find the Specialized grips very slightly softer rubber, and kinder to my hands.
Clark W. Griswold
Quoted: 2023 Post(s)
Liked 934 Times
Another vote for Ergon grips, the real ones not the various knockoffs out there. I do not recommend trying cheaper grips to see if you like Ergons I recommend trying Ergons to see if you like Ergons.
The one thing with Ergon grips that I recommend is trying them in different positions. The owner of my shop loves to put them at a fairly extreme upward angle and it works quite well for him and his CTS. Experiment and you will find the right spot. Having tried a lot of different grips on different bikes I use Ergons exclusively on any flat/alt bar bikes I own and wouldn't do anything else. I like the support they give my hands and the better blood flow they provide to prevent numbness and discomfort.
If you have a swept back bar, I highly recommend using the GC1 version of the grips as they are designed for the more swept back bars to keep your hands in a more natural position.
RockBros is cheap knockoff stuff (even the name is knocked off from Crank Brothers) and the fact they needed to be modified to make them to make them comfortable is a good sign to avoid. ESI is probably the grip you are looking for in their Fit line (probably CR), they are higher quality and made right here in America.
Likes For MyRedTrek:
I used ESI Grips chunky for a few years. Really comfortable and they don't slip.
I switched to Aliexpress Rockbros silicone grips as they're as comfortable, don't slip, they're cheaper, and I've discovered they're also more durable.
Likes For jack1234567:
aka Phil Jungels
Like I said earlier, I have had both Specialized and Ergon, and find the Specialized far more comfortable. I have now switched out all of my Ergons for the Body Geometry ones, and like them a whole lot more. I gave the old ones to the neighborhood kids who needed grips. Win-win!
Bonus on the Specialized grips is they only cost $25, and even come in colors!
Likes For Wanderer:
Mad bike riding scientist
Quoted: 3897 Post(s)
Liked 1,325 Times
The ESI grips come in 11 different colors, at least 3 different thickness and can even be ordered in 2 and 3 color combinations. I have the Extra Chunky on several bikes and really like them. They can be a bit of a bear to put on but they stay put and they are thicker than you’ll get with lock on grips.
Stuart Black
Stuart Black
Clark W. Griswold
Liked 934 Times
